I've found the notification LED to be very good both under sunlight, bulb light and in the dark![]()
Great news! The one on the Sensation is absolutely terrible, and the one on the 9900 is fantastic.
Try use Diceplayer, supposedly that works no problem.
Is this on the bottom of the phone yeah? Ive not managed to see it yet...
anyone have a rooting guide for n00bs?
RE Best Video Player :
DicePlayer - was the only thing that worked properly on my Asus Transformer and now also works on the GN
Uses Hardware Acceleration
RE Notification Light
Much better then on any HTC device
Its nice and big, Measure 3mm in diameter
Very Clear in all lights, Not too bright in the dark so it dosnt illuminate the room but very noticeable
For using this phone as a modem via tethering -
- Is this function supported out of the box?
- Does it require rooting or can I simply connect my phone via USB and connect to the net?
I already have an easytether license anyway so it doesnt matter much.
Oh they never worked for me either. I had to use QQ player to play them. Very stuttery though so its not really possible to play mkv files yet...
Theres is an option in settings for tethering and mobile hotspots etc. Im not sure for usb tethering but wifi tethering works beautifully.
I bought mine today from a 3 store only to get home and find pictures of the inside of the store in the gallery from the previous day. Is it normal that Three sell what is essentially a used second-hand handset for full price?
By wifi tethering do you mean wifi to the Phones 3G internet, or wifi to the home broadband?
I need connection via my sim card, not via the home broadband.
Mobile hotspots is connection through another broadband service, not through the phones 3G isnt it?
So.......what are peoples impressions now that they have had it 24hrs???
Any issues?
Good points?
Bad points?
knit-picking issues??
Really would like to know. Many thanks!!!
Sorry i should have been more clear. 3g tethering through my phones sim card. Proper tethering mate. I can use my phone as a wifi hotspot so my laptop essentially sees a wireless network which is my phones 3g sim card. Exactly what youre after.
