New Cases! Arriving next week!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
This new brand is exclusively coming to OcUK :) The pics say far more than I can......
Stock is about 1 week away.
Anidees AI-6B Midi-Tower Case - Black @ £109.99 inc VAT
The AI-6 gives an immediately clear first impression of quality and elegance. The Front cover shows a fairly large unit which houses a plastic exterior and with a brushed aluminum centre. In between lie, a set of stealthy, and concealed air vents, which should ensure good cooling.
This look is made possible through a closed front door, which is open when delivered to the left, this can be switched by the user to the right if required. If you open it, one sees a rectangular mesh field in the lower and upper area. The drive bays are provided by three 5.25-inch apertures. For each of them they can be cut away in order to push through an external 3.5-inch device.
Although only an adapter factory setting of one of three 5.25-inch slots at Al-6 is, but those frames can be conveniently buy more if needed. The lid of the clear line is continued by the I/O panel which is inserted inconspicuously. Two USB 3.0 ports that are present in addition to audio connectors and four USB 2.0 and are connected internally.
Under the removable cover part you will find a very good mesh surface, which ensures that a radiator with a size of up to 280 mm which can optimally cool with a good deliver fresh air. Alternatively, it is also just two 140s or 120s fan positioned there. The same applies to the front, where two fans of both formats can be accommodated, while the rear has only one 120-mm fan space.
- Dimensions: 207 x 509 x 527 mm (W x H x D)
- Material: steel, aluminum
- Weight: 11 kg
- Color: Black
- Form Factor: ATX, Micro ATX, Mini-ITX
- Front Cooling: 1x 140 / 120 mm (front, 120 mm optional)
- Rear Cooling: 1x 120 mm (rear) / 1x 140 / 120 mm (front optional)
- Top Cooling: 2x 140 / 120 mm (lid, optional)
- Filters: Front & Back
- Drive bays: 3 x 5.25 inches (external) / 1 x 3.5 inches (external, instead of 1x 5.25 inch) / 7 x 3.5 inch / 2.5 inch (internal)
- Power Supply: Standard ATX 1x (optional)
- Expansion Slots: 8 (without tools)
- I / O Panel: 2x USB 3.0 / 4x USB 2.0 / 1x each Audio In / Out
- Maximum graphics card length: 428 mm
- Features: Elements made of brushed aluminum
- Cable Management
- HDD and power supply decoupling
- Removable hard disk cages
Only £109.99 inc VAT.
ORDER NOW
Anidees AI-6BW Midi-Tower Windowed Case - Black @ £119.99 inc VAT
- Windowed Edition
- Weight: 11 kg
- Color: Black
- Cable Management
Only £119.99 inc VAT.
ORDER NOW
Very nice looking case. Tempted to get one myself, in the market for a new case, although I'm unsure about how good the airflow would be on one of these
The front of the cases either side have vents to pull air in, so its not bad!
I'd recommend changing the section about cooling, since it's a tad confusing, I was thinking surely they could put two 120mm fans in the front. After a little google I found you can put:
Front fans: 2x 120/140 mm (1x 140 mm included)
Rear fans: 1x 120 mm (included)
Top fans: 2x 120/140 mm (not included)
Bottom fans: 1x 120/140 mm (not included)
(After typing this I just noticed it is written in text but I didn't read it, point still remains about simplicity of reading)
Very tempted to get myself one of these, liking the looks very much and looks like it is high quality too.
For some reason these reminds me of the dragonlord lancool k62 i had !
I have no doubt in my mind that these cases will be worth ever penny. They look amazing!
Those descriptions have either been auto translated or were written by someone who does not list English as a first language! Need a re-write really.
