the graphics card is today only price, normally £180 so the one with 2 games for £194
http://www.overclockers.co.uk/showproduct.php?prodid=GX-267-AS
unless the op is planning on sli/xfire on his pc you can cut both mbs back to
http://www.overclockers.co.uk/showproduct.php?prodid=MB-364-GI&groupid=701&catid=5&subcat=1990 save £86(£43 per mb)
can save ~£5 on the psu on the wow by going
http://www.overclockers.co.uk/showproduct.php?prodid=CA-007-XF&groupid=701&catid=123&subcat= prob even the 450w version
change ram to
http://www.overclockers.co.uk/showproduct.php?prodid=MY-132-CR&groupid=701&catid=8&subcat=1517
4gb on the wow pc
http://www.overclockers.co.uk/showproduct.php?prodid=MY-133-CR&groupid=701&catid=8&subcat=1517
thats and just under £30 saved, get the gelid tranquilo with that for overclocking the bf3 pc.
put the money saved from the mb towards better screen or elsewhere.
You probable could fit an i5 2300 build in with a relatively good GPU something like the 6850 and that will be better than llano because the cpu is much better![]()
How would the Llano + 2gb 6950 compare against an i5 + 2gb 560Ti for gaming?
don't go llano for main gaming pc, stick to i5 2500k.
if youre going to put a 6850 in your better off with an i3 2100 or i5 2300 they will both out perform llano if your going to buy a 6850![]()
