If you are looking for a new graphics card which comes with LOADS of freebies worth around £100 then you've stopped on the right thread. The HIS ATI Radeon HD 6950 IceQ X PLUS Edition card comes with Battlefield 3, Dirt 3 and Deus EX FREE... yes... all of them!
We also have the lowest price in the UK on for the amazing 2500K processor which offers great OC potential.
HIS ATI Radeon HD 6950 IceQ X PLUS Edition 2048MB GDDR5 PCI-Express Graphics Card **Supplied with Battlefield 3, Dirt 3 & Deus Ex PC Games** @ £215.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Special IceQ Cooler taken from 6970 and custom fitted to 6950 by HIS for upto 18c better cooling
- Great OC Potential
- OcUK Exclusive
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Battlefield 3, Dirt 3 and Deus Ex PC Games
Only £215.99 inc VAT.
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £155.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Only £155.99 inc VAT.
ORDER NOW
Features:-
- OcUK Exclusive
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
- Cores: 4
- Threads: 4
- TDP: 95W
- Socket: LGA1155
- 1yr Warranty
ORDER NOW
