The Channel Islands are not part of the UK. Up until now, HMRC have basically ignored all DVD sized packages coming in from the Channel Islands. Abolishing LVCR will require HMRC to examine each and every one to ensure that the relevant duty etc is paid. That will be manual and hugely time consuming. Then there will be the need for all offshore suppliers to be registered with HMRC, send in returns etc.
It's no different from high value goods and these companies must already pay it. Isnt t it only for goods under £18 and that's being cut to £15?
So no they are already registered and it's already set up. It won't be manual. It'll be x-% checked with punishments I would have thought. They don't hand check ever high value good, do they.
