Onboard Intel NIC chip Vs. Marvell and Realtek
Intel NICs are often well supported by Linux and FreeBSD. Perfect for pfSense. Bigfoot is just a waste of £££.
CPUs are more than fast enough these days to not be concerned about networking tasks. In some test I glanced at about a year ago the reviewer saw a one millisecond advantage by using the expensive card. If it were 20ms then I'm sure they'd have lots of customers but for 1ms it's just not worth tying up a slot.
In real world terms, unless you're transferring a heck of a lot of data, there's no point in spending the money on one for a desktop user imo.
Sure, if you want to backup from a desktop to a server and they both had Intel NICs, vs Realtek onboard, there would be a benefit is what I meant.
Yep, this is only when you're going to notice the difference.
This is why I spashed out on two Intel NICs (think they cost about £20 in total). If you are going straight out onto the internet then you will see no difference. If you are communicating internally then it can help.
Also, CPU network process is negligible
