Wednesday is upon us, this means it's that time again for This Week Only and the next lot of price drops we have to offer. As we are closing in on Christmas now is a great time to start buying presents to miss that Christmas online ordering rush. Offers last for one week and there is something for everyone.
Microsoft Xbox 360 Wireless Controller - PC / Xbox 360 (JR9-00010) @ £26.99 inc VAT
The Xbox 360 Controller for Windows works with most Windows XP-based PCs and Xbox 360, delivering a consistent and universal gaming experience. Get a better feel for the game with vibration feedback ensuring riveting game play every time. Part of the new Game Precision Series, the Xbox 360 Controller offers precision, comfort and control that will set the standard for next-generation game controllers. The pad has precise thumb sticks, two pressure-point triggers, and 8-way directional pad for enhanced PC gaming. Integrated 2.4 GHz high-performance wireless technology lets you control the action from up to 30 feet away
- Integrated 2.4 GHz Wireless
- For PC and Xbox 360
- Vibration Feedback
- Ergonomic Design
- Xbox Live Play - Integrated headset jack for PC headsets and Xbox Live play
- Includes Receiver
Was £29.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive (CSSD-F120GB3-BK) @ £128.99 inc VAT
Step up to SATA 6Gb/s performance with a Corsair Force Series 3 SSD. Your system responds better, boots quicker, and loads applications faster. Ideal for notebooks, Corsair SSDs run cooler and quieter than traditional hard drives, using less power.
- 120GB Capacity
- Sequential read speeds of up to 550 MB/s
- Sequential write speeds of up to 510 MB/s
- SATA 6Gb/s (SATA 3) connectivity
- High performance SandForce SF-2200 SSD controller
- Native TRIM support (O/S support required)
- RAID Support
- BGC (Background Garbage Collection)
- 2.5" - 3.5" Adaptor Included.
** FIRMWARE ISSUE FREE **
Was £133.99 Inc. VAT
Only £128.99 inc VAT.
ORDER NOW
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £76.99 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 475MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £79.99 Inc. VAT
Only £76.99 inc VAT.
ORDER NOW
OcUK V6 Watercooled Case - BitFenix Shinobi **2011 Compatible** @ £194.28 inc VAT
Assembled by Expert OcUK Technical Staff, the V6 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
The OcUK Watercooled Case range comes pre-assembled for your convenience. All of the difficulty of watercooling has been removed and allows you to enjoy the best performance without the hassle.
All of our pre-watercooled cases are built to order and come pre filled ready for you to build your dream system.
The system is shipped with Clear Mayhems Ultra Pure Fluid. If you prefer us to use a coloured fluid or specialist liquid, you can choose from a wide range
All you need to do is build your PC and install the waterblock which is just as easy to do as mounting any CPU cooler.
All leak testing and filling is carried out by our technical staff which means that the watercooling system is ready to use by you when it arrives. All that is required is for you to plug the pump and fans into your power supply.
PLEASE CHOOSE THE CORRECT MOUNTING BRACKET FOR YOUR CPU
BitFenix Shinobi Gaming Windowed Case - Black
- Dimensions: 205 x 460 x 490mm
- Motherboard Sizes: Mini-ITX, mATX, ATX
- 5.25" Drive Bays x 3
- 3.5" Drive Bays x 8
- 2.5" Drive Bays x 2
- Front Cooling: 2 x 120mm Fans (optional) 1 x 120mm Fan (included)
- Rear Cooling: 1 x 120mm Fan (included) or 1 x 92mm Fan (optional)
- Top Cooling: 2 x 140mm Fans (optional) or 2 x 120mm Fans (optional)
- Bottom Cooling: 1 x 120mm Fan (optional)
- Expansions Slots: 7
- I/O Ports: 4 x USB2.0 & 1 x Audio
"EK-KIT H3O - Supreme LT 120" water cooling kit includes following items:
- EK-Supreme LT - UNI (universal CPU block based on EK-Supreme LT)
- EK-Backplate CPU Universal
- EK-CoolStream RAD XT (120)
- Yate Loon D12SH (2200rpm) or Yate Loon D12SM (1650rpm)
- EK-DCP 2.2 Pump
- EK-Reservoir Combo DCP 2.2
- EK-DCP PUMP mounting plate KIT
- TUBE Masterkleer 12,7/9,5 CLEAR (2 meters)
- EK-PSC Fitting 10mm - G1/4 Nickel (6 pcs)
- EK-Ekoolant UV Blue (concentrate 100ml)
- TIM Arctic Cooling MX-2 (EKWB 2g)
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in complteing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Was £200.00 Inc. VAT
Only £194.28 inc VAT.
ORDER NOW
OcUK V8 Watercooled Case - Corsair 650D **2011 Compatible** @ £285.47 inc VAT
Corsair Obsidian 650D Gaming Midi Tower - Black
- Motherboard Support: ATX / mATX
- Expansion Slots: 8
- Drive Bays: 5.25" x 4 & 3.5"/2.5" x 6
- Cooling: 2 x 200mm Fans and 1 x 120mm Fans
- Front I/O Ports: USB2.0 x 4 / FireWire x 1 / Audio x 2 / 4-Channel Fan Controller
- Dual 200mm fans provide outstanding cooling for even the hottest components
- Easily accessible dust filters make maintenance simple and hassle-free
- Quick-release side panels make it easier than ever to upgrade your hardware
- Integrated fan controller lets you quickly adjust cooling performance and noise levels
- Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of expansion
- CPU backplate cutout makes it easy to upgrade your CPU cooler
- Brilliant cable routing system provides a way to keep your system neat and tidy
- Adjustable drive cages can be removed and relocated to accommodate large video cards
- Room for long power supplies gives you peace of mind for future upgrades
- Dimensions: 546mm (L) x 229mm (W) x 521mm (H)
EK-KIT H3O - Supreme LT 240 water cooling kit includes following items:
- EK-CoolStream RAD XT (240)
- EK-DCP 2.2 Pump
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Was £300.00 Inc. VAT
Only £285.47 inc VAT.
ORDER NOW
OcUK V12 Watercooled Case - Corsair 800D **2011 Compatible** @ £388.67 inc VAT
Assembled by Expert OcUK Technical Staff, the V12 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
Corsair Obsidian 800D (6GB/s) Full Tower Case - Black
- Four easily accessed hot-swap drive bays
- Removable CPU backplate panel for easy heatsink installation
- Isolated cooling zones prevent heat buildup
- Unique cable routing holes guarantee a clean and clutter-free installation
- Three fans included, with the ability to add four more 120mm fans
- Tool-free optical drive installation makes building a system faster than ever
- Two year warranty with Corsair’s world-class customer service and technical support
- Dimension: 609mm X 609mm X 229 mm
- 5 x 5.25" Drive Bays
- 4 x 3.5" SATA Hot Swappable Bays
- 2 x 3.5" Internal Bays
- Cooling: 3 x 140mm fans (included)
- Cooling: 4 x 120mm fans (optional)
- Front I/O: 4x USB 2.0, 1x FireWire, 2x Audio
EK-KIT H3O - Supreme LT 360 water cooling kit includes following items:
- EK-CoolStream RAD XT (360)
- EK-DCP 2.2 Pump
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Was £400.00 Inc. VAT
Only £388.67 inc VAT.
ORDER NOW
Laing D5 Vario Pump -T12 12V DC Pump @ £69.98 inc VAT
In response to the overwhelming demand for a quieter MCP655, we are proud to introduce the new MCP655 pump, which features several key improvements: considerably reduced audible operating noise: the high pitch frequency of the MCP655 is now eliminated thanks to a new chipset controller, head and flow characteristics have slightly improved in the midrange,
a potentiometer allows you to adjust the pumps speed from 4800 rpm down to 1800 rpm. At 1800 rpm, the pump is virtually silent. This allows users to tune the pump performance/noise ratio to their particular preference.
- 50,000 hours MTBF (Mean Time Between Failure) equivalent to 5 years lifetime.
- Superior 12 Volts DC convenience: plugs into the computer power supply
- Superior real world performance versus any aquarium pump we have tested to this date.
- The high pressure capability of the MCP655 is particularly well adapted to high-flow systems using 1/2" ID tubing
- Pump speed can be adjusted to yield top performance or virtually silent operations
- Maximum discharge 317 GPH (1200 LPH)
- Compact design
- Quiet operations even at high speed thanks to new chipset controller
- ½" barb fittings
- No maintenance when used with de-mineralized water and additives
Was £79.98 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Thrustmaster Hotas Warthog Joystick @ £249.98 inc VAT
The Hotas Warthog is an U.S. Air Force A-10C attack aircraft HOTAS (Hands On Throttle And Stick) replica joystick high end system. Pre-order now to be the first to receive the most anticipated military control system ever devised.
Flight Stick
- 3D magnetic sensors (Hall Effect) on the stick: enjoy surgical precision that stays razor-sharp over time
- 16-bit resolution (65536 x 65536 values)
- 5 coil spring system: firm, linear and fluid tension, with no dead zones
- USB connection with upgradeable firmware
- Super-stable, weighted base (over 3kg)
- New detachable handle, crafted entirely of metal: also compatible with HOTAS COUGAR™ handle (and vice-versa)
- New replica shape
- Detachable metal plate for desk- or cockpit-style use
- New, realistic pressure on buttons and trigger
- 19 action buttons in total + one 8-way "point of view" hat: . 1 x 8-way "point of view" hat . 2 x 8-way hats . 1 x 4-way hat with push button . 1 x metal dual trigger . 2 x push buttons . 2 x pinkie push buttons
Dual Replica THROTTLES
- Innovative new H.E.A.R.T HallEffect AccuRate Technology(*):
- 3D magnetic sensors (Hall Effect) on the 2 throttles: enjoy surgical precision that stays razor-sharp over time
- 14-bit resolution (16384 values) on each throttle
Dual throttles
- Metal hand rest
- Locking system
- Adjustable friction system: firm, linear and fluid tension, with no dead zones
- Realistic IDLE detent with "Pull & Push"(*) system
- Realistic and disengageable AFTERBURNER detent with "Pull & Push" system
- Realistic pressure on buttons and switches
- 17 action buttons in total + 1 mouse hat with push button + one 8-way "point of view" hat: . 1 x mouse hat with push button and 3D magnetic sensor (Hall Effect) . 1 x 8-way hat . 1 x 4-way hat with push button . 1 x push button . 1 x 3-position switch (2 momentary + 1 permanent) . 2 x 3-position switches (3 permanent)v . 1 x 3-position switch (1 momentary + 2 permanent)
Replica Control Panel
- Weighted base (over 3kg) incorporated underneath the throttles
- Backlit functions
- 5 programmable LEDs
- 15 action buttons in total + 1 TRIM wheel: . 1 x TRIM wheel . 2 x push buttons . 5 x 2-position switches (2 permanent) . 2 x 3-position switches (1 momentary + 2 permanent) . 2 x 3-position switches (3 permanent)
Was £279.98 Inc. VAT
Only £249.98 inc VAT.
ORDER NOW
Hauppauge Colossus - Video Input Adapter - PCI Express x1 @ £156.38 inc VAT
Colossus is a High Definition video recorder for making real-time H.264 compressed recordings at resolutions up to 1080i. HD PVR records component video (YCrCb) from video game consoles and cable TV and satellite set top boxes, with a built-in IR blaster to automatically change TV channels for scheduled recordings.
Colossus also has an HDMI input port, so you can record HD video at up to 1080i from a un-encrypted HDMI source.
Note: most cable and satellite TV set top boxes encrypt HDMI output, so you cannot record from these sources.
Audio is recorded using two channel stereo or optical audio with five channel Dolby Digital.
The recording format is AVCHD, which can be used to burn Blu-ray DVD disks. Two hours of HD recordings, recorded at 5 Mbits/sec, can be burnt onto a standard 4.7 GByte DVD-R or DVD-RW disk for playback on a Blu-ray DVD player.
Record your video game play
One of the popular uses for the Colossus is for recording video gameplay. As said on GeekTonic:
"Now I think anyone watching me play videogames is a sure-fire way to put them to sleep – or at least laugh at my videogame performance. But I know there is a very large number of videogamers using the HD-PVR to record their video gameplay."
Create your own HD video library ... burn your video recordings in a high definition blu-ray format!
The Colossuss amazing recording quality allows personal archival of your favorite TV programs. Record your TV programs in HD, then burn them onto a standard DVD disk (up to two hours) in a high definition AVCHD fomat.
Colossus connects to any component video equipped HD set top box. Colossus also has standard definition composite input so you can record your old home video tapes and then burn onto a DVD disk. (S-Video input available with optional cable.)
Turn your old home video tapes into Blu-ray DVD disks
You can also use Colossus to turn your old VCR tapes into Blu-ray disks. Record your video tapes using Colossus and then burn Blu-ray formatted DVD disks on your PC.
Bundled software applications:
ArcSoft "ShowBiz" for video recording and authoring and burning of your TV recordings onto a Blu-ray DVD compatible disc
Hauppauge WinTV v7 application, with support for the Hauppauge remote control and IR blaster
Was £159.98 Inc. VAT
Only £156.38 inc VAT.
ORDER NOW
Need For Speed The Run - PC @ £27.59 inc VAT
nonl2br
<a href="http://www.origin.com/download"/>
<img src="http://www.overclockers.co.uk/LP/games/originactivation.PNG"></a><br><br>
It’s called The Run.<br>
An illicit, high-stakes race across the country. The only way to get your life back is to be the first from San Francisco to New York. No speed limits. No rules. No allies. <br>
All you have are your driving skills and sheer determination as you battle hundreds of the world’s most notorious drivers on the country’s most dangerous roads. In Need for Speed The Run, you’ll weave through dense urban centers, rocket down icy mountain passes and navigate narrow canyons at breakneck speeds, all the while evading a relentless police force prepared – and willing – to use lethal force to take you down.<br><br>
<center><iframe width="560" height="315" src="http://www.youtube.com/embed/V2WeeL8EFrA" frameborder="0" allowfullscreen></iframe></center>
Was £28.99 Inc. VAT
Only £27.59 inc VAT.
ORDER NOW
Antec Kúhler H2O 620 CPU Watercooler (Socket Intel LGA 775 / 1155 / 1156 / 1366 / AMD AM2 / AM3 / AM2+ / AM3+) @ £40.98 inc VAT
Finally, there is a liquid cooler for the rest of us. The Antec KÜHLER H2O 620 delivers high-performance liquid cooling for your CPU in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The voltage-controlled 120 mm fan, 3rd generation copper coldplate and airflow-enhancing low-profile pump ensure efficient cooling, while the estimated 50,000 hour pump lifetime means this cooler is even likely to outlast the system it cools. Easy-bend flexible tubing allows the KÜHLER H2O 620 to be installed in nearly any orientation regardless of the internal configuration of the case. Finally, the KÜHLER H2O 620 comes with peace of mind in the form of an industry-leading Antec Quality 3 year limited warranty on parts and labour. Take your PC’s Quiet Computing™ to the next level with liquid cooling performance at a price that rivals aftermarket air coolers.
- CPU Socket Compatibility: Intel LGA 775, 1155, 1156, 1366, AMD AM2, AM3, AM2+, AM3+
- Low profile pump ensures exceptional liquid circulation while preserving internal airflow
- Easy-bend tubes for maximum flexibility in radiator positioning
- Intelligent noise / speed control fan for quiet, efficient cooling
- Latest generation copper cold plate for optimal conduction
- Cooling Liquid - Safe, environmentally-friendly, anti-corrosive
- Fan Speed: 1450 - 2000 RPM
- Tubing Length: 330 mm / 13.0"
- Radiator Dimensions: 151mm x 120mm x 27mm
- Fan Dimensions: 120 mm x 25 mm / 4.7" x 1.0"
- AQ3 - Antec Quality 3-year parts and labour warranty
Was £44.99 Inc. VAT
Only £40.98 inc VAT.
ORDER NOW
Antec Kúhler H2O 920 High Performance Liquid CPU Cooler (LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM2+/AM3+) @ £67.98 inc VAT
Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The dual 120 mm Pulse Width Modulation (PWM) fans and 3rd generation copper coldplate ensure quiet, efficient cooling, while the 49 mm radiator is equipped to handle the highest performing CPUs on the market. Lastly, the included software helps you monitor and control the
Kühler H2O 920’s performance and allows you to customize its stylish RGB LED. Designed to unlock the maximum potential of your CPU, the Antec KÜHLER H2O 920 delivers exceptional cooling when you need it the most.
- Customizable RGB LED for brilliant illumination
- CPU Socket: LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM2+/AM3+
- Fan Speed: 700 - 2400 RPM (PWM controlled)
- Radiator Dmensions: 151 x 120 x 49mm
- Fan Dimensions: 120 x 120 x 25mm
- Air Flow: 110 CFM
- 3 Year Warranty
Was £74.99 Inc. VAT
Only £67.98 inc VAT.
ORDER NOW
Creative Sound Blaster Tactic 3D Alpha @ £32.28 inc VAT
Experience the evolution of 3D gaming audio with the Sound Blaster Tactic3D Alpha gaming headset. Acoustically optimized 40mm drivers combine with THX TruStudio Pro technology to transform everyday audio into a mind-blowing cinematic experience. The dual mode design allows you to connect via standard mini jacks or use the Dual Mode adapter to connect to your PC or Mac's USB port for the full THX TruStudio Pro experience.
- Dual Mode – Analog or USB, your choice!
- THX TruStudio Pro technology
- TacticControl Tailor your sound with touch screen controls
- Customise and share optimized audio settings
- Have fun with your gaming voice
- Effortless communication with your team-mates
- Works perfect with VOIP applications such as skype / Windows live
- 1 year limited warranty
Was £32.99 Inc. VAT
Only £32.28 inc VAT.
ORDER NOW
SpeedLink Medusa NX USB 5.1 v2 Surround Headset @ £46.98 inc VAT
Enjoy brilliant trebles, feel the intensive bass - and accurately pinpoint sounds: the Medusa NX USB 5.1 Gaming Headset delivers the finest sound quality plus the eight integrated driver units and subwoofer allow you to determine precisely where the sounds are coming from - a decisive advantage in 3D games. The integrated USB soundcard makes it quick and easy to connect the headset, plus the Medusa NX USB 5.1's low weight and comfortable padding offers maximum comfort - making it the first choice for long gaming sessions.
- Flexible noise-cancelling microphone
- Breathtaking sound quality
- USB connector
- 8 driver units for realistic surround sound
- Integrated 5.1 soundcard
- Real 5.1 surround sound gaming headset
- Weight: 848g
- Packaging Dimensions: 235 (W) x 300 (H) x 100 (D) mm
Was £52.98 Inc. VAT
Only £46.98 inc VAT.
ORDER NOW
Speedlink Triton Stereo Gaming Headset @ £21.59 inc VAT
The headset of professionals. The outstanding sound quality and noise isolation performance make the Triton Stereo Headset an expert piece of kit when it comes to sound. Thanks to the highly sensitive microphone, which can be discreetly positioned in-line with the headband when not in use, you can chat with ease via the internet. At the same time, you'll enjoy many hours of fatigue-free sound thanks to the soft material and perfect-fit earcup design.
