Successfully installed a Silver Arrow on my 2500K chip just now and after doing a quick run of IBT after setting my motherboard to optimized OC settings for 4.6ghz i'm left pretty disappointed. I'm pretty sure Core temp's vcore reading is off as the Asrock Extreme tuning software was more in line with CPU-Z'd reading of 1.36ish.
My case cooling consists of a 120mm Apache front intake, 120mm Bitfenix Spectre side intake and the stock coolermaster fans as rear and top exhaust. I knew my temps wouldn't super awesome since my case is about a food away from my radiator but i was still expecting better
80c on the hottest core after only about 5 minutes of IBT seems kinda crappy. And presumably when i play a game things will only get worse once my 460 starts dumping warm air in the case.
Should i be concerned?
