Call of Duty: Modern Warfare 3
Right so I could have my 3 perks I normally have and then an additional 3 once I hit a certain amount of kills, totalling 6 perks?
Yea the way it worked for me say on the dome map I'd throw two flash bangs were they spawn and get two assists from the flash bangs gave me my 1st perk scavenger pro, then if I got two kills or took out a UAV then a kill I would get quick draw then on my 5th kill I'd get dead silence and 7th kill I would get everything
With hardline pro if you get two assists it counts as a kill which spamming flashes or spraying the SMG you get your first perk in seconds
Worked out like this
1kill or two assists first perk
2 more gives 2nd perk
2 more gives 3rd perk
2 more gives all perks
But have to be using hardline pro
If you use stinger and take out air support you get all perks really easy
I think after 10 kills you should turn into a juggernaught with Gatling gun !
I'm not going to bother trying specialist, I die far too often :p
Even just one extra perk can make a difference like adding something like Sitrep or Assassin because you really need Quickdraw on an Assault rifle.
If you run Hardline capping a point or shooting something down will earn you your first perk and bonus.
I see why specialist is such a popular streak to choose now, when you highlight the assists with HL Pro counting towards kills it makes it easy to get all the perks.
It feels very like WAW, that feeling of you being dead before being shot. I guess the map design is so different too that it really feels very different to the typical modern day COD games.
I think ill try the throwing knifes too.
Kill confirmed is probably the best so far, although had some decent games of Domination not being in a party
Had a quick go on survival last night, only on easy. Seems decent - I guess the harder levels are a pain?
Can Juggernaughts be brought down with a predator in one hit on the harder levels.
The harder levels where only a pain on hard because we didn't realise you only had to get to wave 15 on each level rather than finish it. On hard you get a wave of juggernauts and choppers at 5, 10 and 15. On insane you only get them on 6, 11 and 16. That made harder more difficult than insane until you realise you only need to get to 15 not finish it!
To be fair none of it is hard. Find a corner double sentry. Both have a predator waiting and maybe flashbangs. On the harder levels an attack chopper comes in with the Juggs. Just predator the chopper and run round the map in circles picking of the juggernauts. A predator will kill a Jugg in one hit but it's a waste.
A couple of the levels on insane you can whack down double sentries and sit eating a bag of crisps while watching the game auto run.
The map layout on hard is more difficult than Insane to find spots to lay down two sentries to cover all angles.
I used my pred to get all 3 after flashbanging them, but thanks for the tips.
Think I'll do similar after, I prefer GOW3 online.
Have raised a shaky K/D when started playing (1.17) upto 1.36, woo!
Does anyone else completely milk domination for all it's worth? My favourite game type by miles! :)
Not as comical as my killcam which showed you missing someone with a throwing knife by about 2 miles. :p:D
That was a decoy throw , if I miss then it was a decoy throw see the guy would have heard it and it would have bamboozled him abit which then makes it easier for you to kill him
By far the easiest one to whore XP on is underground. Solo I get to wave 24 which has just taken me in one sitting from level 48 to 49. Two sentries under the bus shelter type thing where the air support box is and when I died on wave 25 I had $30,000 still unspent.
I had two fully upgraded LMG's by the end and masses of gear.
