Can you sharpen something that's out of focus?
16 Nov 2009
UK
I have a cute picture of my daughter, but it's horribly blurry. I know this is a long shot but is there anything I can do to make it significantly better? Or is this impossible?
(PS: I'm not bothered about anything in the background.)
No idea, but this is why I want that new camera. That takes a picture of everything and then in post processing you decide what you want in focus.
http://www.lytro.com/
$499, if I can save enough I may well by one next year when I'm over there.
Obviously it's limited what you can do with motion blur but I hope that's an improvement for you. I took the liberty of fixing the colours and increasing the contrast a bit to help define the edges.
You can't do anything easily that would actually make it look better since the information to do so isn't there. It'll just look speckled from over sharpening.
The info is there to a point - it's just smeared over the sensor a bit. Just need whatever future version of photoshop gets the new de-blurring technique they recently demo'd.
There probably are algorithms that could fix it up better. You can see the blur fields are split in two from looking at the 'l' on the shirt but you'd have to find a way to separate (hardest part) them and then align them better.
