*** Official OcUK Minecraft Server - Discussion and Rules ***
Why don't people submit building plans, either of real buildings or using one of the planners.
Then we could make an epic themed spawn city point.
Slight alteration...
724 Grass
816 Iron blocks
988 Stone blocks
1284 Glass
Luckily the dome on top has already been built in 1.7 so hopefully admin can just pop it on top of the stand once thats built and build transfers to 1.0 are open :)
Sounds like that should be fine, lets just hope you're not 1 block out in construction ;)
I expect Maxi to do something comical like leave a one block gap between the stand and dome :p ;)
I'll have to use glowstone on the inside to prevent enderman from spawning on it and moving all the glass about!
Okay first issue number 1:
Joachim has build a ******* HUGE dirt spawner on MY ISLAND behind my main build
It was clearly laid out with torches and most people know I have been building under the ground towards my little island.
Secondly, I am having issues sorting my build for transport as I am not sure how to measure the co-ords for it because it is mostly above ground with the cave directly behind it towards the island where that horrendous dirt tower is
LETS TNT IT!!!!!
hm...we found a hole without any bedrock at the bottom etc..just goes down...down...down..
It is under joachs big dirt spawner thingy
Should have jumped into to see what happened.
I think I have the worst diet ever in this game, all ive eaten since ive started playing is bread (which someone kindly gave to me) and rotten flesh.
Good job you dont have to have a balanced diet!
