just bought a new system
16 Sep 2005
What used to be a UK
..and noticed on a couple of occassions the pc failed to boot normally. It would attempt to boot, then fail and then on the retry successfully boot. this is intermittent though stable on a successful boot. Any ideas pls
Have you tried Prime95 when it is running in windows to see if you get any errors also you could try memtest86 see if you have any problems with your memory. also you could try reducing the clocks to see if it happens