Features:
- Rugged PC headset with outstanding sound quality
- Especially sensitive microphone which can be discreetly positioned out of the way when not in use
- Compact in-line remote featuring microphone mute switch, volume control and clip
- Total noise isolation and a high level of comfort for extended use
- Lots of freedom of movement thanks to the 2.5m cable
Was £24.98 Inc. VAT
Only £21.59 inc VAT.
ORDER NOW
Samsung SH-S222AL/RSMS 22x DVD±RW SATA Lightscribe ReWriter (Beige/Black/Silver) - Retail @ £18.98 inc VAT
Samsung's 22x Serial SATA DVD Writer supports powerful over speed performance which allows writing with the high speed of 22x on a low cost 16x media and now includes the Lightscribe Labelling function.
Write Speed
- DVD-R: 22x
- DVD-R: 22x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Was £20.99 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
BeQuiet Dark Rock Advanced CPU Cooler (Socket LGA 775 / 1155 / 1156 / 1366, AM2 / AM2+ / AM3 / 754 / 939 / 940) @ £39.98 inc VAT
The Be Quiet! Dark Rock Advanced combines maximum cooling efficiency with a pleasantly quiet operation. With an extremely low noise level, efficient cooling is provided for gaming, multimedia and CAD systems even at maximum processing power. This CPU cooler is enhanced by the high-quality materials used, as well as its attractive design.
- The single-tower layout with six heat pipes enables excellent heat dissipation within a small space
- The 120-mm SilentWings PWM fan guarantees the best ratio of cooling efficiency to noise level
- The wave-shaped contour of the cooling lamellas prevents noises and optimises the airflow
- The fan surfaces are coated in dark nickel
- The brushed, fully aluminium cover protects the cooling lamellas
- The stable backplate ensures a shockproof attachment, even when transporting the computer
- Extremely efficient up to more than 180 watt
- LGA 775 / 1155 / 1156 / 1366, AM2 / AM2+ / AM3 / 754 / 939 / 940
- Fan Noise: Upto 18.8dBA
- Air flow: upto 85.8 CFM
- PWM Controlled
Was £41.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
BeQuiet Shadow Rock Pro CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM3) @ £33.98 inc VAT
The decoupled 120mm Shadow Wings PWM fan (SR1) / 135 mm Shadow Wings PWM fan (TopFlow) guarantees the best relationship between cooling effect and audible noise. The wave-shaped contours of cooling fins minimize noise and optimize air flow.
Four heatpipes transport heat via the shortest path to the optimal point within the cooling fins. The Single-Fin layout is a compact means to attain the best heat dissipation from every individual cooling fin whereas the TopFlow cooler layout provides optimal cooling for the CPU as well as for nearby system components. Completely nickel plated heat sink. The stable backplate ensures vibration-secure attachment, even when
- Number of heatpipes: 4
- Dimensions (incl. fan): 122 x 158 x 95 mm
- 1 x Shadow Wind PWM Fan inculded
- Weight (incl. fan): 740 gram
- Fan Dimensions: 120 x 120 x 75mm
- Fan Speed: 1700 RPM
- Noise Levels: 7.8 - 21.4dBA
- Air Flow: 57.2 CFM
- 4 pin PWM connection
- Black Plate Mounting Included
- 3 Year Warranty
Was £36.98 Inc. VAT
Only £33.98 inc VAT.
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £155.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £164.99 Inc. VAT
Only £155.99 inc VAT.
ORDER NOW
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail @ £47.99 inc VAT
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.00Ghz clock speed (AM3 Socket)
- Multiplier unlocked
- 2.0MB L2 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- 3yr Warranty
- Retail Boxed with Heatsink & Fan
Was £49.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
AMD Athlon II X3 Tri Core 455 3.30GHz (Socket AM3) - Retail @ £59.99 inc VAT
At home or at play, AMD Athlon II processors let you both do more of the things you want to do in less time and enhance your digital life at the right price, with energy-efficient, multi-core performance.
- Tri Core Technology
- 3.30GHz Clock Speed
- AM3 Socket
- 3x 512KB L2 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £61.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail @ £99.98 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.40GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (125W Edition)
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Was £109.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 975 Black Edition "125W Edition" 3.60GHz (Socket AM3) - Retail @ £119.99 inc VAT
- 3.60GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (140W Edition)
Was £124.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1055T "95W Edition" 2.80GHz (Socket AM3) - Retail with FREE Deus Ex PC Game @ £113.99 inc VAT
Six-core processing power for massive performance headroom - at the price of the competition's quad-core products. The AMD Phenom II X6 processor features AMD Turbo CORE technology that enables unlocked performance for cutting-edge applications, and dynamically switches to three cores for raw speed. Direct Connect Architecture that enables leading-edge performance and responsiveness, even on the most demanding applications. HyperTransport 3.0 Technology enables incredible system agility for 3D gaming and ultra-high resolution entertainment. AMD Dedicated Multi-cache that extends the memory bandwidth for intensive applications, delivering fast performance per core.
- Six Core Technology
- 2.80GHz Clock Speed
- 4.0 GT/s System Bus
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- Low Power 95W Edition
- 3 Year Warranty
- Deus Ex: Human Revolution FREE download code. Only on orders placed on 22/09/2011 onwards.
Only £113.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-8 Eight Core 8120 Black Edition 3.10Ghz (Socket AM3+) Processor - Retail @ £161.99 inc VAT
We call it the new AMD FX 8-Core Processor Black Edition and it's unlocked for your overclocking pleasure.1 Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Multiplier Unlocked
- Eight Core Technology
- 3.10GHz Clock Speed
- 4.00GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 125W
- Voltage: 0.975v - 1.4125v
- 32nm technology
- Integrated memory controller upto 29.8GB/sec
- Support upto 1866MHz DDR3
- 3 Year Warranty
Was £173.99 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (CMZ16GX3M4A1600C9) @ £77.99 inc VAT
CORSAIR high performance Vengeance memory module 16GB (4x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each four module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 16384 Megabytes of DDR3 memory
- Four matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £99.98 Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) @ £47.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- Lifetime Warranty
Was £53.99 Inc. VAT
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C8) @ £53.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 8-8-8-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- Lifetime Warranty
Was £67.99 Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) @ £41.99 inc VAT
This 8GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Was £49.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
Crucial Ballistix Elite 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLE2CP2G3D1608CE1TX0CEU) @ £33.59 inc VAT
'Designed specifically for computer gamers and power users seeking maximum seeking maximum system performance and stability, the Crucial Ballistix high performance memory line features advanced speed grades, low latencies, and integrated aluminium heat spreaders. With Ballistix memory, you can push the performance envelope.
- Black PCB
- Black high performance ALU heatspreaders
- Ultimate performance memory
- Elite heat spreader for performance
- 4096 Megabytes of DDR3 memory
- Two matched 2GB modules
- Lifetime Warranty
- Bulldozer compatible
Was £35.99 Inc. VAT
Only £33.59 inc VAT.
ORDER NOW
G.Skill RipJawsX 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-8GBXL ) @ £38.39 inc VAT
G.Skill has announced the development of its brand new RipjawsX series memory modules, designed specifically for Intel Sandy Bridge LGA1155 processors, and H67 and P67 motherboard platforms. The new RipjawsX series consists of a complete range of memory solution, from DDR3 1,333MHz, 1,600MHz, 1,866MHz, 2,133MHz, 2,200MHz to 2,300MHz. Combined with the Intel’s highly anticipated Sandy Bridge platform, G.Skill RipjawsX series memory kits deliver more bandwidth and performance than ever.
Building on the strong success of the first generation Ripjaws brand in performance memory kits, every single RipjawsX memory kit is hand-tested on an Intel Sandy Bridge platform in accordance with G.Skill's strict internal testing procedure, to ensure the best in class performance, compatibility and reliability across a range of popular motherboards. It is the perfect memory solution for PC gamers, performance workstations, enthusiast power users and anyone who loves the cutting-edge of technology!The following list shows the detail specifications of G.Skill RipjawsX family.
Model Name: F3-12800CL9D-8GBXL
Main Board: INTEL
ystem: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-24 2N
Capacity: 8GB (4GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.5V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was £43.99 Inc. VAT
Only £38.39 inc VAT.
ORDER NOW
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) @ £20.39 inc VAT
Kingston® proudly introduces HyperX® blu, a new line of reliable memory ideal for the entry level gamer or PC enthusiast.
HyperX blu features a new streamlined clipless design. Its heatspreaders provide thermal performance at an improved price point.
- Kingston Hyper-X Blu KHX1600C9AD3B1K2/4G
- 4GB Kit - 2x 2GB Modules
- DDR3-1600
- CL9
- 1.5v
- 240pin
Was £23.99 Inc. VAT
Only £20.39 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit (OCZ3G1333LV4GK) @ £22.79 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.55-1.65 Volts
- 240 Pin DIMM
Was £25.99 Inc. VAT
Only £22.79 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6950 IceQ X PLUS Edition 2048MB GDDR5 PCI-Express Graphics Card **Supplied with Battlefield 3, Dirt 3 & Deus Ex PC Games** @ £215.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Special IceQ Cooler taken from 6970 and custom fitted to 6950 by HIS for upto 18c better cooling
- Great OC Potential
- OcUK Exclusive
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Battlefield 3, Dirt 3 and Deus Ex PC Games
Was £229.99 Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6950 OC Twin FrozR III Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £218.39 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/PowerEdition.jpg" alt="Power Edition" /><br>
<br>
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a. <br>
<br>
<Font size="4"><b>Key Features</b><br></font>
<b>Propeller Blade Technology</b><br>
- MSI’s exclusive innovation design.<br>
- 20% more airflow.<br>
- Cool down more components on the PCB.<br>
- 11C cooler and 13.9dB quieter than reference HD 6950.<br>
<br>
<b>Power Edition Architecture</b><br>
- 6+2 Phase PWM Design<br>
1. Higher current to GPU Power.<br>
2. Higher overclocking capability.<br>
3. Better stability in peak load.<br>
<br>
<b>Triple Over-Voltage Function </b><br>
1. Support voltage adjustment of GPU, memory & VDDCI.<br>
2. Unleash GPU performance totally.<br>
<br>
<b>MSI Afterburner overclocking utility </b><br>
1. Supports advanced fan speed control.<br>
2. Supports burn-in stability test. <br>
<br>
<b>MSI Exclusive P/S Switch Function</b><br>
- Two fan speed profiles - Performance / Silence<br>
- Performance Mode provides best cooling demand; Silent Mode balances noise and GPU Temperature<br>
<br>
<Font size="4"><b>Specification</b><br></font>
- Core Clock: 850MHz<br>
- Memory: 2048MB GDDR5<br>
- Memory Clock: 5200MHz (Effective)<br>
- Processing Cores: 1408<br>
- Texture Units: 88<br>
- ROPS: 32<br>
- Bus Type: PCI-Express 2.1<br>
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort<br>
- HDCP Capable<br>
- DirectX 11 Support<br>
- Shader Model 5.0 Support<br>
- OpenGL 4.0 Support<br>
- ATI CrossFire Ready<br>
- ATI Eyefinity Technology<br>
- ATI Avivo HD<br>
- ATI Stream Technology<br>
- ATI HD3D Technology<br>
- Maximum Power Consumption: 250W (Typical 190W)<br>
- 2x 6pin PCI-E power connectors required<br>
- 450W minimum PSU recommended<br>
- Warranty: 3 Years<br>
Was £239.99 Inc. VAT
Only £218.39 inc VAT.
ORDER NOW
OcUK ATI Radeon 6970 2048MB GDDR5 PCI-Express Graphics Card @ £257.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 1x 8pin and 1x 6pin PCI-E power connectors required
- 500W minimum PSU recommended
- Warranty: 2 Years
Was £269.99 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 "Dual Fan Edition" 2048MB GDDR5 PCI-Express Graphics Card @ £209.99 inc VAT
The SAPPHIRE HD 6950 Dirt3 Special Edition is a new SAPPHIRE original model with a special cooler using a new dual fan configuration. Based on the latest high end AMD GPU architecture, it boasts true DX 11 capability and the powerful configuration of 1408 stream processors and 88 texture processing units. With its clock speed of 800MHz for the core and 2GB of the latest GDDR5 memory running at 1250Mhz (5 Gb/sec effective), this model speeds through even the most demanding applications for a smooth and detail packed experience.
A Dual BIOS feature allows enthusiasts to experiment with alternative BIOS settings and performance can be further enhanced with the SAPPHIRE overclocking tool, TriXX, available as a free download from http://www.sapphiretech.com/ssc/TriXX/
Features:-
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1 x Dual-Link DVI-I, 1 x Single-Link DVI-D, 1 x HDMI, 1 x DisplayPort
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters Provided)
- Warranty: 2 Years
Was £224.99 Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6850 Cyclone Power Edition 1024MB GDDR5 PCI-Express Graphics Card @ £113.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 6800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Boost up to 50%* higher with MSI exclusive Voltage Tweak
- Core Clock: 860MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4400MHz (Effective)
- Processing Cores: 960
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 3 Years
Was £119.99 Inc. VAT
ORDER NOW
HIS ATI Radeon HD 6770 1024MB GDDR5 PCI-Express Graphics Card @ £76.79 inc VAT
Now, more people than ever can experience real innovation in DirectX® 11 gaming with AMD Radeon™ HD 6770 Graphics. Expand your visual real estate across up to five displays and get lost in the action with AMD Eyefinity multi-display technology. Using AMD App Acceleration, speed up everyday applications and do more than ever with your PC. Loaded with advanced technologies, these GPUs have the power and premium features needed for fully immersive gameplay.
Features:-
- Memory Clock: 4800MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 800
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI 1.4a & 1x DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £89.99 Inc. VAT
Only £76.79 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6770 IceQ X Turbo 1024MB GDDR5 PCI-Express Graphics Card @ £89.99 inc VAT
Features:-
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £99.98 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX580 DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 782MHz (reference 772MHz), allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX580 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX580 DCII/2DIS/1536MD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Voltage Tweak Technology
- Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
- Gamer OSD: Real-time overclocking, benchmarking and video capturing in any PC game!
- Splendid: Watching movies on PC is as good as on Top-of-the-line consumer television
- Core Clock: 782MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
Was £389.99 Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 Matrix Platinum 1536MB GDDR5 PCI-Express Graphics Card @ £395.99 inc VAT
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
TweakIt provides users with flexible overclocking control even when running benchmark programs! The “+” and “-” button puts overvolting adjustments in the user´s fingertips, offering them performance optimization options during game play to gain the competitive edge.
ProbeIt takes the guesswork out of locating the graphics card´s measurement points, identifying them clearly in the form of 6 sets of detection points so you´ll know exactly where to get quick yet accurate readings using a multimeter.
Safe Mode button resets the graphics card back to default frequencies & BIOS. This is a very welcomed feature for hardware enthusiasts, think of it like the "Clear CMOS" on a motherboard.
Built with exclusive 19-phase Super Alloy Power technology, the MATRIX GTX 580 guarantees much greater overclocking headroom, with a 15% performance boost, 2.5 times longer lifespan and 35°C cooler operation than the reference card design.
Cooling is well taken care of by exclusive DirectCU II technology that puts copper heat pipes in direct contact with the GPU. The pipes efficiently transfer heat through two massive fans that deliver 600% more airflow than the reference design, resulting in a 20% lower operating temperatures.
A multicolored LED MATRIX indicator at the rear of the ROG MATRIX GTX 580 gives an instant and easy-to-understand visual display of the current GPU load.
Features:-
- Overclocking hardware tools, TweakIt and ProbeIt are directly embedded onto the graphics card firmware, while a Safe Mode button offers an easy reset option worry-free hardware overclocking.
- All new GPU Tweak provides professional graphics overclocking for PC enthusiasts
- 19-phase Super Alloy Power technology provides more headroom for overclocking with a 15% performance boost, reduced running temperatures and prolonged product lifespan
- Award-winning DirectCU II thermal technology with sound-dampened dual fans provides 600% greater airflow and 20% cooler performance than the reference design.
- Core Clock: 816MHz (Fermi GF110) (Upto 950MHz core possible)
- Shader Clock: 1632MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters), 1x DisplayPort.
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was £409.99 Inc. VAT
Only £395.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 580 SuperClocked w/Backplate 1536MB GDDR5 PCI-Express Graphics Card @ £383.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 797MHz (Fermi GF110)
- Memory Clock: 4050MHz (Effective)
- Shader Clock: 1594MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 10 Years (Requires registration within 30 days with EVGA)
Was £399.98 Inc. VAT
Only £383.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 580 3072MB GDDR5 PCI-Express Graphics Card @ £443.99 inc VAT
Features:-
- Core Clock: 772MHz (Fermi GF110)
- Memory: 3072MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
Was £479.99 Inc. VAT
Only £443.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 570 HD 2560MB GDDR5 PCI-Express Graphics Card @ £317.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 732MHz
- Memory: 2560MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1464MHz
- DisplayPort 1.1a connector included
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £329.99 Inc. VAT
Only £317.99 inc VAT.
ORDER NOW
MSI GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
Features:-
- Memory: 1280MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £249.98 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 560Ti 2048MB GDDR5 PCI-Express Graphics Card @ £221.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
Features:-
- Core Clock: 822MHz
- Memory Clock: 4000MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1645MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Only £221.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 560Ti 2048MB GDDR5 PCI-Express Graphics Card @ £196.79 inc VAT
Features:-
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was £199.99 Inc. VAT
Only £196.79 inc VAT.
ORDER NOW
Dell UltraSharp U2312HM 23" Widescreen LED Monitor - Midnight Grey @ £199.99 inc VAT
See vivid imagery from almost any angle. The 23” Dell UltraSharp U2312HM monitor with LED offers a brilliant view, rich colors and adjustable height options.
- Lose yourself in the details: : Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding color consistency across a wide viewing range.
- Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
- Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
DISPLAY
Panel Size: 58.42 cm
Aspect Ratio: Widescreen (16:9)
Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
Optimal Resolution: Full HD resolution, 1920 x 1080 at 60 Hz
Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Dynamic Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Brightness: 300 cd/m2 (typical)
Response Time: 8ms (gray to gray)
Viewing Angle: (178° vertical / 178° horizontal)
Color Support: Color Gamut(typical):82%(CIE 1976)4
Color Depth: 16.7 million colors
Pixel Pitch:0.265mm
Diagonal Viewable Size:58.42 cm
23 inches (23-inch wide viewable image size)
Preset Display Area ( H x V): 509.2 mm x 286.4mm, 20.04" x 11.28"
Backlight Technology: LED
CONNECTIVITY
1 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort (DP)
1 Video Graphics Array (VGA)
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
DC power connector for Dell Soundbar
COLOR, SIZE AND WEIGHT
Dimensions with stand (H x W x D):365.0 mm(compressed) ~ 493.0 mm(extended) x 546.4 mm x 185.4 mm, 14.37 inches (compressed) ~19.44 inches(extended) x 21.51 inches x 7.30 inches
Dimensions without stand (H x W x D): 323.3mm x 546.4 mm x 59.5 mm, 12.73 inches x 21.51 inches x 2.34 inches
Weight (panel only - for VESA mount): 2.96 kg, 6.53 lbs
Weight (with packaging): 6.47kg,14.26 lbs
Specifications - Service / Support Details: 3-Year Advanced Exchange1 Service and Premium Panel Guarantee
Was £219.98 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Samsung S23A750D 23" 120Hz 3D Widescreen Ultra Thin LED Monitor - Glossy Black @ £377.99 inc VAT
Samsung’s 750 and 950 series 3D desktop 3D monitors feature high refresh rate, incredibly thin bezel and stylish design. These monitors are able to analyze and render 2D content in real-time to 3D, supporting PC content, Blu-ray films and gaming consoles. The monitors feature a built-in glasses sync emitter, and they are packaged with a pair of 3D active shutter glasses.
Viewers will experience deep, rich colours and image clarity with Samsung’s new Ultra Clear Panel technology, which combines the vibrancy of a glossy display while maintaining the ease of viewing afforded by an anti-glare matte finish. The LED-backlit panel boasts 100% sRGB coverage to produce realistic colour reproduction.
Features:-
- 3D Active Glasses are included
- TRUE 120Hz
- 2D - 3D Conversion technology
- Screen Size: 23" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000000:1
- Brightness: 300cd/m²
- Response Time: 2ms (2D) / 2ms (3D)
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x HDMI, 1x DisplayPort
- Warranty: 3 Years On-Site
Only £377.99 inc VAT.
ORDER NOW
Dell UltraSharp U2412M 24" Widescreen LED Monitor - Midnight Grey @ £275.99 inc VAT
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style. Powerful:
- Experience IPS technology, featuring a wide viewing angle with high-quality color representation for a peerless viewing experience.
- Flexible: Pick the view that works best for you with an almost unlimited range of tilt, swivel, pivot and height adjustments.
- Customizable: Change your energy usage settings, text brightness and color temperature with the touch of a button to help conserve energy with this eco-designed arsenic-free and mercury-free panel.
Whether for work or for play, the Dell UltraSharpTM U2412M can deliver an unmatched viewing experience.
- Clearly outstanding: Watch your graphics come to life on a vast 24" (61cm) LED-backlit screen featuring a crystal-clear 1920x1200 resolution on a 16:10 widescreen aspect ratio so you can’t lose screen area just because your customized applications support a different resolution.
- Contrasting view: Get ready for blur-free viewing with 2 million:1 (typical) high dynamic contrast ratio and 8ms with overdrive gray-to-gray (typical) response time that helps ensure crisp, sharp and ghost-free images.
- Colorful character: Enjoy an amazing range of rich, dramatic and accurate colors, thanks to IPS technology designed to give you color consistency across a broad viewing angle and a wide color gamut at 82% (typical).
- Premium Panel Guarantee: 100% replacement of Dell UltraSharp series monitors sold if any bright pixel is found, valid within the warranty1 period.
Specification:-
- 24" (60.96 cm) viewable area
- Widescreen (16:10)
- Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
- 1920 x 1200 at 60 Hz
- 1000 : 1 (typical)
- 2,000,000:1 (dynamic)
- 300 cd/m2 (typical)
- 8ms (gray to gray) Typical
- 178º / 178º
- 16.7 million colors
- Color Gamut: 82% (CIE 1976)
- 0.27 mm
- 1x Digital Visual Interface connectors (DVI-D) with HDCP
- 1x DisplayPort(DP)
- 1x Video Graphics Array (VGA)
- 1x USB 2.0 upstream port
- 4x USB 2.0 downstream ports
- DC power connector for Dell Soundbar
- Height-adjustable stand, tilt , swivel , pivot and built in cable-management
- Flat Panel Mount Interface
- VESA Mount
- Warranty: 3 Years On-Site (Dell Premium Guarantee - You will receive a replacement UltraSharp monitor should even one bright defective pixel appear on the screen)
Was £299.99 Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Dell UltraSharp U2410 24" Widescreen LCD Monitor - Midnight Grey @ £431.99 inc VAT
Experience astounding colour accuracy, precision and performance with the Dell UltraSharp U2410 Monitor. The U2410 is packed with features that make it easy to connect and a pleasure to use, no matter how much screen time you log including Picture-in-Picture, adjustable stand, touch controls and extensive connectivity. Thanks to PremierColor technology, the U2410 Monitor delivers reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. A colour gamut of 110% delivers vibrant, true-to life colour across all display modes.
- Screen Size: 24" IPS Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 80000:1
- Brightness: 400cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Component, 1x Composite, 1x VGA, 1x DisplayPort, 2x DVI-D & 1x HDMI
- Adjustable Stand
- VESA Compliant
- Dimensions: 559.7mm x 493.0mm x 201.5mm
Was £455.99 Inc. VAT
Only £431.99 inc VAT.
ORDER NOW
Dell UltraSharp U2711 27" Widescreen LCD Monitor - Midnight Grey @ £623.99 inc VAT
With its amazing colour accuracy and versatile connectivity, the high-performance Dell U2711 Monitor delivers stunning detail, depth and responsiveness. PremierColour technology allows the Dell U2711 Monitor to deliver reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. Factory-tuned Adobe RGB and sRGB modes minimize the need for further colour calibration; each monitor arrives with a certified colour-calibration factory report. 100% sRGB and 96% AdobeRGB meets the needs of professional users involved in colour-centric work such as graphic design, CAD/CAM, gaming and media creation.Customize your viewing experience with the height-adjustable stand and tilt/swivel features - or save valuable desktop space by detaching the panel from the stand for wall mounting.
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Brightness: 350cd/m²
- Inputs: 1x Analogue, 2x DVI-D, 1x HDMI, 1x DisplayPort, 1x Composite & 1x Component
- 4-Port USB Hub
- 8-in-1 Card Reader
- VESA Compliant
- Dimensions: 646.71mm x 427.83mm x 199.95mm
- Weight: 7.72kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
Was £635.99 Inc. VAT
Only £623.99 inc VAT.
ORDER NOW
Dell Ultrasharp U3011 30" Widescreen LCD Monitor - Midnight Grey @ £958.80 inc VAT
Experience amazing wide-angle viewing and color consistency with the DellTM UltraSharpTM U3011 30"W Monitor with PremierColor. Extensive connectivity features and customization via CustomColor mode make the U3011 an ideal choice for professionals in CAD/CAM, graphic design, gaming and other fields where color precision matters.
Features:-
- IPS (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- 117% (CIE 1976) color gamut with excellent AdobeRGB and sRGB coverage for rich, lifelike visuals
- Easy, versatile adjustability and some of the latest connectivity options, including HDMI, DisplayPort, DVI-D, USB ports and a 7-in-1 media card reader
Specification:-
- 30" Widescreen
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1.07 Billion Colours
- 100,000:1 Contrast Ratio
- 7ms Response Time (7ms Grey-TO-Grey)
- 370 cd/m2 Brightness
- Two DVI-D Input with HDCP support
- Two HDMI Input
- One Display Port Input
- One Analogue Input
- Component Connectors
- Height adjustable stand, tilt and swivel (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
Was £999.00 Inc. VAT
Only £958.80 inc VAT.
ORDER NOW
Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black @ £239.99 inc VAT
The Hanns.G 27.5" has an industry ultra-fast 3ms response time making it perfect for blur-free video and gaming. With it's 15000:1 contrast ratio and excellent viewing angles there is no other TFT that can match the combination of quality, value and performance. Making the large screen affordable to all this 27.5" is ideal for gamers and home cinema use due to its huge size and 1920x1200 resolution.
- Screen Size: 27.5" Widescreen
- Contrast Ratio: 15000:1
- Response Time: 3ms
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 653.0mm x 523.0mm x 254.0mm
- Weight: 8.5kg
ORDER NOW
Samsung S27A750D 27" 120Hz 3D Widescreen Ultra Thin LED Monitor - Glossy Black @ £503.99 inc VAT
Features:-
- TRUE 120Hz
- Screen Size: 27" Widescreen
Was £529.99 Inc. VAT
Only £503.99 inc VAT.
ORDER NOW
Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB Cache - OEM (0F10383) @ £97.99 inc VAT
The Deskstar 7K1000.C hard drive is a 7200RPM 3.5" hard drive that provides an exceptional blend of power efficiency and performance, making it an ideal solution for power friendly consumer and commercial desktop computers. This third-generation 1TB hard drive from Hitachi boosts media transfer rate performance by as much as 13% over its predecessor. Leveraging eighth-generation power management technology, as well as power-saving HiVERT innovations pioneered on the popular 2.5" line of notebook hard drives from Hitachi, this new desktop drive provides up to 18% idle power savings over the previous model, delivering best-in-class power management and thermal emissions.
- Capacity: 1TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Warranty: 2 Years
Only £97.99 inc VAT.
ORDER NOW
Creative Sound Blaster X-Fi Xtreme Audio 7.1 Sound Card - OEM (PCI-Express) (30SB104200000) @ £29.99 inc VAT
Upgrade your new PC to award-winning Sound Blaster X-Fi Xtreme Fidelity audio! Creative's Sound Blaster X-Fi Xtreme Audio PCI Express transforms MP3 music and movies over headphones or surround sound speakers. X-Fi Crystalizer restores the details and vibrancy lost during MP3 and DivX compression, breathing life back into any audio. X-Fi CMSS-3D expands stereo music and movie sound tracks into amazing surround sound even over regular headphones, with OpenAL and EAX 4.0 support for enhanced gaming. The perfect addition to PCI Express-ready PCs, this Windows Vista compliant card features extended connectivity thanks to its integrated digital optical input and output.
- Full height Windows Vista compliant PCI Express card for the latest desktop PCs.
- X-Fi 24-bit Crystalizer restores the details and vibrancy lost during audio compression, enhancing MP3/WMA music, DivX movies, TV and radio.
- X-Fi CMSS-3D Surround up-mixes MP3 audio to 5.1 or 7.1 surround. X-Fi CMSS-3D Headphone delivers incredible surround sound for movies and music over stereo headphones.
- Free download of Cyberlink's PowerDVD software with DTS® and Dolby Digital®-EX decoding for the ultimate in DVD movies. Enjoy immersive gaming over headphones with OpenAL and EAX 4.0 support.
- Entertainment Console gives easy setup and control.
- Comprehensive connectivity includes an integrated digital optical input and output.
Was £35.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Creative HS-400 Headset (51MZ0235AA007) @ £14.40 inc VAT
The HS-400 headset with noise-cancelling microphone is the right choice for internet voice applications or gaming. It delivers great audio over its headphones, for enhanced gaming pleasure, while users who demand the power of broadband telephony or voice conferencing will appreciate the advanced microphone, which automatically cancels-out background noise and has a rotary design which ensures a comfortable fit. It can also be detached easily when required. Lightweight and comfortable, the HS400 combines style, features and performance.
- Microphone can be detached for gaming and audio use.
- Rotary design makes microphone exceptionally comfortable.
- 30mm Neodymium magnet drivers give good results in gaming and audio.
- Oxygen-free copper cable for enhanced frequency response.
- Gold-plated stereo miniplugs for better connections.
- Stylish design stays comfortable for hours.
Was £14.98 Inc. VAT
Only £14.40 inc VAT.
ORDER NOW
Anidees AI-6BW Midi-Tower Windowed Case - Black @ £112.98 inc VAT
The AI-6 gives an immediately clear first impression of quality and elegance. The Front cover shows a fairly large unit which houses a plastic exterior and with a brushed aluminum centre. In between lie, a set of stealthy, and concealed air vents, which should ensure good cooling.
This look is made possible through a closed front door, which is open when delivered to the left, this can be switched by the user to the right if required. If you open it, one sees a rectangular mesh field in the lower and upper area. The drive bays are provided by three 5.25-inch apertures. For each of them they can be cut away in order to push through an external 3.5-inch device.
Although only an adapter factory setting of one of three 5.25-inch slots at Al-6 is, but those frames can be conveniently buy more if needed. The lid of the clear line is continued by the I/O panel which is inserted inconspicuously. Two USB 3.0 ports that are present in addition to audio connectors and four USB 2.0 and are connected internally.
Under the removable cover part you will find a very good mesh surface, which ensures that a radiator with a size of up to 280 mm which can optimally cool with a good deliver fresh air. Alternatively, it is also just two 140s or 120s fan positioned there. The same applies to the front, where two fans of both formats can be accommodated, while the rear has only one 120-mm fan space.
- Windowed Edition
- Dimensions: 207 x 509 x 527 mm (W x H x D)
- Material: steel, aluminum
- Weight: 11 kg
- Color: Black
- Form Factor: ATX, Micro ATX, Mini-ITX
- Front Cooling: 1x 140 / 120 mm (front, 120 mm optional)
- Rear Cooling: 1x 120 mm (rear) / 1x 140 / 120 mm (front optional)
- Top Cooling: 2x 140 / 120 mm (lid, optional)
- Filters: Front & Back
- Drive bays: 3 x 5.25 inches (external) / 1 x 3.5 inches (external, instead of 1x 5.25 inch) / 7 x 3.5 inch / 2.5 inch (internal)
- Power Supply: Standard ATX 1x (optional)
- Expansion Slots: 8 (without tools)
- I / O Panel: 2x USB 3.0 / 4x USB 2.0 / 1x each Audio In / Out
- Maximum graphics card length: 428 mm
- Features: Elements made of brushed aluminum
- Cable Management
- HDD and power supply decoupling
- Removable hard disk cages
Only £112.98 inc VAT.
ORDER NOW
Anidees AI-6B Midi-Tower Case - Black @ £99.98 inc VAT
- Weight: 11 kg
- Color: Black
- Cable Management
ORDER NOW
Corsair Graphite 600TM Midi Tower Mesh Windowed Case - Black @ £129.98 inc VAT
nonl2brThe Graphite Series 600T is a mid-tower in height, but inside it’s positively cavernous. Easily accommodate even the longest graphics cards in the industry due to the reconfigurable hard drive bays. The increased space behind the motherboard tray allows clean, uncluttered cable routing. Up to six hard drive caddies, each of which can accommodate SSDs and standard mechanical disks, sit below the four 5.25" tool-free optical drive bays. If that weren’t enough, you can remove the top panel 200mm fan and install a 240mm radiator and dual 120mm fans for a quick watercooling upgrade.<br><br>
- Twin 200mm cooling fans with white LEDs for excellent cooling<br>
- Eight expansion slots provides you flexibility for multiple graphics card solutions<br>
- Unique cable routing holes guarantees you a clean and clutter-free installation<br>
- Integrated fan controller, for up to four fans, gives you the choice of noise vs. performance<br>
- Motherboard compatibility: ATX and MicroATX<br>
- Front I/O Ports: USB2.0 x 4, USB3.0 x 1, FireWire x 1, Audio x 2<br>
- Cooling: 2 x 200mm white LED fans <br>
- Tool-free optical drive installation makes building your system faster than ever<br>
- CPU backplate cutout makes upgrading your CPU heatsink easy<br>
- 2.5” and 3.5” hard drive compatibility for up to 6 drives — straight out of the box!<br>
- Two year warranty with Corsair’s world-class customer service and technical support<br>
<center>
<span id="ctl00_ctl00_cpBodyCode_cpSubBodyCode_lblHTML"><object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/L_XuntEjQS8&hl=en_GB&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/L_XuntEjQS8&hl=en_GB&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object></span>
</center>
Was £134.99 Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
Razer Megalodon Elite 7.1 Surround Sound USB Gaming Headset @ £116.39 inc VAT
The Razer Megalodon is a 7.1 Surround Sound Gaming Headset designed specifically to incorporate the Razer Maelstrom Audio Engine, making it the definitive headset for gamers today. Utilizing next generation HRTF technologies and a superb DSP with unheard of processing power, the Razer Megalodon is the most advanced audio headset of its kind.
- Frequency Response: 20 - 20,000 Hz
- Impedance: 32 O at 1kHz
- Sensitivity (@1kHz, 1V/Pa): 102 ± 4dB at 1 kHz
- Max. Input Power: 200 mW
- Drivers: 40 mm, with neodymium magnets
- Microphone
- Frequency Response: 50 - 16,000 Hz
- Sensitivity (-37 ± 4dB @1kHz, 1V/Pa): Variable (user adjustable)
- Signal-to-Noise Ratio: 50 dB
- Pick-up pattern: Unidirectional
- Audio Processing Unit
- Master volume, center speaker, front speakers, side speakers, rear speakers, bass level, mic sensitivity, mic leveling, mic mute, Razer Maelstrom on/off, active/standby toggle, reset
- Cable: 3.3 meters, Braided Fiber Sheath
- Connector: Gold-plated USB
Only £116.39 inc VAT.
ORDER NOW
TT Esports Gamers Headset Shock - Black @ £27.59 inc VAT
nonl2br
The TT Esports Gamers Headset Shock brings gaming to a new level. Immerse deeply into your games with 40mm speaker drivers and stereo surround sound. Take advantage of your soundcard with 3.5mm speaker jacks bringing maximum sound performance. The ultra comfortable padded earcups make sure that comfort is key, especially for intense professional gaming. <br><br>
- Stereo surround sound<br>
- Quality 40mm speaker driver with enhanced bass performance<br>
- Noise cancelling microphone for communciation in gaming activities<br>
- Control Box with In-line control box for instant gaming sound control<br>
- 10 Levels adjustment for a perfect fit<br>
- Foldable design<br>
- Gold plated 3.5mm connctor<br>
<br>
<br>
<iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/2gampqTGEf8" frameborder="0" allowfullscreen></iframe>
Was £29.99 Inc. VAT
Only £27.59 inc VAT.
ORDER NOW
XFX Pro 850W Core Edition '80 Plus Bronze' Power Supply @ £86.99 inc VAT
XFX PSUs are designed to deliver tight DC voltage regulation with minimal AC ripple, giving you safer, cleaner power which, along with XFX’s new EasyRail™ Technology allows you to connect numerous devices without worrying about running out of power before reaching the maximum wattage. EasyRail™ optimizes it all for you. Available in 650W, 750W and 850W, XFX ProSeriesPSUs with EasyRail™ Technology gives you one continuous rail of power covering the total maximum wattage. EasyRail™ Technology Provides Maximum Power Unique, continuous EasyRail™ technology enables you to maximize available power and makes set-up easy.
- Fixed FDD: 1
- Fixed Peripheral: 7
- Fixed 6+2-pin PCI-E: 2
- Fixed 6-pin PCI-E: 2
- Fixed ATX12V / EPS12V: One 4+4-pin
- Fixed Motherboard Connector: 20+4 Pin
- Fixed SATA: up to 11
Was £89.98 Inc. VAT
Only £86.99 inc VAT.
