I've been using the Specialist strike package and I really like it.
Start with Blind Eye pro+Hardline+Stalker. With a silenced G36 and a stinger.
My perks for the specialist are then Assassin,Scavenger,Sleight Of hand.
I'm doing much better as there's no worrying about if you're gonna get a kill streak. Just run around shooting and if you get a load of kills you get better.
. . Hopefully they will fix it next patch or two.
