** Hauppauge Products Now in stock at OcUK **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We are happy to bring you a brand new range of products today, Hauppauge are a world leader in digital TV and Video recording hardware providing cutting edge features simply not offered by other companies.
With the Hauppauge WinTC Nova-T, you can record and watch TV on your pc or laptop easily. This is a product ideal for students or kids bedrooms where space can be an issue. The benefits of being able to catch your shows and record them is really useful too.
The Hauppauge HD PVR is fast becoming world renowned as the recording device of choice for games consoles. if you have important matches to document or just fancy making videos for youtube, this is the product you need.
It also works with a wide variety of other high definition inputs such as BluRay and Camcorders. Simply put, if you want to put any high def footage onto a digital format, then this is the product for you.
The Hauppauge Colossus does everything the PVR does but is an internal card. This offers the advantages of not needing an external power source and is a cool permanent fixture for your system that allows for a greater deal of AV versatility.
Our range of Hauppauge products will be increasing over time to include more key lines. If you want a product we don't list then let me know either in this thread or the product suggestion forum and I will do what I can to stock it.
needless to say, these are all seriously cool pieces of kit
We have a HD PVR on test at the moment an rjkoneill preview is on its way soon :)
Hauppauge HD PVR Video Recorder @ £169.99 inc VAT
Record your high definition TV programs to your PC, using high quality H.264!
HD PVR is the world’s first High-Definition video recorder for making real-time H.264 compressed recordings at resolutions up to 1080i. HD-PVR records component video (YCrCb) from cable TV and satellite set top boxes, with a built-in IR blaster to automatically change TV channels for scheduled recordings. Audio is recorded using AAC.
The recording format is AVCHD, which can be used to burn Blu-ray DVD disks. Two hours of HD recordings, recorded at 5 Mbits/sec, can be burnt onto a standard 4.7 GByte DVD-R or DVD-RW disk for playback on a Blu-ray DVD player.
The HD PVRs amazing recording quality allows personal archival of your favorite high definition TV programs from any component video HD set top box. The HD PVR also has standard definition composite and S-Video inputs so you can record your old home video tapes into an AVCHD format for creating Blu-ray DVD recordings.
Features
• Built-in hardware H.264 high definition encoder, for high performance, high quality TV recordings.
• Component video input from most high definition cable TV and satellite TV receivers. Optical or stereo audio inputs.
• Record high definition video at up to 1080i resolution, 720p or VGA/D1.
• Record at datarates from 1Mbs to 13.5Mbs, constant and Variable Bit Rate.
• Blu-ray format AVCHD recordings, so you can burn your TV recordings onto a standard DVD disk (up to 2 hours of video at 5MBits/sec) and playback on Blu-ray DVD players.
• Includes HD software video player, so you can playback recordings to your PC screen.
• Audio/Video component video loop through to allow HD recording and viewing at the same time.
• High Performance Noise Reduction Function.
• NTSC,PAL and SECAM Support.
• IR Blaster to change the TV channels in your set top box.
Included with the HD PVR
• HD PVR high definition personal video recorder, USB.
• IR Blaster transmitter cable.
• Component video cable set.
• Audio cable set.
• USB cable.
• 5v power supply.
Bundled software applications
• Arcsoft “TotalMediaExtreme” for video capture, preview, playback, and authoring and burning your TV recordings onto a Blu-ray DVD compatible disc.
• Arcsoft “TotalMedia Theater”, a video player so you can play back your TV recordings to your PC screen.
• Arcsoft “MediaConverter” , to convert your H.264 HD recordings onto other formats.
• Includes Hauppauge's WinTV scheduler for scheduled TV recordings.
Input and outputs
• Component video input and loop through output.
• Optical audio Input and loop through output.
• Left/ Right RCA audio input and loop through output.
• Composite video and S-Video inputs (on front panel).
• Left/right audio input (on front panel).
• IR Blaster output.
• USB2.0 High speed Device.
Only £169.99 inc VAT.
ORDER NOW
Hauppauge Colossus @ £159.98 inc VAT
Colossus is a High Definition video recorder for making real-time H.264 compressed recordings at resolutions up to 1080i. HD PVR records component video (YCrCb) from video game consoles and cable TV and satellite set top boxes, with a built-in IR blaster to automatically change TV channels for scheduled recordings.
Colossus also has an HDMI input port, so you can record HD video at up to 1080i from a un-encrypted HDMI source.
Note: most cable and satellite TV set top boxes encrypt HDMI output, so you cannot record from these sources.
Audio is recorded using two channel stereo or optical audio with five channel Dolby Digital.