ORDER NOW
XFX 750W Black Edition Modular '80 Plus Silver' Power Supply @ £99.98 inc VAT
The XFX Black Edition 750 watt modular power supply gives you the power you need with a brilliant
combination of form and function. Giving more than just life to your PC, this power supply allows easy cable management with modular connectors which helps increase airflow. With tight voltage regulation and high efficiency operation up to 88% (80 Plus Silver) this power supply will give you exactly what you need to keep your gaming charged and ready.
-750W of continuous power at 50°C
- Tight voltage regulation (±3%)
- High efficiency operation up to 88% (80 Plus Silver)
- Single, high power +12V rail (up to 62A/744W)
- DC to DC voltage Regulator modules for +3.3V and +5V
- High quality Japanese brand capacitors (105°C)
- Solid polymer caps provide enhanced reliability and stability
- Quiet 135mm ball bearing fan provides superior cooling
- Supports multiple high-end graphic adapters (NVIDIA SLI & ATI CrossFire Ready)
- Supports the latest ATX12V and EPS12V standards
- Active PFC with Universal AC input
- Detachable modular cables
- Energy Star 4.0 and RoHS compliant
- 5-Year Limited Warranty, subject to registration
Was £104.99 Inc. VAT
ORDER NOW
Sennheiser PC 11 VOIP Headset @ £11.99 inc VAT
The PC 11 makes it easy to phone over the net with clear sound quality wherever you take your laptop – thanks to one-hand operation and an adjustable high-performance microphone. The
ultra-light and discreet on-ear design is not only comfortable, it also quickly stows away in a handbag or pocket. Key Features include: Speech clarity – adjustable, omni-directional microphone delivers clear conversations and flexibility. Light and comfortable – on-ear headset that is so light, you’ll almost forget you are wearing it. Flexible wearing – two ear-hooks give you the choice of wearing the headset on either your right or left ear. Easy to use – just insert the 3.5mm plugs into the microphone and headphone jacks on your desktop or laptop and you are ready for internet telephony. Internet telephony on any computer – for desktop PCs and laptops, on the road or at home. Peace of mind – thanks to the 2-year international warranty.
- Light and comfortable;
- Flexible wearing on right or left ear;
- Easy to use;
- Adjustable, omni-sirectional microphone delivers clear conversations;
- 2 Year Warranty
Was £12.59 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Logitech G400 3600DPI Gaming Mouse (910-002279) @ £27.98 inc VAT
Set your sights on victory. With a high-precision optical engine, the G400 gives you consistent tracking and precise aiming no matter how fast you move your hand.
Instant access to four dpi levels lets you shift from pixel-precise targeting to lightning-fast maneuvers. A sculpted comfort grip, low-friction feet and eight programmable buttons keep you comfortable and in command.
You've got the upper hand with precision targeting and pinpoint accuracy. Your mouse communicates over USB at a blazing-fast 1000 reports per second - as fast as USB can go, and eight times faster than standard USB mice.
- Weight: 133 g
- Connectivity Technology: USB
- Movement Detection Technology: Optical
- Buttons Qty: 8
- Movement Resolution: 3600 dpi
- Performance: 1 ms response time, 5.8 megapixels per second, realtime sensitivity switching 400 - 3600 dpi, 25 G maximum acceleration
- Features: Programmable buttons, sensitivity adjustment, polytetrafluoroethylene (PTFE) feet
- Cables Included: 1 x USB cable - integrated
- 3 years warranty
Was £29.99 Inc. VAT
Only £27.98 inc VAT.
ORDER NOW
Mionix Naos 5000 Gaming Mouse Laser 5040dpi Sensor @ £66.98 inc VAT
This prominent gaming mouse is named after the star Naos, a blue super giant and one of the brightest stars in our galaxy. Naos means “ship” and is enough powerful to create comet tails and huge clouds of auroras visible from Earth. Naos is constantly moving away from its original position in the constellation of Vela and it spins about 100 times faster than our sun. Since its birth it has covered a distance of 400 light-years. No one knows exactly why Naos has such a high rotation speed, but an explanation to this phenomenon lies in the gravitational interaction between many other stars.
A passionate hunt for perfection has come to an end. Mionix Naos 5000 has seen its first light of day. Get ready to meet a gaming mouse with an incredible ergonomic comfort and stunning technology that offers an outstanding gaming experience. Mionix Naos 5000 features a new innovative weight tuning system for an optimal weight distribution of the mouse, carefully selected high-end components and leading laser technology. Stunning features such as adjustable lift-distance, 5 onboard profiles, extensive macro settings and customizable LED-lights give you the opportunity to customize the mouse exactly to your liking.
- Balanced weight tuning system
- Seven programmable buttons
- Surface quality analyzer tool
- Customizable LED light system
- 128KB built-in memory
- 5040 DPI Laser sensor
- Truly ergonomic design
- Maximum grip: The rubber coating ensures a maximum grip
- Balanced weight tuning system: A unique weight tuning system for an optimal weight distribution
- 5040 dpi laser sensor: Remarkable tracking performance built for gaming
- S.Q.A.T™ - Surface Quality Analyzer Tool
- 3 steps customizable dpi in-game adjustment
- 7 programmable buttons
- In-game profile switch
- Adjustable polling rate
- Plug n Play
Was £69.98 Inc. VAT
Only £66.98 inc VAT.
ORDER NOW
Logitech C910 HD 1080p Pro 10 Megapixel Webcam (960-000598) @ £75.59 inc VAT
Individuals using the webcam to communicate with friends and business associates will benefit from its 720p video calls, 1080p HD recording and its ability to capture ten-megapixel stills. Sharing videos and images could not be easier with the Logitech HD Pro Webcam C910 (960-000598) due to its one-click Facebook upload feature, while its life-like audio quality could appeal to some customers. Users can enhance the security of the webcam by using its face recognition login feature, offering peace of mind and protection against unauthorised use. Meanwhile, Carl Zeiss optics combined with RightLight 2 technology and bundled Logitech video effects could make this device an even more appealing purchase for enthusiasts.
- Full HD 1080p video capture (up to 1920 X 1080 pixels) with recommended system*
- HD video calling (1280 x 720 pixels) with recommended system*
- Logitech More HD technology
- Carl Zeiss® optics with autofocus
- Photos: Up to 10 megapixels (software enhanced)
- Built-in mics with Logitech RightSound™ technology
- Hi-Speed USB 2.0 certified (recommended)
- Universal clip fits laptops, LCD or CRT monitors
- 2-year limited hardware warranty
Basic requirements:
- 1 GHz
- 512 MB RAM or more
- 200 MB hard drive space
- Internet connection
- USB 1.1 port (2.0 recommended)
- Windows® XP (SP2 or higher), Windows Vista® or Windows® 7 (32-bit or 64-bit)
For HD 720p video calling and Full HD 1080p video recording:
- 2.4 GHz Intel® Core™2 Duo
- 2 GB RAM
- USB 2.0 port
- 1 Mbps upload speed or higher
- 1280 x 720 screen resolution
Was £77.99 Inc. VAT
Only £75.59 inc VAT.
ORDER NOW
OcUK Value CA403 8.0 Mega Capture PC Camera @ £9.60 inc VAT
The superb OcUK Value webcam offers brilliant image quality at high resolution for a great price.
• USB2.0 Pixart UVC DSP chip and high analyze degree 1/6-inch CMOS Color sensor,High quality glass lens
• 2.Performance: plug & play in vista,xp2 system(driverless) ,300K pixels in hardware(optical),(up to 2.0M pixels for video and caputre,8.0M pixels for capture after use driver)
• Use driver on XP1,2000 system ,Snap capture (Max.): 3200*2400
• Image mode:160*120(QQVGA);176*144(QCIF);320*240(QVGA);352*288(CIF);Default 640*480(VGA);800*600(SVGA);1280*960(SXGA);1600*1200(UXGA);
• With face tracking,zoom in and out function,Digital zoom function,6 frame and 18 special effects by driver
• Frame rate: 640* 480 (VGA) mode up to 30 frames per second;1600*1200 upto 15 frames per second;
• USB2.0 format
• Supports Windows 2000/XP/Vista/7
• Supports Mac OS X: Above version 10.4.8
Was £9.98 Inc. VAT
Only £9.60 inc VAT.
ORDER NOW
Storage Options CCTV 500GB DVR 2+2 + Monitor @ £402.78 inc VAT
nonl2br
A 4 channel digital video recorder with pre-installed hard disk drive, designed to be used with the
Storage Options CCTV Range. Records in H.264, the latest compression technology, which gives
improved image quality and a longer recording time. Remote viewing is available as standard across your network or through the mobile phone/tablet application. Just add cameras for a complete security
solution.<br><br>
Storage Options offers a range of affordable CCTV Solutions for home or small business security. With a range of cameras, digital video recorders and other accessories, our aim is to offer high-quality products and service without the premium price.<br><br>
- 500GB hard disk drive installed<br>
- Real time Viewing/Recording of up to 4 CCTV Cameras <br>
- Easy Setup and Operation, Simple User Interface<br>
- H.264 Compression Technology Provides Higher Quality and Longer Recording Times<br>
- Simultaneous Viewing, Recording, Playback, Backup and Network Operation<br>
- Android TM and Apple® Applications for Mobile Devices Available<br>
- Compatible with Most Modern CCTV Cameras<br><br>
<b>Package Contents</b><br>
1x 17" LCD Monitor
1x Storage Options Digital Video Recorder<br>
2x Storage Options Indoor CCTV Camera<br>
2x Storage Options Outdoor CCTV Camera<br><br>
<b>Motion Detection</b><br>
The Storage Options CCTV system has built in, sophisticated software that can detect movement. If your camera spots movement it can trigger an event to record this to your hard drive, giving you peace of mind that your home or office is constantly being monitored & protected. Most users however will set it to record continuously, this feature is mostly used to save disk space as well as only record when movement is detected.<br><br>
<b>Flexibility…</b><br>
The Storage Options CCTV Camera range is designed to appeal as many different customers as possible, with options for different capacity hard drives & types of camera available you can expand your surveillance or change the type of application (e.g indoor to outdoor) just by replacing or adding cameras.<br><br>
e.g. – Customer purchases a 2 outdoor camera bundle for watching the drive & front door, he then decides he would like to watch the rear garden & also his home office…. No problem, just buy one indoor , one outdoor camera & connect using the provided cables – Instant upgrade! <br><br>
<b>Simple User Interface </b><br>
The User interface was designed with simplicity at its core, although it has many advanced functions. We wanted to ensure it was easy to set-up and get started, but also provides all the advanced features you could ever want should you need them. (e.g. Motion detection or privacy masking.)<br><br>
<b>Pentaplex</b> <br>
The Storage Options CCTV System is capable of performing multiple tasks at the same time, it can record, playback, live-view, back-up & network all simultaneously!! (Pentaplex) This ensures your property is still being protected regardless of what you are doing to the system, a great feature and one that ensures you never miss a thing.<br><br>
<b>Recording Time</b> <br>
The length of recording time is determined by 2 key factors, the size of the hard disk & number of cameras being used. Up to 400 days recording is possible. The device is smart too, it will alarm when the disk is full too. (this can then be re-formatted or removed for archive and a new drive fitted)<br><br>
<b>Time & Date Stamped Recordings </b><br>
Time & Date stamped recordings show you exactly when an event occurred, a feature needed should the recordings be used in any criminal investigations. Recordings are stored in date order too so it makes searching for the footage you need even easier. The recordings are grouped into manageable sized chunks for easier copying or backing up <br><br>
<b>Back-up Facility </b><br>
We recognise that at some point you will need quick access to footage stored on your DVR, and so to make it easier, we have included a handy USB port so you can plug in a USB Flash or Hard Disk Drive (HDD) and copy footage across to these devices – whether its just a short clip or a full back-up of your system should you wish to archive.
It’s as easy as selecting the Date range (from & to) and which cameras (one or even all) <br><br>
<b>Network </b><br>
Although this is an analogue CCTV solution, it has a killer feature in that it is network enabled. This feature means that if you connect it to your network you can view your system live from anywhere in the world on any internet connected PC, no need to install software. (Viewed through the web browser) <br><br>
Alternatively there are apps available for iPhone & Android for remote viewing also. You are never more than click away from viewing your home or business.
Was £409.98 Inc. VAT
Only £402.78 inc VAT.
ORDER NOW
Roccat Isku Illuminated Gaming Keyboard @ £59.99 inc VAT
nonl2brThe Isku is the world’s first keyboard to feature groundbreaking Easy Shift[+]™ technology, which puts 36 easily-customizable macros in 3 spots in the easy-to-find WASD zone -- so players can give a multitude of custom orders without ever having to re-adjust the hand position.<br>
Exclusive ROCCAT™ Talk© protocol lets the Isku and other ROCCAT™ TALK- enabled products, like the ROCCAT™ Kone[+] Max Customization Gaming Mouse, talk to each other – opening up a new world of Set Bonus gaming advantages. <br>
For example, this groundbreaking tech works great with Easy Shift[+]™ technology on compatible ROCCAT™ mice, letting gamers use the Isku Easy Shift[+]™ key to activate macros for both the keyboard and mouse – offering one-stop macro activation that lets gamers concentrate more on playing and less on controls. <br>
ROCCAT™ Talk© also allows gamers to take advantage of exclusive EasyAim technology like never before. When a game demands precise marksmanship in sniper mode, a player can simply press and hold a single keyboard key and EasyAim will instantly optimize the DPI setting on the ROCCAT™ Talk©-compatible mouse. <br>
New enhanced Macro Live! Recording makes in-game macro recording a joy. Gamers simply hit the dedicated Macro Live! Recording button and the Sound Feedback tool will talk them through the quick and easy recording process. Players can program up to an amazing 500 actions for each of the 180 possible macros – giving them freedom to lay down any orders they can dream up. <br>
Backlit with ROCCAT™ Extreme Ice Blue Lighting in 6 adjustable brightness levels, the Isku makes it easy to always hit the right key -- even in low lighting. The optimized illumination also means the Isku is perfect for avoiding eye strain during those long gaming sessions. Plus, gamers can program the Isku to automatically switch its lights off if a key hasn’t been hit for a predetermined time – great for a quick break.<br><br>
- Blue key illumination with 6 brightness levels including off setting<br>
- Easy Shift[+]. for simple key duplication and activation<br>
- 3 Easy Shift[+]. zones featuring 28 easy-to-reach macro keys, including 5 doubly-programmable dedicated M-keys and 3 doubly-programmable Thumbster Keys<br>
- Macro Live! recording button for in-game macro setting; 180+ macros in 5 profiles<br>
- 8 media & hotkeys; 25+ assignable functions<br>
- Medium-height keys; optimum keystroke; advanced anti-ghosting<br>
- ROCCAT. Driver & Macro Manager, incl. macro presets for games, multimedia & office apps<br>
- Integrated Extra-Large Granulated Wrist Rest with optimized surface texture<br>
- Cable channels for better device organization<br>
- Non-slip base with lock-on keyboard feet<br>
- Fast profile switching; 5 Profile-Status LEDs<br>
- ROCCAT. Talk: Set Bonus by combining devices<br>
<br>
<center><iframe width="560" height="345" src="http://www.youtube.com/embed/fFZ3yMnimp0" frameborder="0" allowfullscreen></iframe></center>
Was £76.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Storage Options DIY Home CCTV Kit 500GB DVR 2 Cam @ £168.00 inc VAT
Designed specifically for use and installation by those with no experience or prior knowledge of CCTV systems. DIY Home CCTV Kit with 500GB digital video recorder and 2 outdoor cameras. Includes a clear English manual and all the cabling, power supplies, fixings and everything else needed to secure a property. Capable of recording footage from up to 4 cameras simultaneously. Footage can also be viewed from a Smartphone with apps for Apple and Android available.
Key Features
• View on your Existing TV, Monitor or Smartphone
• Up to 50 Days Continuous Recording
• 2x Fully Weatherproof Cameras with Night Vision
• DIY Kit with All Fixtures, a Detailed Manual & Installation Guide Included
Why Install CCTV?
Installing this DIY Home CCTV Kit could be one of the best steps you ever take to secure your home or business premises. As well as protecting against criminal activity and actively deterring criminals from targeting your property and vehicles, it will bring additional peace of mind for you and your family.
Why Choose a Storage Options DIY Home CCTV Kit?
Designed specifically for use and installation by those with no experience or prior knowledge of CCTV systems, everything you need is contained in the box including a clear instruction manual. If you need additional help, our UK-based support team is available for the price of a local rate phone call.
Your CCTV Questions Answered
What is this kit?
This is a DIY Home CCTV Kit, which will allow you to setup and install a CCTV system in your home or small business.
What's Included in the Box?
• 2x outdoor, weatherproof, night vision cameras
• Digital video recorder (DVR)
• 2x 18.3m (60ft) power/video cables (to connect the cameras to the recorder)
• 1x power adapter
• 1x 5-way power splitter (for the DVR and up to 4 cameras)
• Remote control and a mouse to use with the DVR
• Instruction manual
• Wall fittings (screws and wall plugs)
What Else Will I Need to Use the Kit?
Almost everything you need is included but there are some obvious things to remember: You'll need something to view the footage on, either a TV or a computer monitor. A drill, drill bit and a screwdriver are needed to mount the cameras. Internet access is required to view footage on your smartphone and you will need a network cable to connect the DVR to your router.
Can I Add More Than 2 Cameras to the System?
Yes. The DVR included in this kit can record up to 4 cameras simultaneously. Spare cameras are available from Storage Options.
How Long Will the System Record for?
With 2 cameras attached, this kit will record continuously for 50 days. This time is reduced proportionately if a third (37 days) or fourth camera (25 days) is attached.
Can I View the Live Footage from the Cameras on my Smartphone?
Yes. With free Android and Apple apps available, you can now view CCTV footage directly on your smart phone. So even if you are miles away from your property you can still check all is well at home or work and if necessary, take immediate action. Apple app available from iTunes and Android app available from storageoptions.com.
Can the Cameras "See" in the Dark?
Yes, the cameras included in the kit have infrared night vision with a range of up to 10m (32ft). The system will record all events, even if you can't see them with your own eyes!
What if I Need Some Help Setting up or Using this Kit?
No problem. Our UK-based support team is available for the price of a local-rate phone call. Call us on 0844 248 7191 or email [email protected].
Is there a Warranty on this Kit?
This product is backed by a 12-month warranty in the unlikely event of something going wrong. Simply call our support line if you think there is a problem with your kit. More information is available at storageoptions.com
Was £169.99 Inc. VAT
Only £168.00 inc VAT.
ORDER NOW
Mionix Zibal 60 Mechanical Gaming Keyboard @ £139.98 inc VAT
The Mionix Zibal 60 is a fusion of the best keyboard components together with great gaming features that gives you the edge to your game. Engineered with non-tactile, mechanical, black cherry MX switches that deliver the best feel to every keystroke. Multi-level backlight illumination paired with six key rollover that allows you to perform up to six simultaneous keystrokes with all keys, make the Zibal 60 standout from the crowd. In addition to the performance features, the Zibal 60 offers smart functions that include a two port usb 2.0 hub, audio/mic extensions and media control keys for full integration with your desktop setup.
