So I bought another 5770 to crossfire as I wanted to have a bit more graphics horsepower to play BF3 and so far it seems im generally better off having crossfire disabled - espcially during online play.
I did a little benchmark test using FRAPS during the opening sequence of the campaign level where you're in the car with the ruskies. Graphic settings set to "high". Results were:
Crossfire enabled:
Frames, Time (ms), Min, Max, Avg
3225, 60000, 21, 92, 53.750
Crossfire disabled:
2610, 60000, 34, 55, 43.500
Usage averaged about 60%
As you can see there is only a 10fps average increase, and actually a lower minimum fps with crossfire enabled. This is my main problem as in multiplayer say i'm flying a jet on caspian - the frames will drop horribly low sometimes and i'll just end up crashing into a hill - not a problem I have using just one card.
It's been suggested that my other hardware could be bottlenecking the setup so here's what i'm running:
Vista 64
Asus P5E intel X38 mobo
Intel core 2 quad Q9300 2.5Ghz
2 X 2GB corsair DDR2 XMS2
Sound Blaster x-fi fatality sound card
2 X Samsung harddrives
1 X Enermax Galax 850W modular PSU
Graphics software - Cat 11.10 + CAP4 after an atiman driver removal run.
I've ordered an aftermarket CPU cooler so I can overclock and see if this remedies the situation. In the meantime does anyone have any suggestions as to why this is happening?
Any help much appreciated!
Crossfire enabled:
Crossfire disabled:
Vista 64
