H80 or H100?
15 Dec 2004
Hudds, UK
As per title, not sure which one to get as I have space for both.
Corsair H80 or a H100. To be honest I want something quiet and powerful enough to cool a 2700k @ 4.6 (which should be hard!)
Price wise theres is't much between them - just wondering if anyone here has tried upgrading from a H80 to a H100 and how it went. thanks
Zoomee I see you've managed 5Ghz out of your 2700k, which cooler did you choose In the end?
Cheers
I would have said if you are after the lowest temps then go for the h100, assuming you have room for a double radiator of course
Cheers
The 5ghz was from my custom watercooling setup (120.3 rad & supreme hf) but in all honesty even that was struggling to keep my 5ghz oc cool for 24/7 useage. In the end i dropped it in favour of much lower volts n heat for 4.8ghz.
I got the h100 but cant say im that impressed. Its a very thin radiator which i stuck my 1450rpm scythe gts on. still yet to do any conclusive testing tbh guys. will be next week before i get chance
Cheers for feedback fella, I was thinking of running 4 Apache fans In push/pull config.
I am not too fussing about getting to 5Ghz tbh but would like at least 4.6Ghz and not bothered about fan noise, will be running them at full load.
Just £100 bit steep for cooler, shame I rushed and bought the taller Vengeance ram straight away. Bah :(
4.6 is really easy to cool mate. It wont matter which cooler u use because it only needs 1.28volts for me. its above that it becomes trickier to cool. Im still using stock thermal past
I have some IC Diamond 24 I could use, just pending on H80 or H100 now.
