Antec 1200 fan replacements??
16 Apr 2009
Hi all,
Im looking to replace the 120mm fans on my antec1200 (front and back)
What would be the best to get for quieter/more airflow/best value?
thanks
Ade
Replacing the back ones is quite simple, however i would take a look at the front mounting again before you buy any fans :)
replaced my back ones with the ones mentioned by stulid above :)
When I had my old 1200 I replaced all 120mm fans with Noctua S12s and left the Bigboy200 on low, they were excellent, I didnt encounter any problems with the front fans myself, just for info
Scythe Gentle Typhoon 120mm 1850 RPM
These are well regarded around forums.
Only get these if you have a fan controller or don't mind noise.
The 1450 will also suffice.
Vipers are pretty nice too. For looks, the xigmatek blue lines and the enermax apollishes get my vote.
