@Draeger
Glad to hear that you are pleased with it
Also you may have noticed a bigger difference between the old adapter and the TP-Link adapter in a ping test, as you can see the massive difference between mine
lol.
As for the utility software, terribly sorry, I forgot about that
, I also had the same thing pop up when installing it.
Essentially it is just a fancy looking control panel for your adapter settings (like with the ATI and nvidia control panels), which will have a few more options for you to mess around with, but can still be done within windows anyway, maybe just not as easy to find the options.
I had a look on the website to see if there is a later version of the utility available and there may be as usually the drivers etc. that are supplied on the disc are older versions.
http://www.tp-link.com/en/support/download/?model=TL-WN722NC&version=V1#tbl_b
And a quick glimpse of what it looks like to give you an idea:
http://www.tp-link.com/en/article/?id=351
I personally will be leaving it for now (as everything I need the adapter to do, works perfectly fine), may try it out at some point in the future though and update my review with some info/thoughts on the utility software side of things
PS. My review has been updated with this info as well now.
lol.As for the utility software, terribly sorry, I forgot about that
, I also had the same thing pop up when installing it. Essentially it is just a fancy looking control panel for your adapter settings (like with the ATI and nvidia control panels), which will have a few more options for you to mess around with, but can still be done within windows anyway, maybe just not as easy to find the options.
) and I don't think it's ever dropped signal, unlike Netgear's offerings which were as flaky as a Cadbury's Flake and source of endless 'why are you not working!?!' rages.
