- 18 Oct 2005
Is there a quicksave function? What key is it? :S
If you look in the controls menu it tells you, F5
Press Tab to exit conversations. No idea what the controller button is though.
what's a good way to level enchanting? I take it you'll need loads of petty soul jems which will be hard to come by in quantity...
If you serve your time your skill levels reset, the number of which depends on how long you're incarcerated for.
As for breaking out, I believe you can only do it the once, the guards seal up your escape route after that so don't get sent to the same jail.
How do you fill the soul gems?
Just edited my post above.
There are a few ways:
You can learn the Soul Trap spell, or, you can enchant a weapon with the soul trap spell. Not found it yet, but I will be on the look out for it.
On my Xbox Controller, button B is to exit conversations and leave them talking to themselves![]()
Terry Makedon@CatalystMaker tweeted not long ago:
http://www.guru3d.com/news/amd-catalyst-1111-whql-driver-download/
http://twitter.com/#!/catalystcreator
CatalystCreator Andrew D
Still working on Skyrim CAP - definitely aiming to get it released ASAP - upcoming performance driver will include other updates as well
8 minutes ago
Came across a good little part of the game that people may have overlooked/unnoticed
Eat at least one of everything you come across (flowers/butterflys etc), to learn there affects.
what steam overlay?mine loads without steam even being opened!