- Black Cherry MX Mechanical key switches
Mechanical non-tactile Cherry MX black switches with 18K Gold plated switch connectors ensures durability and longer life time.
- Comfortable design
Designed with a detachable wrist rest to be comfortable throughout long gaming sessions.
- Backlit key illumination
Every switch is fitted with a single green LED and you can choose from the three different lighting modes.
- Three lighting modes On, Off and WASD
Select between the three lighting modes On, Off and WASD.
- Multi-level brightness control
Three level adjustable brightness control.
- Mionix Action key
The Mionix Action key provides instant access to all the media and illumination functions.
- Six Key Rollover
Register up to six keystrokes simultaneously.
- Rage proof durability
Fends off rage blasts thanks to the 1.6 mm thick steel frame and heavy duty braided cable.
- Built to last
Lifespan of 50 million keystrokes and wear resistant laser printed keycaps
- Connect-through port for audio
Superior audio quality thanks to the insulated shielded cables
- Full speed USB 2.0 hub
Inbuilt with a two port USB 2.0 hub powered by its own USB cable.
- Plug n Play
Complete Plug n Play, all functions can be performed without any software or drivers.
Was £149.99 Inc. VAT
Only £139.98 inc VAT.
ORDER NOW
Swissgear Synergy 15.6" Backpack @ £53.58 inc VAT
nonl2br
<img src="http://www.ccidistribution.co.uk/images/manufacturers/wenger.jpg">
- Made by Wenger, makers of the genuine Swiss Army knife<br>
- CaseBase Stabilizing Platform<br>
- Air-Flow Back padding keeps your back cool even with a full pack<br>
- Essentials Orangiser<br><br>
Material: Poly, Nylon, PVC<br>
Size (DxWxH): 10” x 13” x 18” / 25.4 x 33 x 46 cm<br><br>
<b>Features :</b><br>
- Fits Most 15”/15.6” Notebooks<br>
- Made by WENGER, maker of the genuine Swiss Army Knife.<br>
- COMP-U-FLEX Computer Pocket<br>
- Lifetime Warranty<br>
- Shock Absorbing Shoulder Straps<br>
- iPod/Music Player Pocket<br>
- Air Flow Back Padding<br>
- Quick Pocket<br>
- Essentials Organizer<br>
- Complies with most airline restrictions for hand luggage*<br>
Was £55.98 Inc. VAT
Only £53.58 inc VAT.
ORDER NOW
Saitek X52 Flight Controller And Throttle Joystick - PC (PS28) @ £84.98 inc VAT
The most fully integrated PC Flight Control System Precision engineering, ergonomic design and a detailed fusion of features deliver maximum aeronautical authenticity.
- Advanced programming provided by Saitek Smart Technology (SST) software
- Enhanced gameplay through intuitive Multi-Function display (MFD)
- Illuminated buttons and MFD - ideal for low light environments
- Rubber grips and ergonomic design for increased comfort and fatigue-free gaming
- Part metal construction for increased durability and authenticity
- Includes Roger Wilco Chat software - the ideal accompaniment for on-line multiplayer gaming
Was £86.99 Inc. VAT
Only £84.98 inc VAT.
ORDER NOW
Saitek Pro Flight Rudder Pedals - PC (PZ35) @ £81.98 inc VAT
The Pro Flight Rudder Pedals are solidly constructed and feature three axis pedals which maximize flight simulator realism by enabling foot control of the rudder function. Paired with a Saitek X52 Flight Stick and Throttle, the Pro Flight Rudder Pedals provide the additional sensitivity and control accuracy for an almost real flight sim experience.
- Self-centering pedals with adjustable damping
- Adjustable foot rests to fit all sizes, with non-slip materials
- Fully adjustable rudder control to suit the gamer’s preferences
- Tension adjustment to vary resistance to suit flying style
- Advanced SST Programming
- Toe brakes
Was £83.99 Inc. VAT
Only £81.98 inc VAT.
ORDER NOW
Saitek Pro Flight Yoke System - PC (PZ44) @ £104.99 inc VAT
Precision. Realism. Control. The Saitek Pro Flight Yoke System is highly engineered to meet the exacting needs of the true flight simulation enthusiast. Stainless steel shaft, ergonomic controls, integrated chronograph and separate throttle quadrant ensure a smooth, accurate and totally realistic flying experience.
- Durable Stainless Steel shaft with precision bearings gives smooth and predictable elevator and aileron control
- Used with the supplied SST Programming software, integrated mode switch trebles the number of controls you have at your fingertips
- Accurately time each leg of your flight plan with the integrated chronograph
- Separate throttle quadrant with additional switches to configure any combination of throttle, flaps, mixture or prop pitch. Mount on top, in front of your desk, pilot or co-pilot side so that the controls are exactly where you want them
- Unique, 2-position desk clamp keeps your yoke and quadrant securely fixed no matter how extreme the flying conditions
- Saitek’s powerful Saitek Smart Technology (SST) programming software allows gamers to configure their controls to suit their preferred gaming style, and to save the configurations aspersonal profiles
Was £109.99 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
Microsoft Xbox 360 Wireless Controller - PC / Xbox 360 (JR9-00010) @ £26.99 inc VAT
The Xbox 360 Controller for Windows works with most Windows XP-based PCs and Xbox 360, delivering a consistent and universal gaming experience. Get a better feel for the game with vibration feedback ensuring riveting game play every time. Part of the new Game Precision Series, the Xbox 360 Controller offers precision, comfort and control that will set the standard for next-generation game controllers. The pad has precise thumb sticks, two pressure-point triggers, and 8-way directional pad for enhanced PC gaming. Integrated 2.4 GHz high-performance wireless technology lets you control the action from up to 30 feet away
- Integrated 2.4 GHz Wireless
- For PC and Xbox 360
- Vibration Feedback
- Ergonomic Design
- Xbox Live Play - Integrated headset jack for PC headsets and Xbox Live play
- Includes Receiver
Was £29.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive (CSSD-F120GB3-BK) @ £128.99 inc VAT
Step up to SATA 6Gb/s performance with a Corsair Force Series 3 SSD. Your system responds better, boots quicker, and loads applications faster. Ideal for notebooks, Corsair SSDs run cooler and quieter than traditional hard drives, using less power.
- 120GB Capacity
- Sequential read speeds of up to 550 MB/s
- Sequential write speeds of up to 510 MB/s
- SATA 6Gb/s (SATA 3) connectivity
- High performance SandForce SF-2200 SSD controller
- Native TRIM support (O/S support required)
- RAID Support
- BGC (Background Garbage Collection)
- 2.5" - 3.5" Adaptor Included.
** FIRMWARE ISSUE FREE **
Was £133.99 Inc. VAT
Only £128.99 inc VAT.
ORDER NOW
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £76.99 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 475MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £79.99 Inc. VAT
Only £76.99 inc VAT.
ORDER NOW
OcUK V6 Watercooled Case - BitFenix Shinobi **2011 Compatible** @ £194.28 inc VAT
Assembled by Expert OcUK Technical Staff, the V6 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
The OcUK Watercooled Case range comes pre-assembled for your convenience. All of the difficulty of watercooling has been removed and allows you to enjoy the best performance without the hassle.
All of our pre-watercooled cases are built to order and come pre filled ready for you to build your dream system.
The system is shipped with Clear Mayhems Ultra Pure Fluid. If you prefer us to use a coloured fluid or specialist liquid, you can choose from a wide range
All you need to do is build your PC and install the waterblock which is just as easy to do as mounting any CPU cooler.
All leak testing and filling is carried out by our technical staff which means that the watercooling system is ready to use by you when it arrives. All that is required is for you to plug the pump and fans into your power supply.
PLEASE CHOOSE THE CORRECT MOUNTING BRACKET FOR YOUR CPU
BitFenix Shinobi Gaming Windowed Case - Black
- Dimensions: 205 x 460 x 490mm
- Motherboard Sizes: Mini-ITX, mATX, ATX
- 5.25" Drive Bays x 3
- 3.5" Drive Bays x 8
- 2.5" Drive Bays x 2
- Front Cooling: 2 x 120mm Fans (optional) 1 x 120mm Fan (included)
- Rear Cooling: 1 x 120mm Fan (included) or 1 x 92mm Fan (optional)
- Top Cooling: 2 x 140mm Fans (optional) or 2 x 120mm Fans (optional)
- Bottom Cooling: 1 x 120mm Fan (optional)
- Expansions Slots: 7
- I/O Ports: 4 x USB2.0 & 1 x Audio
"EK-KIT H3O - Supreme LT 120" water cooling kit includes following items:
- EK-Supreme LT - UNI (universal CPU block based on EK-Supreme LT)
- EK-Backplate CPU Universal
- EK-CoolStream RAD XT (120)
- Yate Loon D12SH (2200rpm) or Yate Loon D12SM (1650rpm)
- EK-DCP 2.2 Pump
- EK-Reservoir Combo DCP 2.2
- EK-DCP PUMP mounting plate KIT
- TUBE Masterkleer 12,7/9,5 CLEAR (2 meters)
- EK-PSC Fitting 10mm - G1/4 Nickel (6 pcs)
- EK-Ekoolant UV Blue (concentrate 100ml)
- TIM Arctic Cooling MX-2 (EKWB 2g)
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in complteing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Was £200.00 Inc. VAT
Only £194.28 inc VAT.
ORDER NOW
OcUK V8 Watercooled Case - Corsair 650D **2011 Compatible** @ £285.47 inc VAT
Corsair Obsidian 650D Gaming Midi Tower - Black
- Motherboard Support: ATX / mATX
- Drive Bays: 5.25" x 4 & 3.5"/2.5" x 6
- Cooling: 2 x 200mm Fans and 1 x 120mm Fans
- Front I/O Ports: USB2.0 x 4 / FireWire x 1 / Audio x 2 / 4-Channel Fan Controller
- Dual 200mm fans provide outstanding cooling for even the hottest components
- Easily accessible dust filters make maintenance simple and hassle-free
- Quick-release side panels make it easier than ever to upgrade your hardware
- Integrated fan controller lets you quickly adjust cooling performance and noise levels
- Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of expansion
- CPU backplate cutout makes it easy to upgrade your CPU cooler
- Brilliant cable routing system provides a way to keep your system neat and tidy
- Adjustable drive cages can be removed and relocated to accommodate large video cards
- Room for long power supplies gives you peace of mind for future upgrades
- Dimensions: 546mm (L) x 229mm (W) x 521mm (H)
EK-KIT H3O - Supreme LT 240 water cooling kit includes following items:
- EK-CoolStream RAD XT (240)
- EK-DCP 2.2 Pump
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Was £300.00 Inc. VAT
Only £285.47 inc VAT.
ORDER NOW
OcUK V12 Watercooled Case - Corsair 800D **2011 Compatible** @ £388.67 inc VAT
Assembled by Expert OcUK Technical Staff, the V12 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
Corsair Obsidian 800D (6GB/s) Full Tower Case - Black
- Four easily accessed hot-swap drive bays
- Removable CPU backplate panel for easy heatsink installation
- Isolated cooling zones prevent heat buildup
- Unique cable routing holes guarantee a clean and clutter-free installation
- Three fans included, with the ability to add four more 120mm fans
- Tool-free optical drive installation makes building a system faster than ever
- Dimension: 609mm X 609mm X 229 mm
- 5 x 5.25" Drive Bays
- 4 x 3.5" SATA Hot Swappable Bays
- 2 x 3.5" Internal Bays
- Cooling: 3 x 140mm fans (included)
- Cooling: 4 x 120mm fans (optional)
- Front I/O: 4x USB 2.0, 1x FireWire, 2x Audio
EK-KIT H3O - Supreme LT 360 water cooling kit includes following items:
- EK-CoolStream RAD XT (360)
- EK-DCP 2.2 Pump
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Was £400.00 Inc. VAT
Only £388.67 inc VAT.
ORDER NOW
Laing D5 Vario Pump -T12 12V DC Pump @ £69.98 inc VAT
In response to the overwhelming demand for a quieter MCP655, we are proud to introduce the new MCP655 pump, which features several key improvements: considerably reduced audible operating noise: the high pitch frequency of the MCP655 is now eliminated thanks to a new chipset controller, head and flow characteristics have slightly improved in the midrange,
a potentiometer allows you to adjust the pumps speed from 4800 rpm down to 1800 rpm. At 1800 rpm, the pump is virtually silent. This allows users to tune the pump performance/noise ratio to their particular preference.
- 50,000 hours MTBF (Mean Time Between Failure) equivalent to 5 years lifetime.
- Superior 12 Volts DC convenience: plugs into the computer power supply
- Superior real world performance versus any aquarium pump we have tested to this date.
- The high pressure capability of the MCP655 is particularly well adapted to high-flow systems using 1/2" ID tubing
- Pump speed can be adjusted to yield top performance or virtually silent operations
- Maximum discharge 317 GPH (1200 LPH)
- Compact design
- Quiet operations even at high speed thanks to new chipset controller
- ½" barb fittings
- No maintenance when used with de-mineralized water and additives
Was £79.98 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Thrustmaster Hotas Warthog Joystick @ £249.98 inc VAT
The Hotas Warthog is an U.S. Air Force A-10C attack aircraft HOTAS (Hands On Throttle And Stick) replica joystick high end system. Pre-order now to be the first to receive the most anticipated military control system ever devised.
Flight Stick
- 3D magnetic sensors (Hall Effect) on the stick: enjoy surgical precision that stays razor-sharp over time
- 16-bit resolution (65536 x 65536 values)
- 5 coil spring system: firm, linear and fluid tension, with no dead zones
- USB connection with upgradeable firmware
- Super-stable, weighted base (over 3kg)
- New detachable handle, crafted entirely of metal: also compatible with HOTAS COUGAR™ handle (and vice-versa)
- New replica shape
- Detachable metal plate for desk- or cockpit-style use
- New, realistic pressure on buttons and trigger
- 19 action buttons in total + one 8-way "point of view" hat: . 1 x 8-way "point of view" hat . 2 x 8-way hats . 1 x 4-way hat with push button . 1 x metal dual trigger . 2 x push buttons . 2 x pinkie push buttons
Dual Replica THROTTLES
- Innovative new H.E.A.R.T HallEffect AccuRate Technology(*):
- 3D magnetic sensors (Hall Effect) on the 2 throttles: enjoy surgical precision that stays razor-sharp over time
- 14-bit resolution (16384 values) on each throttle
Dual throttles
- Metal hand rest
- Locking system
- Adjustable friction system: firm, linear and fluid tension, with no dead zones
- Realistic IDLE detent with "Pull & Push"(*) system
- Realistic and disengageable AFTERBURNER detent with "Pull & Push" system
- Realistic pressure on buttons and switches
- 17 action buttons in total + 1 mouse hat with push button + one 8-way "point of view" hat: . 1 x mouse hat with push button and 3D magnetic sensor (Hall Effect) . 1 x 8-way hat . 1 x 4-way hat with push button . 1 x push button . 1 x 3-position switch (2 momentary + 1 permanent) . 2 x 3-position switches (3 permanent)v . 1 x 3-position switch (1 momentary + 2 permanent)
Replica Control Panel
- Weighted base (over 3kg) incorporated underneath the throttles
- Backlit functions
- 5 programmable LEDs
- 15 action buttons in total + 1 TRIM wheel: . 1 x TRIM wheel . 2 x push buttons . 5 x 2-position switches (2 permanent) . 2 x 3-position switches (1 momentary + 2 permanent) . 2 x 3-position switches (3 permanent)
Was £279.98 Inc. VAT
Only £249.98 inc VAT.
ORDER NOW
Hauppauge Colossus - Video Input Adapter - PCI Express x1 @ £156.38 inc VAT
Colossus is a High Definition video recorder for making real-time H.264 compressed recordings at resolutions up to 1080i. HD PVR records component video (YCrCb) from video game consoles and cable TV and satellite set top boxes, with a built-in IR blaster to automatically change TV channels for scheduled recordings.
Colossus also has an HDMI input port, so you can record HD video at up to 1080i from a un-encrypted HDMI source.
Note: most cable and satellite TV set top boxes encrypt HDMI output, so you cannot record from these sources.
Audio is recorded using two channel stereo or optical audio with five channel Dolby Digital.
The recording format is AVCHD, which can be used to burn Blu-ray DVD disks. Two hours of HD recordings, recorded at 5 Mbits/sec, can be burnt onto a standard 4.7 GByte DVD-R or DVD-RW disk for playback on a Blu-ray DVD player.
Record your video game play
One of the popular uses for the Colossus is for recording video gameplay. As said on GeekTonic:
"Now I think anyone watching me play videogames is a sure-fire way to put them to sleep – or at least laugh at my videogame performance. But I know there is a very large number of videogamers using the HD-PVR to record their video gameplay."
Create your own HD video library ... burn your video recordings in a high definition blu-ray format!
The Colossuss amazing recording quality allows personal archival of your favorite TV programs. Record your TV programs in HD, then burn them onto a standard DVD disk (up to two hours) in a high definition AVCHD fomat.
Colossus connects to any component video equipped HD set top box. Colossus also has standard definition composite input so you can record your old home video tapes and then burn onto a DVD disk. (S-Video input available with optional cable.)
Turn your old home video tapes into Blu-ray DVD disks
You can also use Colossus to turn your old VCR tapes into Blu-ray disks. Record your video tapes using Colossus and then burn Blu-ray formatted DVD disks on your PC.
Bundled software applications:
ArcSoft "ShowBiz" for video recording and authoring and burning of your TV recordings onto a Blu-ray DVD compatible disc
Hauppauge WinTV v7 application, with support for the Hauppauge remote control and IR blaster
Was £159.98 Inc. VAT
Only £156.38 inc VAT.
ORDER NOW
Need For Speed The Run - PC @ £27.59 inc VAT
nonl2br
<a href="http://www.origin.com/download"/>
<img src="http://www.overclockers.co.uk/LP/games/originactivation.PNG"></a><br><br>
It’s called The Run.<br>
An illicit, high-stakes race across the country. The only way to get your life back is to be the first from San Francisco to New York. No speed limits. No rules. No allies. <br>
All you have are your driving skills and sheer determination as you battle hundreds of the world’s most notorious drivers on the country’s most dangerous roads. In Need for Speed The Run, you’ll weave through dense urban centers, rocket down icy mountain passes and navigate narrow canyons at breakneck speeds, all the while evading a relentless police force prepared – and willing – to use lethal force to take you down.<br><br>
<center><iframe width="560" height="315" src="http://www.youtube.com/embed/V2WeeL8EFrA" frameborder="0" allowfullscreen></iframe></center>
Was £28.99 Inc. VAT
ORDER NOW
Antec Kúhler H2O 620 CPU Watercooler (Socket Intel LGA 775 / 1155 / 1156 / 1366 / AMD AM2 / AM3 / AM2+ / AM3+) @ £40.98 inc VAT
Finally, there is a liquid cooler for the rest of us. The Antec KÜHLER H2O 620 delivers high-performance liquid cooling for your CPU in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The voltage-controlled 120 mm fan, 3rd generation copper coldplate and airflow-enhancing low-profile pump ensure efficient cooling, while the estimated 50,000 hour pump lifetime means this cooler is even likely to outlast the system it cools. Easy-bend flexible tubing allows the KÜHLER H2O 620 to be installed in nearly any orientation regardless of the internal configuration of the case. Finally, the KÜHLER H2O 620 comes with peace of mind in the form of an industry-leading Antec Quality 3 year limited warranty on parts and labour. Take your PC’s Quiet Computing™ to the next level with liquid cooling performance at a price that rivals aftermarket air coolers.
