mac os, what gesture did this?
13 Jan 2006
Wigan
i did something but no idea what, it brought up a calc, calendar and something else to use quickly.
any ideas? ive looked through a gestures guide but cant see it.
You moved to the widgets dashboard lol. F4 will do the same thing. Depending on how you have gestures setup its either a 3 or 4 finger swipe from left to right.
Yep four fingers right swipes you to the widget dashboard and four fingers left will swipe between any full screen apps you have open.
I've got an early 2008 macbook, does that make a difference?
(from a hardware restriction point of view?)
Depends on the exact model.
You need an aluminium unibody MacBook or later to get multi-touch gestures. The older machines are restricted to 2-finger gestures I think.
MacBook Pro had support from the early 2008 revision.
All MacBook Airs are supported.
