- 27 Mar 2004
- Between Realities
what you've just said is basically if someone is willing to pay more for an item than you then they will win it... Erm.. Duh!?
But the thing is, Fleabay has more than just you on it. There are snipers, there are people that alter last bids, there are people who sit back with an early max bid. If you want to realistically win. You need to be able to try and figure out what the top bid is.
How can you not grasp the concept of a single early high bid inorder to gauge the highest bidders max bid? At 60 seconds put in something high, but not your real max bid. this will sometimes put you on top(and therefore you end up with a bargain), At other times, it will just give you an example of what sort of money is in play, with regards to what you're bidding on. You dont enter your real max bid until the last few seconds, And at that point, you either win. or lose out to someone with a higher max bid. But thats fair enough...because like you said. If you lose to someone willing to pay more. Fair enough right?
But please dont try and push your method forward as the right one, and try and put us last second bidders in a dim light... It makes you sound so damn arrogant.