- CPU Socket Compatibility: Intel LGA 775, 1155, 1156, 1366, AMD AM2, AM3, AM2+, AM3+
- Low profile pump ensures exceptional liquid circulation while preserving internal airflow
- Easy-bend tubes for maximum flexibility in radiator positioning
- Intelligent noise / speed control fan for quiet, efficient cooling
- Latest generation copper cold plate for optimal conduction
- Cooling Liquid - Safe, environmentally-friendly, anti-corrosive
- Fan Speed: 1450 - 2000 RPM
- Tubing Length: 330 mm / 13.0"
- Radiator Dimensions: 151mm x 120mm x 27mm
- Fan Dimensions: 120 mm x 25 mm / 4.7" x 1.0"
- AQ3 - Antec Quality 3-year parts and labour warranty
Was £44.99 Inc. VAT
Only £40.98 inc VAT.
ORDER NOW
Antec Kúhler H2O 920 High Performance Liquid CPU Cooler (LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM2+/AM3+) @ £67.98 inc VAT
Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The dual 120 mm Pulse Width Modulation (PWM) fans and 3rd generation copper coldplate ensure quiet, efficient cooling, while the 49 mm radiator is equipped to handle the highest performing CPUs on the market. Lastly, the included software helps you monitor and control the
Kühler H2O 920’s performance and allows you to customize its stylish RGB LED. Designed to unlock the maximum potential of your CPU, the Antec KÜHLER H2O 920 delivers exceptional cooling when you need it the most.
- Customizable RGB LED for brilliant illumination
- CPU Socket: LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM2+/AM3+
- Fan Speed: 700 - 2400 RPM (PWM controlled)
- Radiator Dmensions: 151 x 120 x 49mm
- Fan Dimensions: 120 x 120 x 25mm
- Air Flow: 110 CFM
- 3 Year Warranty
Was £74.99 Inc. VAT
Only £67.98 inc VAT.
ORDER NOW
Creative Sound Blaster Tactic 3D Alpha @ £32.28 inc VAT
Experience the evolution of 3D gaming audio with the Sound Blaster Tactic3D Alpha gaming headset. Acoustically optimized 40mm drivers combine with THX TruStudio Pro technology to transform everyday audio into a mind-blowing cinematic experience. The dual mode design allows you to connect via standard mini jacks or use the Dual Mode adapter to connect to your PC or Mac's USB port for the full THX TruStudio Pro experience.
- Dual Mode – Analog or USB, your choice!
- THX TruStudio Pro technology
- TacticControl Tailor your sound with touch screen controls
- Customise and share optimized audio settings
- Have fun with your gaming voice
- Effortless communication with your team-mates
- Works perfect with VOIP applications such as skype / Windows live
- 1 year limited warranty
Was £32.99 Inc. VAT
Only £32.28 inc VAT.
ORDER NOW
SpeedLink Medusa NX USB 5.1 v2 Surround Headset @ £46.98 inc VAT
Enjoy brilliant trebles, feel the intensive bass - and accurately pinpoint sounds: the Medusa NX USB 5.1 Gaming Headset delivers the finest sound quality plus the eight integrated driver units and subwoofer allow you to determine precisely where the sounds are coming from - a decisive advantage in 3D games. The integrated USB soundcard makes it quick and easy to connect the headset, plus the Medusa NX USB 5.1's low weight and comfortable padding offers maximum comfort - making it the first choice for long gaming sessions.
- Flexible noise-cancelling microphone
- Breathtaking sound quality
- USB connector
- 8 driver units for realistic surround sound
- Integrated 5.1 soundcard
- Real 5.1 surround sound gaming headset
- Weight: 848g
- Packaging Dimensions: 235 (W) x 300 (H) x 100 (D) mm
Was £52.98 Inc. VAT
Only £46.98 inc VAT.
ORDER NOW
Speedlink Triton Stereo Gaming Headset @ £21.59 inc VAT
The headset of professionals. The outstanding sound quality and noise isolation performance make the Triton Stereo Headset an expert piece of kit when it comes to sound. Thanks to the highly sensitive microphone, which can be discreetly positioned in-line with the headband when not in use, you can chat with ease via the internet. At the same time, you'll enjoy many hours of fatigue-free sound thanks to the soft material and perfect-fit earcup design.
Features:
- Rugged PC headset with outstanding sound quality
- Especially sensitive microphone which can be discreetly positioned out of the way when not in use
- Compact in-line remote featuring microphone mute switch, volume control and clip
- Total noise isolation and a high level of comfort for extended use
- Lots of freedom of movement thanks to the 2.5m cable
Was £24.98 Inc. VAT
Only £21.59 inc VAT.
ORDER NOW
Samsung SH-S222AL/RSMS 22x DVD±RW SATA Lightscribe ReWriter (Beige/Black/Silver) - Retail @ £18.98 inc VAT
Samsung's 22x Serial SATA DVD Writer supports powerful over speed performance which allows writing with the high speed of 22x on a low cost 16x media and now includes the Lightscribe Labelling function.
Write Speed
- DVD-R: 22x
- DVD-R: 22x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Was £20.99 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
BeQuiet Dark Rock Advanced CPU Cooler (Socket LGA 775 / 1155 / 1156 / 1366, AM2 / AM2+ / AM3 / 754 / 939 / 940) @ £39.98 inc VAT
The Be Quiet! Dark Rock Advanced combines maximum cooling efficiency with a pleasantly quiet operation. With an extremely low noise level, efficient cooling is provided for gaming, multimedia and CAD systems even at maximum processing power. This CPU cooler is enhanced by the high-quality materials used, as well as its attractive design.
- The single-tower layout with six heat pipes enables excellent heat dissipation within a small space
- The 120-mm SilentWings PWM fan guarantees the best ratio of cooling efficiency to noise level
- The wave-shaped contour of the cooling lamellas prevents noises and optimises the airflow
- The fan surfaces are coated in dark nickel
- The brushed, fully aluminium cover protects the cooling lamellas
- The stable backplate ensures a shockproof attachment, even when transporting the computer
- Extremely efficient up to more than 180 watt
- LGA 775 / 1155 / 1156 / 1366, AM2 / AM2+ / AM3 / 754 / 939 / 940
- Fan Noise: Upto 18.8dBA
- Air flow: upto 85.8 CFM
- PWM Controlled
Was £41.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
BeQuiet Shadow Rock Pro CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM3) @ £33.98 inc VAT
The decoupled 120mm Shadow Wings PWM fan (SR1) / 135 mm Shadow Wings PWM fan (TopFlow) guarantees the best relationship between cooling effect and audible noise. The wave-shaped contours of cooling fins minimize noise and optimize air flow.
Four heatpipes transport heat via the shortest path to the optimal point within the cooling fins. The Single-Fin layout is a compact means to attain the best heat dissipation from every individual cooling fin whereas the TopFlow cooler layout provides optimal cooling for the CPU as well as for nearby system components. Completely nickel plated heat sink. The stable backplate ensures vibration-secure attachment, even when
- Number of heatpipes: 4
- Dimensions (incl. fan): 122 x 158 x 95 mm
- 1 x Shadow Wind PWM Fan inculded
- Weight (incl. fan): 740 gram
- Fan Dimensions: 120 x 120 x 75mm
- Fan Speed: 1700 RPM
- Noise Levels: 7.8 - 21.4dBA
- Air Flow: 57.2 CFM
- 4 pin PWM connection
- Black Plate Mounting Included
- 3 Year Warranty
Was £36.98 Inc. VAT
Only £33.98 inc VAT.
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £155.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £164.99 Inc. VAT
Only £155.99 inc VAT.
ORDER NOW
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail @ £47.99 inc VAT
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.00Ghz clock speed (AM3 Socket)
- Multiplier unlocked
- 2.0MB L2 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- 3yr Warranty
- Retail Boxed with Heatsink & Fan
Was £49.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
AMD Athlon II X3 Tri Core 455 3.30GHz (Socket AM3) - Retail @ £59.99 inc VAT
At home or at play, AMD Athlon II processors let you both do more of the things you want to do in less time and enhance your digital life at the right price, with energy-efficient, multi-core performance.
- Tri Core Technology
- 3.30GHz Clock Speed
- AM3 Socket
- 3x 512KB L2 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £61.99 Inc. VAT
ORDER NOW
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail @ £99.98 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.40GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (125W Edition)
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Only £99.98 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 975 Black Edition "125W Edition" 3.60GHz (Socket AM3) - Retail @ £119.99 inc VAT
- 3.60GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (140W Edition)
Was £124.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1055T "95W Edition" 2.80GHz (Socket AM3) - Retail with FREE Deus Ex PC Game @ £113.99 inc VAT
Six-core processing power for massive performance headroom - at the price of the competition's quad-core products. The AMD Phenom II X6 processor features AMD Turbo CORE technology that enables unlocked performance for cutting-edge applications, and dynamically switches to three cores for raw speed. Direct Connect Architecture that enables leading-edge performance and responsiveness, even on the most demanding applications. HyperTransport 3.0 Technology enables incredible system agility for 3D gaming and ultra-high resolution entertainment. AMD Dedicated Multi-cache that extends the memory bandwidth for intensive applications, delivering fast performance per core.
- Six Core Technology
- 2.80GHz Clock Speed
- 4.0 GT/s System Bus
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- Low Power 95W Edition
- 3 Year Warranty
- Deus Ex: Human Revolution FREE download code. Only on orders placed on 22/09/2011 onwards.
Only £113.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-8 Eight Core 8120 Black Edition 3.10Ghz (Socket AM3+) Processor - Retail @ £161.99 inc VAT
We call it the new AMD FX 8-Core Processor Black Edition and it's unlocked for your overclocking pleasure.1 Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Multiplier Unlocked
- Eight Core Technology
- 3.10GHz Clock Speed
- 4.00GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 125W
- Voltage: 0.975v - 1.4125v
- 32nm technology
- Integrated memory controller upto 29.8GB/sec
- Support upto 1866MHz DDR3
- 3 Year Warranty
Was £173.99 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (CMZ16GX3M4A1600C9) @ £77.99 inc VAT
CORSAIR high performance Vengeance memory module 16GB (4x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each four module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 16384 Megabytes of DDR3 memory
- Four matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £99.98 Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) @ £47.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- Lifetime Warranty
Was £53.99 Inc. VAT
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C8) @ £53.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 8-8-8-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- Lifetime Warranty
Was £67.99 Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) @ £41.99 inc VAT
This 8GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Was £49.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
Crucial Ballistix Elite 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLE2CP2G3D1608CE1TX0CEU) @ £33.59 inc VAT
'Designed specifically for computer gamers and power users seeking maximum seeking maximum system performance and stability, the Crucial Ballistix high performance memory line features advanced speed grades, low latencies, and integrated aluminium heat spreaders. With Ballistix memory, you can push the performance envelope.
- Black PCB
- Black high performance ALU heatspreaders
- Ultimate performance memory
- Elite heat spreader for performance
- 4096 Megabytes of DDR3 memory
- Two matched 2GB modules
- Lifetime Warranty
- Bulldozer compatible
Was £35.99 Inc. VAT
Only £33.59 inc VAT.
ORDER NOW
G.Skill RipJawsX 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-8GBXL ) @ £38.39 inc VAT
G.Skill has announced the development of its brand new RipjawsX series memory modules, designed specifically for Intel Sandy Bridge LGA1155 processors, and H67 and P67 motherboard platforms. The new RipjawsX series consists of a complete range of memory solution, from DDR3 1,333MHz, 1,600MHz, 1,866MHz, 2,133MHz, 2,200MHz to 2,300MHz. Combined with the Intel’s highly anticipated Sandy Bridge platform, G.Skill RipjawsX series memory kits deliver more bandwidth and performance than ever.
Building on the strong success of the first generation Ripjaws brand in performance memory kits, every single RipjawsX memory kit is hand-tested on an Intel Sandy Bridge platform in accordance with G.Skill's strict internal testing procedure, to ensure the best in class performance, compatibility and reliability across a range of popular motherboards. It is the perfect memory solution for PC gamers, performance workstations, enthusiast power users and anyone who loves the cutting-edge of technology!The following list shows the detail specifications of G.Skill RipjawsX family.
Model Name: F3-12800CL9D-8GBXL
Main Board: INTEL
ystem: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-24 2N
Capacity: 8GB (4GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.5V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was £43.99 Inc. VAT
Only £38.39 inc VAT.
ORDER NOW
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) @ £20.39 inc VAT
Kingston® proudly introduces HyperX® blu, a new line of reliable memory ideal for the entry level gamer or PC enthusiast.
HyperX blu features a new streamlined clipless design. Its heatspreaders provide thermal performance at an improved price point.
- Kingston Hyper-X Blu KHX1600C9AD3B1K2/4G
- 4GB Kit - 2x 2GB Modules
- DDR3-1600
- CL9
- 1.5v
- 240pin
Was £23.99 Inc. VAT
Only £20.39 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit (OCZ3G1333LV4GK) @ £22.79 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.55-1.65 Volts
- 240 Pin DIMM
Was £25.99 Inc. VAT
Only £22.79 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6950 IceQ X PLUS Edition 2048MB GDDR5 PCI-Express Graphics Card **Supplied with Battlefield 3, Dirt 3 & Deus Ex PC Games** @ £215.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Special IceQ Cooler taken from 6970 and custom fitted to 6950 by HIS for upto 18c better cooling
- Great OC Potential
- OcUK Exclusive
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Battlefield 3, Dirt 3 and Deus Ex PC Games
Was £229.99 Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6950 OC Twin FrozR III Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £218.39 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/PowerEdition.jpg" alt="Power Edition" /><br>
<br>
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a. <br>
<br>
<Font size="4"><b>Key Features</b><br></font>
<b>Propeller Blade Technology</b><br>
- MSI’s exclusive innovation design.<br>
- 20% more airflow.<br>
- Cool down more components on the PCB.<br>
- 11C cooler and 13.9dB quieter than reference HD 6950.<br>
<br>
<b>Power Edition Architecture</b><br>
- 6+2 Phase PWM Design<br>
1. Higher current to GPU Power.<br>
2. Higher overclocking capability.<br>
3. Better stability in peak load.<br>
<br>
<b>Triple Over-Voltage Function </b><br>
1. Support voltage adjustment of GPU, memory & VDDCI.<br>
2. Unleash GPU performance totally.<br>
<br>
<b>MSI Afterburner overclocking utility </b><br>
1. Supports advanced fan speed control.<br>
2. Supports burn-in stability test. <br>
<br>
<b>MSI Exclusive P/S Switch Function</b><br>
- Two fan speed profiles - Performance / Silence<br>
- Performance Mode provides best cooling demand; Silent Mode balances noise and GPU Temperature<br>
<br>
<Font size="4"><b>Specification</b><br></font>
- Core Clock: 850MHz<br>
- Memory: 2048MB GDDR5<br>
- Memory Clock: 5200MHz (Effective)<br>
- Processing Cores: 1408<br>
- Texture Units: 88<br>
- ROPS: 32<br>
- Bus Type: PCI-Express 2.1<br>
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort<br>
- HDCP Capable<br>
- DirectX 11 Support<br>
- Shader Model 5.0 Support<br>
- OpenGL 4.0 Support<br>
- ATI CrossFire Ready<br>
- ATI Eyefinity Technology<br>
- ATI Avivo HD<br>
- ATI Stream Technology<br>
- ATI HD3D Technology<br>
- Maximum Power Consumption: 250W (Typical 190W)<br>
- 2x 6pin PCI-E power connectors required<br>
- 450W minimum PSU recommended<br>
- Warranty: 3 Years<br>
Was £239.99 Inc. VAT
Only £218.39 inc VAT.
ORDER NOW
OcUK ATI Radeon 6970 2048MB GDDR5 PCI-Express Graphics Card @ £257.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 1x 8pin and 1x 6pin PCI-E power connectors required
- 500W minimum PSU recommended
- Warranty: 2 Years
Was £269.99 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 "Dual Fan Edition" 2048MB GDDR5 PCI-Express Graphics Card @ £209.99 inc VAT
The SAPPHIRE HD 6950 Dirt3 Special Edition is a new SAPPHIRE original model with a special cooler using a new dual fan configuration. Based on the latest high end AMD GPU architecture, it boasts true DX 11 capability and the powerful configuration of 1408 stream processors and 88 texture processing units. With its clock speed of 800MHz for the core and 2GB of the latest GDDR5 memory running at 1250Mhz (5 Gb/sec effective), this model speeds through even the most demanding applications for a smooth and detail packed experience.
A Dual BIOS feature allows enthusiasts to experiment with alternative BIOS settings and performance can be further enhanced with the SAPPHIRE overclocking tool, TriXX, available as a free download from http://www.sapphiretech.com/ssc/TriXX/
Features:-
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1 x Dual-Link DVI-I, 1 x Single-Link DVI-D, 1 x HDMI, 1 x DisplayPort
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters Provided)
- Warranty: 2 Years
Was £224.99 Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6850 Cyclone Power Edition 1024MB GDDR5 PCI-Express Graphics Card @ £113.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 6800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Boost up to 50%* higher with MSI exclusive Voltage Tweak
- Core Clock: 860MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4400MHz (Effective)
- Processing Cores: 960
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 3 Years
Was £119.99 Inc. VAT
ORDER NOW
HIS ATI Radeon HD 6770 1024MB GDDR5 PCI-Express Graphics Card @ £76.79 inc VAT
Now, more people than ever can experience real innovation in DirectX® 11 gaming with AMD Radeon™ HD 6770 Graphics. Expand your visual real estate across up to five displays and get lost in the action with AMD Eyefinity multi-display technology. Using AMD App Acceleration, speed up everyday applications and do more than ever with your PC. Loaded with advanced technologies, these GPUs have the power and premium features needed for fully immersive gameplay.
Features:-
- Memory Clock: 4800MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 800
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI 1.4a & 1x DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £89.99 Inc. VAT
Only £76.79 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6770 IceQ X Turbo 1024MB GDDR5 PCI-Express Graphics Card @ £89.99 inc VAT
Features:-
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £99.98 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX580 DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 782MHz (reference 772MHz), allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX580 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX580 DCII/2DIS/1536MD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Voltage Tweak Technology
- Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
- Gamer OSD: Real-time overclocking, benchmarking and video capturing in any PC game!
