- 24 Sep 2011
Afternoon all,
I'm going to get my brother several PC components for christmas, so he can build his own rig.
Purely by chance I managed to get a fantastic deal on some RAM yesterday, and ended up with 8gb (2x4GB) of this;
http://www.kingston.com/anz/hyperx/products/t1_ddr3.asp
It's the dual channel one, not the triple channel. The only concern I have about it is that I believe it has fairly large fins, and don't want to have problems fitting everything together.
I'm fairly hopeless when it comes to these things, so don't want to make a mess of it or buy something which is incompatible.
At the moment I'm thinking about getting him the i5 2500k.
He just uses the PC for general bits and bobs. Perhaps sometimes he may dabble in some basic image editing. He'll probably end up playing Skyrim on this when it's out, but I certainly can't afford to build it to run on the very highest settings. Other than that it will be a general use PC.
Ideally I'd like a motherboard under £100, and a GPU under £100. He will not overclock this PC whatsoever.
Can anyone suggest a CPU, GPU, Mobo, PSU and anything else which they think may be required?
Many thanks,
John.
Edit: In regards to a hard drive, I'll most likely pull something off another PC and stick it in there until prices return back to sane levels. Alternatively I might just try and find the cheapest 160gb available and run the important stuff off that, then he can use an external drive for work etc.
Many thanks,
John.
