AV Amp with Airplay
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
A curve ball to the stereo amp thread.
Just wondering what AV Receiver out there with Airplay that is under £800?
I know Pioneer has one but it is £1k.
The reason i am asking is that half my time i am playing music through my old am through Apple Express and so for that time, stereo performance doesn't need to be top notch...it isn't exactly Lossless format for a start!
So...Av amp with airplay? Suggestions?
So...what is the best AV Amp (forget stereo HiFi side of things) this side of £800?
Must have Airplay, and whatever the must have tech these days.
Thanks for the suggestion but what is the difference between the LX range and the VSX range?
Generally the LX range is higher, though reports said the 2020 was the same internals as the LX53 just the LX has aluminium front.
The 2021 is newer and adds airplay, seen some good reviews on it, I'm sure it will be excellent.
Looking at the spec compare
http://www.pioneer.eu/uk/products/42/98/405/compare.html?__P5=55732&__P6=55731&__P9=54466
The difference between the LX and 2021 is 7.2 v 7.1 and the wifi really. The rest is much of muchness, same body chassis as well.
Where the real star is the 921 !!! It has 90% of the LX and 35% of the price !!!
