Lmao the aim! it makes me cry worse then when i didnt get no xmas presents when i was 9! lol at the sniper bit on the crane the aim is so bad i wanna smash stuff!
wonder if EA can handle the starwars release while keeping origin and the BF3 service up ;p
Not sure if it has been posted but here is some footage of Karkand and Gulf of Oman
Thx, was engineer and had lock on jet and launched three guided anti air rockets one after another, each time he popped a flare. He then proceeded to kill me and it said he haid 3 stealths fittedDo you get flares by default?
Also when I try to pop flare in a chopper my ir flare is still loading when next rocket is coming in and i die horribly![]()
I haven't played BF2 for so long that I had forgot that there was the spec ops classes in an expansion that had zip lines which I remember using on some map with a Mosque. Makes me wonder what other awesome stuff I have forgotten about.
one knifage doesn't take off 100%. i had to do it 2-3 times unless they have lost health already. that's the knife without the cut scene animation.
If u equip the knife rather than melee to attack does it avoid the cut scene for knifing from behind?
When you hear the lock on, it doesnt mean they've fired a missile yet. So its up to you to guess the time they actually do fire it off and able to block it. I normally do this against jets, i.e.. Lock on and watch them pop a flare prematurely and then shoot my missile![]()
Got out the motar out in metro rush last night. What can i say? call me the shamman, it will rain death!! 23-0 k/d just sending shells when ever a red dot came out, wookies? no problem lol
The final higher pitched/faster tone is the Missile away notification. You should never flare until you hear this. The only time you should do it on a solid tone is when something is so close that delaying would get you killed anyway.
The latter is a rare occurrence however.
Goon at this rate with moans on snipers,infra red scope and mortars we might aswell start trying to use shoes to kill each other
Ive got the urge to go into a 64man server to see how high it will go.
