If you have never experienced a mechanical keyboard for gaming or typing before then you should really take a look. If you a gamer mechanical keyboards have a much quicker response per touch and press than any standard membrane keyboard with a much longer key life also.
We also have a great value 8GB 1333MHz memory kit for that quick upgrade without having to splash a load of cash. Grab your kit now
Ozone Strike Gaming Mechanical Keyboard @ £83.99 inc VAT
Ozone Strike is the latest and most desired addition to the Ozone gaming peripherals family. This keyboard isn't just an interface between you and the virtual world, but it's also an infrastructure featuring the most powerful and well known gaming mechanism: Cherry Black MX switches.
- THE MORE PRECISION, THE MORE SUCCESS
You instantly get the feeling of a winner when pressing the keys. Cherry Black MX switches, require more strength when striking the keys than common keyboards, and also thanks to this particularity, keystrokes are more precise in the relative to its sensitivity when pressed so you get precision when you want precision.
- THE MULTIMEDIA WORLD
You will never have to worry again about having to quit from the game to listen to music while playing or just simply when you want to watch a movie or any multimedia content. Ozone F-Key, gives you access to main multimedia functions by just pressing a few keys.
- GET YOUR WRISTS OFF MY KEYBOARD
To rest or not to rest, that's the question. Strike, features a detachable palm-rest, so you can take it away from your keyboard whenever you want depending on your preferences or your needs.
- DESIGNED TO LAST AND PERFORM
Strike uses double nylon braided cables to ensure their durability and 18K gold plated connector to give you the performance that you need to be the best.
- PLUG YOURSELF INTO THE EXPERIENCE
With Ozone Strike, you can easily plug your USB devices and also your Headphones & Mic, so don't give up on connectivity.
Only £83.99 inc VAT.
ORDER NOW
OcUK Value 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit @ £23.99 inc VAT
OcUk Value Series Memory is designed to optimized the high performance DIMMs for reliability in order to ensure your system does not fail you, while maintaining a solid overclock to prevent a mid-game PC failure from memory errors.
Features:-
- Cas latency: 9-9-9-24-2N
- Capacity: 8GB (4GBx2)
- Speed: DDR3-1333 (PC3 10666)
- Test voltage: 1.5 Volts
- Type: 240-pin DIMM
- Warranty: Lifetime
- Sandybridge compatible
Only £23.99 inc VAT.
ORDER NOW
ORDER NOW
Features:-
ORDER NOW
