He means changing clock timer with a mod so one game minute = one real minute.? what do you mean.
It isn't needed as Daedric has higher base stats. But, just make whichever one you prefer the look of as both will be absurdly powerful.Ok I'll take the right side of the smithing tree for Daedric. I assume that Dragon Armor isnt needed then?
So I got a new mage circlet from the Archmage and was checking it out, and wondered why my character was making angry faces:
If you're using the custom dx9 dll thingy that's why.I must record the battle, but MSI Afterburner seems to have stopped working with Skyrim, I no longer get the FPS counter, nor does the screen or video capture work!![]()
How exactly do you view your character like this?
Press 'f' to go third person, rotate your mouse round.
My cracked fraps worked though, but splits the video every 1.30![]()
put your weapons away and it should work.
How do you actually turn into a wearwolf? I have the ability but it just sits there amongst my spells and I don't seem to have any actual ability to select it.
You can type tfc into the console for a free roam camera too, lets you get much better screenshotsput your weapons away and it should work.
You can type tfc into the console for a free roam camera too, lets you get much better screenshots![]()
Daedric is better than Dragon
^ Spoilers mate!!
