- 21 Oct 2004
- Wales
It's only been 2 weeks since I asked for the best GTX560Ti ^.^ but it seems that I am being given a GTX580 for this x-mas (wish they had told me before), anyway the family member in question is allowing me to pick out the one I want but I need some help to decide on which one I should get.
Of course I am a big fan of low noise as with my choice of case being the Fractal R3 with a H80 fitted with 2 x 1850RPM GT's, 2 x 120mm fans connected to the front 120mm mounts which are both connected to a fan controller. My question is this, which design, reference or aftermarket would dump the least amount of heat into the case while maintaining a decent thermal performance while remaining quiet.