Record your video game play
One of the popular uses for the Colossus is for recording video gameplay. As said on GeekTonic:
"Now I think anyone watching me play videogames is a sure-fire way to put them to sleep – or at least laugh at my videogame performance. But I know there is a very large number of videogamers using the HD-PVR to record their video gameplay."
Create your own HD video library ... burn your video recordings in a high definition blu-ray format!
The Colossuss amazing recording quality allows personal archival of your favorite TV programs. Record your TV programs in HD, then burn them onto a standard DVD disk (up to two hours) in a high definition AVCHD fomat.
Colossus connects to any component video equipped HD set top box. Colossus also has standard definition composite input so you can record your old home video tapes and then burn onto a DVD disk. (S-Video input available with optional cable.)
Turn your old home video tapes into Blu-ray DVD disks
You can also use Colossus to turn your old VCR tapes into Blu-ray disks. Record your video tapes using Colossus and then burn Blu-ray formatted DVD disks on your PC.
Bundled software applications:
ArcSoft "ShowBiz" for video recording and authoring and burning of your TV recordings onto a Blu-ray DVD compatible disc
Hauppauge WinTV v7 application, with support for the Hauppauge remote control and IR blaster
Only £159.98 inc VAT.
ORDER NOW
Hauppauge WinTV-NOVA-T USB Stick - DVB-T Digital Freeview TV Tuner @ £34.99 inc VAT
Watch & record Freeview digital TV on your PC or laptop!
WinTV-NOVA-T stick uses the latest high sensitivity digital DVB-T TV tuner, offering the best possible DVB-T digital reception. With this product you will be able to Watch, pause and record DVB-T digital TV in a window or full screen using high quality MPEG-2. Use the WinTV Scheduler to record you favourite digital TV shows. Play your TV recordings back to your screen any time. The WinTV-NOVA-T stick is easy to install. Just plug it into your notebook or PC's USB 2.0 port and connect to a digital TV antenna, Load the software from our installation CD and you’re ready to start watching digital TV on your PC or laptop screen. This product also includes a portable digital DVB-T antenna, so you can receive digital TV while you travel!
The NOVA-T stick uses the COFDM demodulator which utilizes the state of the art Signal Processing to provide high performance portable and fixed reception of DVB-T signal, TV to USB bridge which encapsulates MPEG2-TS packets (Digital TV reception) over USB. This product also benefits from Hauppauge's standard 2 year warrenty and they offer UK technical support.
Hauppauge has been a worldwide leading developer and manufacturer of analogue/digital video, TV and Data broadcast receiver products for the PC since 1982, with an estimated worldwide installed base of over 5 million.There flagship product the WinTV is the leading branded TV card in the retail market place and now they have come to market with this excellent compact lightweight USB device.
This new USB DVB-T device has the Latest COFDM demodulator which utilizes the state of the art Signal Processing to provide high performance portable and fixed reception of DVB-T signal, Therefore ensuring that you always get the best possible digital reception allowing you to watch, Pause and record Digital TV almost everywhere.
WinTV-NOVA-T-Stick features
• Watch Freeview digital TV programmes on your laptop or desktop PC screen, in a resizable window or full screen. Freeview digital TV does not require a PayTV subscription. DVB-T digital TV gives you better pictures and CD quality sound.
• Pause digital TV with instant replay.
• Record digital TV programmes to your PC's hard disk using high quality MPEG-2 compression. Play them back on your PC screen at any time.
• Schedule TV recording using WinTV-Scheduler or the free 7 day EPG (Electronic Programme Guide). See a guide of upcoming digital TV programmes. Schedule TV recordings with a single click of the mouse!
• Listen to Digital stereo radio* on your PC or laptop.
• Media Center compatible. Watch and record TV with Microsoft’s Windows Media Center*.
• Includes Hauppauge’s IR remote control for easy control of WinTV or Microsoft Media Center application (on some models).
• Includes a portable antenna* so you can watch digital TV at home or away (on some models).
Only £34.99 inc VAT.
ORDER NOW
Hi,
You are missing a crucial one - the DVB-T2 USB stick. Currently the only way to get Freeview HD on a PC and quite a good price at 80 quid or so :)
Despite having HD written all over them none of those will do the trick :(
Woo Hoo and about time
Hauppauge make the best DVB stuff , better than the compro carp OCuk
have been stocking for years
Hi,
winner, thanks for the feedback :)
will look into that model tomorrow
good to hear you like it!
Hi,
+1
I bought a TV card from OcUK some time ago, had to return it as even though the box said HD they don't do UK HD !!.....(should carry a warning) Ended up buying the DVD-T2 USB stick from a competitor.... It works well, picture is excellent, and is detected and works in Win7 64 bit Media player.
I've never had a problem with Compro myself, but I would have to agree that the Hauppauge cards tend to be a little better quality.
