Would this work? see photo.
The pump would be just above the floor behind the PC not inside it, so I can get to it when I need to drain the system.
The tubes would enter & exit the case from the back (could not get the whole PC in the photo)
The wall is 40cm of solid stone you can feel the cold coming off it when you put your had close to it.
The radiator fans would be on the outside of the rads pulling the cold air from the stone wall through to cool the water. I would leave a 1cm gap between the wall & the rads.
I could even make a large shroud around the rads so the air has to travel along the wall to enter the rads making better use of the cold air coming off the wall.
So does this seem like a good plain
Thought it would look nice with some coloured fluids going around the wall.
I don't have the room for a watercooling setup inside a case or a larger case.
