Today you can get Battlefield 3 Full PC Game free with your new Kingston HyperX SSD. Experience faster game level loading times and quicker boot speeds with this fantastic piece of technology.
You can also jump deep into your game and be fully immersed with Corsairs SP2200 2.1 PC Speaker System. Bring the battle to you!
Corsair Gaming Audio Series SP2200 2.1 PC Speaker System - 46 Watts RMS @ £37.99 inc VAT
The SP2200 is designed for gamers and media enthusiasts who want a powerful, compact 2.1 speaker system that doesn’t take a lot of space. 46 Watts of total power (measured via the FTC “RMS” method), with 30 Watts dedicated to the 6” subwoofer, ensure room-shaking bass and clean, crisp audio reproduction at any volume level. Excellent stereo imaging with a generous “sweet spot” ensure a competitive advantage in games and realistic music and movie audio.
The SP2200 is easy to set up, and easy to use. Controls are up front where you need them, and flexible connection options allow you to connect up to three audio sources at once.
- 46 Watts RMS continuous power delivery for room-filling sound and clean, crisp audio reproduction
- 30 Watt subwoofer with 6” driver for serious bass performance
- Compact satellites with 3” drivers provide detailed audio reproduction without taking lots of desk space
- Excellent stereo imaging with a generous “sweet spot”
Specifications:
- Frequency response of 40Hz – 20kHz +/5 5dB, -10dB @ 35Hz
- 46 Watts total power (measured via FTC “RMS” method)
- Subwoofer: 6” (15.24cm) side-firing, ported subwoofer suitable for desk or floor placement
- Subwoofer: 30 Watts (measured via FTC “RMS” method)
- Subwoofer: Subwoofer enclosure dimensions: 9.1” x 9.9” x 7.1” (23.1cm x 25.2cm x 18cm)
- Satellites: 2” (5cm) drivers
- Satellites: Volume and subwoofer output controls integrated in right satellite
- Satellites: Up-front auxiliary input and headphone output
- Satellites: 8 Watts per satellite (measured via FTC “RMS” method)
- Satellites: Satellite enclosure dimensions: 5” x 3.6” x 5.6” (12.7cm x 9.1cm x 14.2cm)
- Satellites: PC input on subwoofer
- I/O and Controls: Three inputs for maximum flexibility: 3.5mm stereo PC input, RCA stereo auxiliary input for gaming consoles, and a 3.5mm stereo auxiliary input on the right satellite for MP3 players
- I/O and Controls: 3.5mm headphone output
- I/O and Controls: Main volume and subwoofer output control dials on the right satellite
- Package Contents: x1 subwoofer, x2 satellites, Power cable, User Guide
- Retail box dimensions: 12.8” L x 11.5” W x 11” H (32.5cm L x 29.3cm W x 28cm H)
- Weight: 11.17 lb (5 kg)
Only £37.99 inc VAT.
ORDER NOW
Kingston HyperX 120GB 2.5" SATA-3 Solid State Drive ** With FREE Battlefield 3 ** @ £166.99 inc VAT
The all new Kingston HyperX performance SSD featuring the Sandforce SF-2281 controller for blistering fast reads and writes and industry leading IOPS.
- 95k IOPS
- Capacity: 120GB
- Controller: SandForce SF-2281
- Maximum Read: 555MB/sec
- Maximum Write: 510MB/sec
- Max I/O Per Second (IOPS): 95000 IOPS (4KB File, READ)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
** For a limited time only Battlefield 3 Retail is provided for FREE with this SSD **
** Stocks apply **
Only £166.99 inc VAT.
ORDER NOW
Specifications:
ORDER NOW
- 95k IOPS
- Capacity: 120GB
- Warranty: 3 Years
** Stocks apply **
ORDER NOW
