****The Official Samsung Galaxy S II ACCESSORIES Thread***
Just upgraded from an HTC Desire to the S2 (should arrive in the next few days)
Does anyone know a decent case that will fit with the extended battery? Been looking at the Genuine Samsung Galaxy S2 Flip Cover (just trying to find stock of it atm) also trying to find the battery in stock to. Seems the place to get them is a site that's *mobile* and *fun* they are out of stock atm but does anyone know of any better deals for the items?
Extended Battery arrived this morning, came with ~60% charge. Is it worth charging it up to 100% first? or shall I let it run down then charge it etc?
Same, but i got 68% with mine ;) :cool:
And it does feel so much better.
Does anyone have/or can recommend a case for the SGS2 with the extended battery?
Thanks.
Thanks.
According to Samsung and mobilefun.co.uk the Genuine Samsung Galaxy S2 Flip Cover fits with the extended battery but out of stock. Looking for a case myself as I should get the S2 on Monday and looking for a case for it that will go with the extended battery.
Fancied something like the Case mate, so basically gel case, but i want it to be solid and have a good build quality. Last eBay job i did came cracked, thats what you get for paying £4 :p
Got my battery this morning. My case even fits and looks ok.
Too early to really tell but it seems good.
Charged up to 96% when I had to go out at 12pm and it's only down to 74% now. Some camera work and plenty of wifi browsing.
Pleased with that.
Pleased with that.
Which case are you using as I am looking for one for when the phone arrives as I ordered an extended battery for it so its ready from the get go, cheers.
Just a £2.50 plastic jobby from the well known auction site.
If you really want the exact one then send me a trust message with your email address and I'll link you up.
Well 17 hours after full charge and the battery is on 63%. I don't know how the extra 350mAh does it but it doesn't seem to be a linear ratio!
It has been on wifi pretty much constantly. Bit of browsing forums. Lots of Facebook messaging with location services enabled. No calls, but a few texts.
Not at all an issue, I get the same results calibrated or not. The extended battery "is" that good. I posted my results many pages back many times :p
Interesting. At the end of the day the battery is supposed to be only 350mAh bigger.
The change in behaviour would suggest a bigger increase....which what myself and the previous poster were saying.
Im thinking of getting a 32gb microsd fpr mine, how much of a difference is there between class 4 & 10 in this phone? anyone have any experience of this?
Thanking you
I understand about the speed difference i was more concerned about actual usage in the phone itself and if its noticable :)
I think i might go for Class 4 as im only going to use it to store music :)
