hero!
Oops, this was meant to say...
Treated myself to one of these today, hell of an upgrade from my hero!
hero!
(A bit of a rubbish) camera comparison here with the Galaxy S II. The Galaxy S II is certainly better but there isn't a great deal in it -
http://imgur.com/a/HQa7J
This just wont work for me. Do you have to enable it in settings?
So.......what are peoples impressions now that they have had it 24hrs???
Any issues?
Good points?
Bad points?
knit-picking issues??
Really would like to know. Many thanks!!!
I didn't know Andy had done one. He came to the conclusion the Galaxy Nexus is better though, which is a bit odd as the SGS2 seems to capture detail a lot better, especially outdoors. It doesn't take much to get phone camera pictures to vary though, a cloud moving for example can have a profound effect.
The low light performance of the Nexus is very good though, as are the macro shots. I suppose with the instant shutter speed, you could argue it edges it.
Anyway, it's good news that the Nexus camera is decent.![]()
I've set the text size to small too, I can fit loads on the screen now.
Yes please
Agreed, I used hotspot shield, worked without issue and took me 1 minute!
You can change text size, system wide? Does this also make everything else smaller, like turning down the DPI on older android versions?