- Splendid: Watching movies on PC is as good as on Top-of-the-line consumer television
- Core Clock: 782MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
Was £389.99 Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 Matrix Platinum 1536MB GDDR5 PCI-Express Graphics Card @ £395.99 inc VAT
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
TweakIt provides users with flexible overclocking control even when running benchmark programs! The “+” and “-” button puts overvolting adjustments in the user´s fingertips, offering them performance optimization options during game play to gain the competitive edge.
ProbeIt takes the guesswork out of locating the graphics card´s measurement points, identifying them clearly in the form of 6 sets of detection points so you´ll know exactly where to get quick yet accurate readings using a multimeter.
Safe Mode button resets the graphics card back to default frequencies & BIOS. This is a very welcomed feature for hardware enthusiasts, think of it like the "Clear CMOS" on a motherboard.
Built with exclusive 19-phase Super Alloy Power technology, the MATRIX GTX 580 guarantees much greater overclocking headroom, with a 15% performance boost, 2.5 times longer lifespan and 35°C cooler operation than the reference card design.
Cooling is well taken care of by exclusive DirectCU II technology that puts copper heat pipes in direct contact with the GPU. The pipes efficiently transfer heat through two massive fans that deliver 600% more airflow than the reference design, resulting in a 20% lower operating temperatures.
A multicolored LED MATRIX indicator at the rear of the ROG MATRIX GTX 580 gives an instant and easy-to-understand visual display of the current GPU load.
Features:-
- Overclocking hardware tools, TweakIt and ProbeIt are directly embedded onto the graphics card firmware, while a Safe Mode button offers an easy reset option worry-free hardware overclocking.
- All new GPU Tweak provides professional graphics overclocking for PC enthusiasts
- 19-phase Super Alloy Power technology provides more headroom for overclocking with a 15% performance boost, reduced running temperatures and prolonged product lifespan
- Award-winning DirectCU II thermal technology with sound-dampened dual fans provides 600% greater airflow and 20% cooler performance than the reference design.
- Core Clock: 816MHz (Fermi GF110) (Upto 950MHz core possible)
- Shader Clock: 1632MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters), 1x DisplayPort.
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was £409.99 Inc. VAT
Only £395.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 580 SuperClocked w/Backplate 1536MB GDDR5 PCI-Express Graphics Card @ £383.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 797MHz (Fermi GF110)
- Memory Clock: 4050MHz (Effective)
- Shader Clock: 1594MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 10 Years (Requires registration within 30 days with EVGA)
Was £399.98 Inc. VAT
Only £383.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 580 3072MB GDDR5 PCI-Express Graphics Card @ £443.99 inc VAT
Features:-
- Core Clock: 772MHz (Fermi GF110)
- Memory: 3072MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
Was £479.99 Inc. VAT
Only £443.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 570 HD 2560MB GDDR5 PCI-Express Graphics Card @ £317.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 732MHz
- Memory: 2560MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1464MHz
- DisplayPort 1.1a connector included
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £329.99 Inc. VAT
Only £317.99 inc VAT.
ORDER NOW
MSI GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
Features:-
- Memory: 1280MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £249.98 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 560Ti 2048MB GDDR5 PCI-Express Graphics Card @ £221.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
Features:-
- Core Clock: 822MHz
- Memory Clock: 4000MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1645MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Only £221.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 560Ti 2048MB GDDR5 PCI-Express Graphics Card @ £196.79 inc VAT
Features:-
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was £199.99 Inc. VAT
Only £196.79 inc VAT.
ORDER NOW
Dell UltraSharp U2312HM 23" Widescreen LED Monitor - Midnight Grey @ £199.99 inc VAT
See vivid imagery from almost any angle. The 23” Dell UltraSharp U2312HM monitor with LED offers a brilliant view, rich colors and adjustable height options.
- Lose yourself in the details: : Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding color consistency across a wide viewing range.
- Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
- Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
DISPLAY
Panel Size: 58.42 cm
Aspect Ratio: Widescreen (16:9)
Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
Optimal Resolution: Full HD resolution, 1920 x 1080 at 60 Hz
Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Dynamic Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Brightness: 300 cd/m2 (typical)
Response Time: 8ms (gray to gray)
Viewing Angle: (178° vertical / 178° horizontal)
Color Support: Color Gamut(typical):82%(CIE 1976)4
Color Depth: 16.7 million colors
Pixel Pitch:0.265mm
Diagonal Viewable Size:58.42 cm
23 inches (23-inch wide viewable image size)
Preset Display Area ( H x V): 509.2 mm x 286.4mm, 20.04" x 11.28"
Backlight Technology: LED
CONNECTIVITY
1 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort (DP)
1 Video Graphics Array (VGA)
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
DC power connector for Dell Soundbar
COLOR, SIZE AND WEIGHT
Dimensions with stand (H x W x D):365.0 mm(compressed) ~ 493.0 mm(extended) x 546.4 mm x 185.4 mm, 14.37 inches (compressed) ~19.44 inches(extended) x 21.51 inches x 7.30 inches
Dimensions without stand (H x W x D): 323.3mm x 546.4 mm x 59.5 mm, 12.73 inches x 21.51 inches x 2.34 inches
Weight (panel only - for VESA mount): 2.96 kg, 6.53 lbs
Weight (with packaging): 6.47kg,14.26 lbs
Specifications - Service / Support Details: 3-Year Advanced Exchange1 Service and Premium Panel Guarantee
Was £219.98 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Samsung S23A750D 23" 120Hz 3D Widescreen Ultra Thin LED Monitor - Glossy Black @ £377.99 inc VAT
Samsung’s 750 and 950 series 3D desktop 3D monitors feature high refresh rate, incredibly thin bezel and stylish design. These monitors are able to analyze and render 2D content in real-time to 3D, supporting PC content, Blu-ray films and gaming consoles. The monitors feature a built-in glasses sync emitter, and they are packaged with a pair of 3D active shutter glasses.
Viewers will experience deep, rich colours and image clarity with Samsung’s new Ultra Clear Panel technology, which combines the vibrancy of a glossy display while maintaining the ease of viewing afforded by an anti-glare matte finish. The LED-backlit panel boasts 100% sRGB coverage to produce realistic colour reproduction.
Features:-
- 3D Active Glasses are included
- TRUE 120Hz
- 2D - 3D Conversion technology
- Screen Size: 23" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000000:1
- Brightness: 300cd/m²
- Response Time: 2ms (2D) / 2ms (3D)
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x HDMI, 1x DisplayPort
- Warranty: 3 Years On-Site
Only £377.99 inc VAT.
ORDER NOW
Dell UltraSharp U2412M 24" Widescreen LED Monitor - Midnight Grey @ £275.99 inc VAT
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style. Powerful:
- Experience IPS technology, featuring a wide viewing angle with high-quality color representation for a peerless viewing experience.
- Flexible: Pick the view that works best for you with an almost unlimited range of tilt, swivel, pivot and height adjustments.
- Customizable: Change your energy usage settings, text brightness and color temperature with the touch of a button to help conserve energy with this eco-designed arsenic-free and mercury-free panel.
Whether for work or for play, the Dell UltraSharpTM U2412M can deliver an unmatched viewing experience.
- Clearly outstanding: Watch your graphics come to life on a vast 24" (61cm) LED-backlit screen featuring a crystal-clear 1920x1200 resolution on a 16:10 widescreen aspect ratio so you can’t lose screen area just because your customized applications support a different resolution.
- Contrasting view: Get ready for blur-free viewing with 2 million:1 (typical) high dynamic contrast ratio and 8ms with overdrive gray-to-gray (typical) response time that helps ensure crisp, sharp and ghost-free images.
- Colorful character: Enjoy an amazing range of rich, dramatic and accurate colors, thanks to IPS technology designed to give you color consistency across a broad viewing angle and a wide color gamut at 82% (typical).
- Premium Panel Guarantee: 100% replacement of Dell UltraSharp series monitors sold if any bright pixel is found, valid within the warranty1 period.
Specification:-
- 24" (60.96 cm) viewable area
- Widescreen (16:10)
- Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
- 1920 x 1200 at 60 Hz
- 1000 : 1 (typical)
- 2,000,000:1 (dynamic)
- 300 cd/m2 (typical)
- 8ms (gray to gray) Typical
- 178º / 178º
- 16.7 million colors
- Color Gamut: 82% (CIE 1976)
- 0.27 mm
- 1x Digital Visual Interface connectors (DVI-D) with HDCP
- 1x DisplayPort(DP)
- 1x Video Graphics Array (VGA)
- 1x USB 2.0 upstream port
- 4x USB 2.0 downstream ports
- DC power connector for Dell Soundbar
- Height-adjustable stand, tilt , swivel , pivot and built in cable-management
- Flat Panel Mount Interface
- VESA Mount
- Warranty: 3 Years On-Site (Dell Premium Guarantee - You will receive a replacement UltraSharp monitor should even one bright defective pixel appear on the screen)
Was £299.99 Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Dell UltraSharp U2410 24" Widescreen LCD Monitor - Midnight Grey @ £431.99 inc VAT
Experience astounding colour accuracy, precision and performance with the Dell UltraSharp U2410 Monitor. The U2410 is packed with features that make it easy to connect and a pleasure to use, no matter how much screen time you log including Picture-in-Picture, adjustable stand, touch controls and extensive connectivity. Thanks to PremierColor technology, the U2410 Monitor delivers reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. A colour gamut of 110% delivers vibrant, true-to life colour across all display modes.
- Screen Size: 24" IPS Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 80000:1
- Brightness: 400cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Component, 1x Composite, 1x VGA, 1x DisplayPort, 2x DVI-D & 1x HDMI
- Adjustable Stand
- VESA Compliant
- Dimensions: 559.7mm x 493.0mm x 201.5mm
Was £455.99 Inc. VAT
Only £431.99 inc VAT.
ORDER NOW
Dell UltraSharp U2711 27" Widescreen LCD Monitor - Midnight Grey @ £623.99 inc VAT
With its amazing colour accuracy and versatile connectivity, the high-performance Dell U2711 Monitor delivers stunning detail, depth and responsiveness. PremierColour technology allows the Dell U2711 Monitor to deliver reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. Factory-tuned Adobe RGB and sRGB modes minimize the need for further colour calibration; each monitor arrives with a certified colour-calibration factory report. 100% sRGB and 96% AdobeRGB meets the needs of professional users involved in colour-centric work such as graphic design, CAD/CAM, gaming and media creation.Customize your viewing experience with the height-adjustable stand and tilt/swivel features - or save valuable desktop space by detaching the panel from the stand for wall mounting.
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Brightness: 350cd/m²
- Inputs: 1x Analogue, 2x DVI-D, 1x HDMI, 1x DisplayPort, 1x Composite & 1x Component
- 4-Port USB Hub
- 8-in-1 Card Reader
- VESA Compliant
- Dimensions: 646.71mm x 427.83mm x 199.95mm
- Weight: 7.72kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
Was £635.99 Inc. VAT
Only £623.99 inc VAT.
ORDER NOW
Dell Ultrasharp U3011 30" Widescreen LCD Monitor - Midnight Grey @ £958.80 inc VAT
Experience amazing wide-angle viewing and color consistency with the DellTM UltraSharpTM U3011 30"W Monitor with PremierColor. Extensive connectivity features and customization via CustomColor mode make the U3011 an ideal choice for professionals in CAD/CAM, graphic design, gaming and other fields where color precision matters.
Features:-
- IPS (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- 117% (CIE 1976) color gamut with excellent AdobeRGB and sRGB coverage for rich, lifelike visuals
- Easy, versatile adjustability and some of the latest connectivity options, including HDMI, DisplayPort, DVI-D, USB ports and a 7-in-1 media card reader
Specification:-
- 30" Widescreen
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1.07 Billion Colours
- 100,000:1 Contrast Ratio
- 7ms Response Time (7ms Grey-TO-Grey)
- 370 cd/m2 Brightness
- Two DVI-D Input with HDCP support
- Two HDMI Input
- One Display Port Input
- One Analogue Input
- Component Connectors
- Height adjustable stand, tilt and swivel (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
Was £999.00 Inc. VAT
Only £958.80 inc VAT.
ORDER NOW
Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black @ £239.99 inc VAT
The Hanns.G 27.5" has an industry ultra-fast 3ms response time making it perfect for blur-free video and gaming. With it's 15000:1 contrast ratio and excellent viewing angles there is no other TFT that can match the combination of quality, value and performance. Making the large screen affordable to all this 27.5" is ideal for gamers and home cinema use due to its huge size and 1920x1200 resolution.
- Screen Size: 27.5" Widescreen
- Contrast Ratio: 15000:1
- Response Time: 3ms
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 653.0mm x 523.0mm x 254.0mm
- Weight: 8.5kg
ORDER NOW
Samsung S27A750D 27" 120Hz 3D Widescreen Ultra Thin LED Monitor - Glossy Black @ £503.99 inc VAT
Features:-
- TRUE 120Hz
- Screen Size: 27" Widescreen
Was £529.99 Inc. VAT
Only £503.99 inc VAT.
ORDER NOW
Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB Cache - OEM (0F10383) @ £97.99 inc VAT
The Deskstar 7K1000.C hard drive is a 7200RPM 3.5" hard drive that provides an exceptional blend of power efficiency and performance, making it an ideal solution for power friendly consumer and commercial desktop computers. This third-generation 1TB hard drive from Hitachi boosts media transfer rate performance by as much as 13% over its predecessor. Leveraging eighth-generation power management technology, as well as power-saving HiVERT innovations pioneered on the popular 2.5" line of notebook hard drives from Hitachi, this new desktop drive provides up to 18% idle power savings over the previous model, delivering best-in-class power management and thermal emissions.
- Capacity: 1TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Warranty: 2 Years
Was £109.99 Inc. VAT
Only £97.99 inc VAT.
ORDER NOW
Creative Sound Blaster X-Fi Xtreme Audio 7.1 Sound Card - OEM (PCI-Express) (30SB104200000) @ £29.99 inc VAT
Upgrade your new PC to award-winning Sound Blaster X-Fi Xtreme Fidelity audio! Creative's Sound Blaster X-Fi Xtreme Audio PCI Express transforms MP3 music and movies over headphones or surround sound speakers. X-Fi Crystalizer restores the details and vibrancy lost during MP3 and DivX compression, breathing life back into any audio. X-Fi CMSS-3D expands stereo music and movie sound tracks into amazing surround sound even over regular headphones, with OpenAL and EAX 4.0 support for enhanced gaming. The perfect addition to PCI Express-ready PCs, this Windows Vista compliant card features extended connectivity thanks to its integrated digital optical input and output.
- Full height Windows Vista compliant PCI Express card for the latest desktop PCs.
- X-Fi 24-bit Crystalizer restores the details and vibrancy lost during audio compression, enhancing MP3/WMA music, DivX movies, TV and radio.
- X-Fi CMSS-3D Surround up-mixes MP3 audio to 5.1 or 7.1 surround. X-Fi CMSS-3D Headphone delivers incredible surround sound for movies and music over stereo headphones.
- Free download of Cyberlink's PowerDVD software with DTS® and Dolby Digital®-EX decoding for the ultimate in DVD movies. Enjoy immersive gaming over headphones with OpenAL and EAX 4.0 support.
- Entertainment Console gives easy setup and control.
- Comprehensive connectivity includes an integrated digital optical input and output.
Was £35.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Creative HS-400 Headset (51MZ0235AA007) @ £14.40 inc VAT
The HS-400 headset with noise-cancelling microphone is the right choice for internet voice applications or gaming. It delivers great audio over its headphones, for enhanced gaming pleasure, while users who demand the power of broadband telephony or voice conferencing will appreciate the advanced microphone, which automatically cancels-out background noise and has a rotary design which ensures a comfortable fit. It can also be detached easily when required. Lightweight and comfortable, the HS400 combines style, features and performance.
- Microphone can be detached for gaming and audio use.
- Rotary design makes microphone exceptionally comfortable.
- 30mm Neodymium magnet drivers give good results in gaming and audio.
- Oxygen-free copper cable for enhanced frequency response.
- Gold-plated stereo miniplugs for better connections.
- Stylish design stays comfortable for hours.
Was £14.98 Inc. VAT
Only £14.40 inc VAT.
ORDER NOW
Anidees AI-6BW Midi-Tower Windowed Case - Black @ £112.98 inc VAT
The AI-6 gives an immediately clear first impression of quality and elegance. The Front cover shows a fairly large unit which houses a plastic exterior and with a brushed aluminum centre. In between lie, a set of stealthy, and concealed air vents, which should ensure good cooling.
This look is made possible through a closed front door, which is open when delivered to the left, this can be switched by the user to the right if required. If you open it, one sees a rectangular mesh field in the lower and upper area. The drive bays are provided by three 5.25-inch apertures. For each of them they can be cut away in order to push through an external 3.5-inch device.
Although only an adapter factory setting of one of three 5.25-inch slots at Al-6 is, but those frames can be conveniently buy more if needed. The lid of the clear line is continued by the I/O panel which is inserted inconspicuously. Two USB 3.0 ports that are present in addition to audio connectors and four USB 2.0 and are connected internally.
Under the removable cover part you will find a very good mesh surface, which ensures that a radiator with a size of up to 280 mm which can optimally cool with a good deliver fresh air. Alternatively, it is also just two 140s or 120s fan positioned there. The same applies to the front, where two fans of both formats can be accommodated, while the rear has only one 120-mm fan space.
- Windowed Edition
- Dimensions: 207 x 509 x 527 mm (W x H x D)
- Material: steel, aluminum
- Weight: 11 kg
- Color: Black
- Form Factor: ATX, Micro ATX, Mini-ITX
- Front Cooling: 1x 140 / 120 mm (front, 120 mm optional)
- Rear Cooling: 1x 120 mm (rear) / 1x 140 / 120 mm (front optional)
- Top Cooling: 2x 140 / 120 mm (lid, optional)
- Filters: Front & Back
- Drive bays: 3 x 5.25 inches (external) / 1 x 3.5 inches (external, instead of 1x 5.25 inch) / 7 x 3.5 inch / 2.5 inch (internal)
- Power Supply: Standard ATX 1x (optional)
- Expansion Slots: 8 (without tools)
- I / O Panel: 2x USB 3.0 / 4x USB 2.0 / 1x each Audio In / Out
- Maximum graphics card length: 428 mm
- Features: Elements made of brushed aluminum
- Cable Management
- HDD and power supply decoupling
- Removable hard disk cages
Only £112.98 inc VAT.
