Depends completely on map and play style but I run 5 classes all set to assualt so take advantage of all maps and situations. All classes run with semtex and flash bangs.I can't remember perk names though but
Class 1 - Small maps when air support or uavs are up a lot
Primary: UMP 45 Rapid fire and kick
Secondary: Launcher
Perks: Anti Air support (blind eye I think) Anti Uav and No noise (ghost?)
Class 2: Small maps when I really want to run and gun, lots of cover if helicopters go up etc.
Same as above but machine pistol for secondary and perks: sleight of hand, quick aim and steady aim.
Class 3: Bigger maps or with more open areas where ump45 doesn't the range
Same as class 1 but with Primary as ACR with kick and silencer
Class 4: Bigger maps or with more open areas where ump45 doesn't the range
Same as class 2 but with Primary as ACR with kick and silencer
Class 5: For those times when I want a bit of both.
Primary: UMP 45 rapid fire and kick
Secondary: ACR with kick and red dot
Perks (IIRC) is, sleight of hand, 2 primary weapon (overlord?) and Steady aim.
I find that it gives me the option and ability to quickly change between classes depending on the map I am playing on. Though it depends completely on preference, I know a mate of mine who is very similar level hates the ump45 (and the other SMG's) and sticks to purely AR's.
I think some of the connection problems last night might have been due to Infinity Ward running stress tests on elite. I'm sure the last time they did something similar it locked up the leaderboards which is exactly what was happening last night.
I'm getting bloody annoyed with the Stealth Bomber on this, lost a great kill streak last night due to someone running a support class and picking up a SB, only for it to then kill me when I was inside a building, infuriating to say the least.
It's not theatre mode it's lag compensation rearing it's head again, I suffered from it mildly in Black ops but don't seem too as much in this. It has been present in COD games since Black ops and can be adjusted if you know how by giving your self a high ping this will give you a huge advantage, unfortunately again if you have a great low ping connection (basically if you ruled the roost on MW2) you will suffer on this.
Nothing to do with green bars on the game you can have 4 still with a wild ping, I think the green bars represent quality of connection rather than ping.
Patch out earlier for PS3 not sure what it does if anythingis there one out for 360 also ???
Tell me about it! As you know I will pull host 9 out of 10 times and end up with a completely gimped playing experience because of it![]()
Need to downgrade my intarwebs!
They need to sort out the lag. It's pointless sniping now. All you get is hit markers, even at dead aim.