ORDER NOW
Anidees AI-6B Midi-Tower Case - Black @ £99.98 inc VAT
- Weight: 11 kg
- Color: Black
- Cable Management
ORDER NOW
Corsair Graphite 600TM Midi Tower Mesh Windowed Case - Black @ £129.98 inc VAT
nonl2brThe Graphite Series 600T is a mid-tower in height, but inside it’s positively cavernous. Easily accommodate even the longest graphics cards in the industry due to the reconfigurable hard drive bays. The increased space behind the motherboard tray allows clean, uncluttered cable routing. Up to six hard drive caddies, each of which can accommodate SSDs and standard mechanical disks, sit below the four 5.25" tool-free optical drive bays. If that weren’t enough, you can remove the top panel 200mm fan and install a 240mm radiator and dual 120mm fans for a quick watercooling upgrade.<br><br>
- Twin 200mm cooling fans with white LEDs for excellent cooling<br>
- Eight expansion slots provides you flexibility for multiple graphics card solutions<br>
- Unique cable routing holes guarantees you a clean and clutter-free installation<br>
- Integrated fan controller, for up to four fans, gives you the choice of noise vs. performance<br>
- Motherboard compatibility: ATX and MicroATX<br>
- Front I/O Ports: USB2.0 x 4, USB3.0 x 1, FireWire x 1, Audio x 2<br>
- Cooling: 2 x 200mm white LED fans <br>
- Tool-free optical drive installation makes building your system faster than ever<br>
- CPU backplate cutout makes upgrading your CPU heatsink easy<br>
- 2.5” and 3.5” hard drive compatibility for up to 6 drives — straight out of the box!<br>
- Two year warranty with Corsair’s world-class customer service and technical support<br>
<center>
<span id="ctl00_ctl00_cpBodyCode_cpSubBodyCode_lblHTML"><object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/L_XuntEjQS8&hl=en_GB&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/L_XuntEjQS8&hl=en_GB&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object></span>
</center>
Was £134.99 Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
Razer Megalodon Elite 7.1 Surround Sound USB Gaming Headset @ £116.39 inc VAT
The Razer Megalodon is a 7.1 Surround Sound Gaming Headset designed specifically to incorporate the Razer Maelstrom Audio Engine, making it the definitive headset for gamers today. Utilizing next generation HRTF technologies and a superb DSP with unheard of processing power, the Razer Megalodon is the most advanced audio headset of its kind.
- Frequency Response: 20 - 20,000 Hz
- Impedance: 32 O at 1kHz
- Sensitivity (@1kHz, 1V/Pa): 102 ± 4dB at 1 kHz
- Max. Input Power: 200 mW
- Drivers: 40 mm, with neodymium magnets
- Microphone
- Frequency Response: 50 - 16,000 Hz
- Sensitivity (-37 ± 4dB @1kHz, 1V/Pa): Variable (user adjustable)
- Signal-to-Noise Ratio: 50 dB
- Pick-up pattern: Unidirectional
- Audio Processing Unit
- Master volume, center speaker, front speakers, side speakers, rear speakers, bass level, mic sensitivity, mic leveling, mic mute, Razer Maelstrom on/off, active/standby toggle, reset
- Cable: 3.3 meters, Braided Fiber Sheath
- Connector: Gold-plated USB
Only £116.39 inc VAT.
ORDER NOW
TT Esports Gamers Headset Shock - Black @ £27.59 inc VAT
nonl2br
The TT Esports Gamers Headset Shock brings gaming to a new level. Immerse deeply into your games with 40mm speaker drivers and stereo surround sound. Take advantage of your soundcard with 3.5mm speaker jacks bringing maximum sound performance. The ultra comfortable padded earcups make sure that comfort is key, especially for intense professional gaming. <br><br>
- Stereo surround sound<br>
- Quality 40mm speaker driver with enhanced bass performance<br>
- Noise cancelling microphone for communciation in gaming activities<br>
- Control Box with In-line control box for instant gaming sound control<br>
- 10 Levels adjustment for a perfect fit<br>
- Foldable design<br>
- Gold plated 3.5mm connctor<br>
<br>
<br>
<iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/2gampqTGEf8" frameborder="0" allowfullscreen></iframe>
Was £29.99 Inc. VAT
Only £27.59 inc VAT.
ORDER NOW
XFX Pro 850W Core Edition '80 Plus Bronze' Power Supply @ £86.99 inc VAT
XFX PSUs are designed to deliver tight DC voltage regulation with minimal AC ripple, giving you safer, cleaner power which, along with XFX’s new EasyRail™ Technology allows you to connect numerous devices without worrying about running out of power before reaching the maximum wattage. EasyRail™ optimizes it all for you. Available in 650W, 750W and 850W, XFX ProSeriesPSUs with EasyRail™ Technology gives you one continuous rail of power covering the total maximum wattage. EasyRail™ Technology Provides Maximum Power Unique, continuous EasyRail™ technology enables you to maximize available power and makes set-up easy.
- Fixed FDD: 1
- Fixed Peripheral: 7
- Fixed 6+2-pin PCI-E: 2
- Fixed 6-pin PCI-E: 2
- Fixed ATX12V / EPS12V: One 4+4-pin
- Fixed Motherboard Connector: 20+4 Pin
- Fixed SATA: up to 11
Was £89.98 Inc. VAT
Only £86.99 inc VAT.
ORDER NOW
XFX 750W Black Edition Modular '80 Plus Silver' Power Supply @ £99.98 inc VAT
The XFX Black Edition 750 watt modular power supply gives you the power you need with a brilliant
combination of form and function. Giving more than just life to your PC, this power supply allows easy cable management with modular connectors which helps increase airflow. With tight voltage regulation and high efficiency operation up to 88% (80 Plus Silver) this power supply will give you exactly what you need to keep your gaming charged and ready.
-750W of continuous power at 50°C
- Tight voltage regulation (±3%)
- High efficiency operation up to 88% (80 Plus Silver)
- Single, high power +12V rail (up to 62A/744W)
- DC to DC voltage Regulator modules for +3.3V and +5V
- High quality Japanese brand capacitors (105°C)
- Solid polymer caps provide enhanced reliability and stability
- Quiet 135mm ball bearing fan provides superior cooling
- Supports multiple high-end graphic adapters (NVIDIA SLI & ATI CrossFire Ready)
- Supports the latest ATX12V and EPS12V standards
- Active PFC with Universal AC input
- Detachable modular cables
- Energy Star 4.0 and RoHS compliant
- 5-Year Limited Warranty, subject to registration
Was £104.99 Inc. VAT
ORDER NOW
Sennheiser PC 11 VOIP Headset @ £11.99 inc VAT
The PC 11 makes it easy to phone over the net with clear sound quality wherever you take your laptop – thanks to one-hand operation and an adjustable high-performance microphone. The
ultra-light and discreet on-ear design is not only comfortable, it also quickly stows away in a handbag or pocket. Key Features include: Speech clarity – adjustable, omni-directional microphone delivers clear conversations and flexibility. Light and comfortable – on-ear headset that is so light, you’ll almost forget you are wearing it. Flexible wearing – two ear-hooks give you the choice of wearing the headset on either your right or left ear. Easy to use – just insert the 3.5mm plugs into the microphone and headphone jacks on your desktop or laptop and you are ready for internet telephony. Internet telephony on any computer – for desktop PCs and laptops, on the road or at home. Peace of mind – thanks to the 2-year international warranty.
- Light and comfortable;
- Flexible wearing on right or left ear;
- Easy to use;
- Adjustable, omni-sirectional microphone delivers clear conversations;
- 2 Year Warranty
Was £12.59 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Logitech G400 3600DPI Gaming Mouse (910-002279) @ £27.98 inc VAT
Set your sights on victory. With a high-precision optical engine, the G400 gives you consistent tracking and precise aiming no matter how fast you move your hand.
Instant access to four dpi levels lets you shift from pixel-precise targeting to lightning-fast maneuvers. A sculpted comfort grip, low-friction feet and eight programmable buttons keep you comfortable and in command.
You've got the upper hand with precision targeting and pinpoint accuracy. Your mouse communicates over USB at a blazing-fast 1000 reports per second - as fast as USB can go, and eight times faster than standard USB mice.
- Weight: 133 g
- Connectivity Technology: USB
- Movement Detection Technology: Optical
- Buttons Qty: 8
- Movement Resolution: 3600 dpi
- Performance: 1 ms response time, 5.8 megapixels per second, realtime sensitivity switching 400 - 3600 dpi, 25 G maximum acceleration
- Features: Programmable buttons, sensitivity adjustment, polytetrafluoroethylene (PTFE) feet
- Cables Included: 1 x USB cable - integrated
- 3 years warranty
Was £29.99 Inc. VAT
Only £27.98 inc VAT.
ORDER NOW
Mionix Naos 5000 Gaming Mouse Laser 5040dpi Sensor @ £66.98 inc VAT
This prominent gaming mouse is named after the star Naos, a blue super giant and one of the brightest stars in our galaxy. Naos means “ship” and is enough powerful to create comet tails and huge clouds of auroras visible from Earth. Naos is constantly moving away from its original position in the constellation of Vela and it spins about 100 times faster than our sun. Since its birth it has covered a distance of 400 light-years. No one knows exactly why Naos has such a high rotation speed, but an explanation to this phenomenon lies in the gravitational interaction between many other stars.
A passionate hunt for perfection has come to an end. Mionix Naos 5000 has seen its first light of day. Get ready to meet a gaming mouse with an incredible ergonomic comfort and stunning technology that offers an outstanding gaming experience. Mionix Naos 5000 features a new innovative weight tuning system for an optimal weight distribution of the mouse, carefully selected high-end components and leading laser technology. Stunning features such as adjustable lift-distance, 5 onboard profiles, extensive macro settings and customizable LED-lights give you the opportunity to customize the mouse exactly to your liking.
- Balanced weight tuning system
- Seven programmable buttons
- Surface quality analyzer tool
- Customizable LED light system
- 128KB built-in memory
- 5040 DPI Laser sensor
- Truly ergonomic design
- Maximum grip: The rubber coating ensures a maximum grip
- Balanced weight tuning system: A unique weight tuning system for an optimal weight distribution
- 5040 dpi laser sensor: Remarkable tracking performance built for gaming
- S.Q.A.T™ - Surface Quality Analyzer Tool
- 3 steps customizable dpi in-game adjustment
- 7 programmable buttons
- In-game profile switch
- Adjustable polling rate
- Plug n Play
Was £69.98 Inc. VAT
Only £66.98 inc VAT.
ORDER NOW
Logitech C910 HD 1080p Pro 10 Megapixel Webcam (960-000598) @ £75.59 inc VAT
Individuals using the webcam to communicate with friends and business associates will benefit from its 720p video calls, 1080p HD recording and its ability to capture ten-megapixel stills. Sharing videos and images could not be easier with the Logitech HD Pro Webcam C910 (960-000598) due to its one-click Facebook upload feature, while its life-like audio quality could appeal to some customers. Users can enhance the security of the webcam by using its face recognition login feature, offering peace of mind and protection against unauthorised use. Meanwhile, Carl Zeiss optics combined with RightLight 2 technology and bundled Logitech video effects could make this device an even more appealing purchase for enthusiasts.
- Full HD 1080p video capture (up to 1920 X 1080 pixels) with recommended system*
- HD video calling (1280 x 720 pixels) with recommended system*
- Logitech More HD technology
- Carl Zeiss® optics with autofocus
- Photos: Up to 10 megapixels (software enhanced)
- Built-in mics with Logitech RightSound™ technology
- Hi-Speed USB 2.0 certified (recommended)
- Universal clip fits laptops, LCD or CRT monitors
- 2-year limited hardware warranty
Basic requirements:
- 1 GHz
- 512 MB RAM or more
- 200 MB hard drive space
- Internet connection
- USB 1.1 port (2.0 recommended)
- Windows® XP (SP2 or higher), Windows Vista® or Windows® 7 (32-bit or 64-bit)
For HD 720p video calling and Full HD 1080p video recording:
- 2.4 GHz Intel® Core™2 Duo
- 2 GB RAM
- USB 2.0 port
- 1 Mbps upload speed or higher
- 1280 x 720 screen resolution
Was £77.99 Inc. VAT
Only £75.59 inc VAT.
ORDER NOW
OcUK Value CA403 8.0 Mega Capture PC Camera @ £9.60 inc VAT
The superb OcUK Value webcam offers brilliant image quality at high resolution for a great price.
• USB2.0 Pixart UVC DSP chip and high analyze degree 1/6-inch CMOS Color sensor,High quality glass lens
• 2.Performance: plug & play in vista,xp2 system(driverless) ,300K pixels in hardware(optical),(up to 2.0M pixels for video and caputre,8.0M pixels for capture after use driver)
• Use driver on XP1,2000 system ,Snap capture (Max.): 3200*2400
• Image mode:160*120(QQVGA);176*144(QCIF);320*240(QVGA);352*288(CIF);Default 640*480(VGA);800*600(SVGA);1280*960(SXGA);1600*1200(UXGA);
• With face tracking,zoom in and out function,Digital zoom function,6 frame and 18 special effects by driver
• Frame rate: 640* 480 (VGA) mode up to 30 frames per second;1600*1200 upto 15 frames per second;
• USB2.0 format
• Supports Windows 2000/XP/Vista/7
• Supports Mac OS X: Above version 10.4.8
Was £9.98 Inc. VAT
Only £9.60 inc VAT.
ORDER NOW
Storage Options CCTV 500GB DVR 2+2 + Monitor @ £402.78 inc VAT
nonl2br
A 4 channel digital video recorder with pre-installed hard disk drive, designed to be used with the
Storage Options CCTV Range. Records in H.264, the latest compression technology, which gives
improved image quality and a longer recording time. Remote viewing is available as standard across your network or through the mobile phone/tablet application. Just add cameras for a complete security
solution.<br><br>
Storage Options offers a range of affordable CCTV Solutions for home or small business security. With a range of cameras, digital video recorders and other accessories, our aim is to offer high-quality products and service without the premium price.<br><br>
- 500GB hard disk drive installed<br>
- Real time Viewing/Recording of up to 4 CCTV Cameras <br>
- Easy Setup and Operation, Simple User Interface<br>
- H.264 Compression Technology Provides Higher Quality and Longer Recording Times<br>
- Simultaneous Viewing, Recording, Playback, Backup and Network Operation<br>
- Android TM and Apple® Applications for Mobile Devices Available<br>
- Compatible with Most Modern CCTV Cameras<br><br>
<b>Package Contents</b><br>
1x 17" LCD Monitor
1x Storage Options Digital Video Recorder<br>
2x Storage Options Indoor CCTV Camera<br>
2x Storage Options Outdoor CCTV Camera<br><br>
<b>Motion Detection</b><br>
The Storage Options CCTV system has built in, sophisticated software that can detect movement. If your camera spots movement it can trigger an event to record this to your hard drive, giving you peace of mind that your home or office is constantly being monitored & protected. Most users however will set it to record continuously, this feature is mostly used to save disk space as well as only record when movement is detected.<br><br>
<b>Flexibility…</b><br>
The Storage Options CCTV Camera range is designed to appeal as many different customers as possible, with options for different capacity hard drives & types of camera available you can expand your surveillance or change the type of application (e.g indoor to outdoor) just by replacing or adding cameras.<br><br>
e.g. – Customer purchases a 2 outdoor camera bundle for watching the drive & front door, he then decides he would like to watch the rear garden & also his home office…. No problem, just buy one indoor , one outdoor camera & connect using the provided cables – Instant upgrade! <br><br>
<b>Simple User Interface </b><br>
The User interface was designed with simplicity at its core, although it has many advanced functions. We wanted to ensure it was easy to set-up and get started, but also provides all the advanced features you could ever want should you need them. (e.g. Motion detection or privacy masking.)<br><br>
<b>Pentaplex</b> <br>
The Storage Options CCTV System is capable of performing multiple tasks at the same time, it can record, playback, live-view, back-up & network all simultaneously!! (Pentaplex) This ensures your property is still being protected regardless of what you are doing to the system, a great feature and one that ensures you never miss a thing.<br><br>
<b>Recording Time</b> <br>
The length of recording time is determined by 2 key factors, the size of the hard disk & number of cameras being used. Up to 400 days recording is possible. The device is smart too, it will alarm when the disk is full too. (this can then be re-formatted or removed for archive and a new drive fitted)<br><br>
<b>Time & Date Stamped Recordings </b><br>
Time & Date stamped recordings show you exactly when an event occurred, a feature needed should the recordings be used in any criminal investigations. Recordings are stored in date order too so it makes searching for the footage you need even easier. The recordings are grouped into manageable sized chunks for easier copying or backing up <br><br>
<b>Back-up Facility </b><br>
We recognise that at some point you will need quick access to footage stored on your DVR, and so to make it easier, we have included a handy USB port so you can plug in a USB Flash or Hard Disk Drive (HDD) and copy footage across to these devices – whether its just a short clip or a full back-up of your system should you wish to archive.
It’s as easy as selecting the Date range (from & to) and which cameras (one or even all) <br><br>
<b>Network </b><br>
Although this is an analogue CCTV solution, it has a killer feature in that it is network enabled. This feature means that if you connect it to your network you can view your system live from anywhere in the world on any internet connected PC, no need to install software. (Viewed through the web browser) <br><br>
Alternatively there are apps available for iPhone & Android for remote viewing also. You are never more than click away from viewing your home or business.
Was £409.98 Inc. VAT
Only £402.78 inc VAT.
ORDER NOW
Roccat Isku Illuminated Gaming Keyboard @ £59.99 inc VAT
nonl2brThe Isku is the world’s first keyboard to feature groundbreaking Easy Shift[+]™ technology, which puts 36 easily-customizable macros in 3 spots in the easy-to-find WASD zone -- so players can give a multitude of custom orders without ever having to re-adjust the hand position.<br>
Exclusive ROCCAT™ Talk© protocol lets the Isku and other ROCCAT™ TALK- enabled products, like the ROCCAT™ Kone[+] Max Customization Gaming Mouse, talk to each other – opening up a new world of Set Bonus gaming advantages. <br>
For example, this groundbreaking tech works great with Easy Shift[+]™ technology on compatible ROCCAT™ mice, letting gamers use the Isku Easy Shift[+]™ key to activate macros for both the keyboard and mouse – offering one-stop macro activation that lets gamers concentrate more on playing and less on controls. <br>
ROCCAT™ Talk© also allows gamers to take advantage of exclusive EasyAim technology like never before. When a game demands precise marksmanship in sniper mode, a player can simply press and hold a single keyboard key and EasyAim will instantly optimize the DPI setting on the ROCCAT™ Talk©-compatible mouse. <br>
New enhanced Macro Live! Recording makes in-game macro recording a joy. Gamers simply hit the dedicated Macro Live! Recording button and the Sound Feedback tool will talk them through the quick and easy recording process. Players can program up to an amazing 500 actions for each of the 180 possible macros – giving them freedom to lay down any orders they can dream up. <br>
Backlit with ROCCAT™ Extreme Ice Blue Lighting in 6 adjustable brightness levels, the Isku makes it easy to always hit the right key -- even in low lighting. The optimized illumination also means the Isku is perfect for avoiding eye strain during those long gaming sessions. Plus, gamers can program the Isku to automatically switch its lights off if a key hasn’t been hit for a predetermined time – great for a quick break.<br><br>
- Blue key illumination with 6 brightness levels including off setting<br>
- Easy Shift[+]. for simple key duplication and activation<br>
- 3 Easy Shift[+]. zones featuring 28 easy-to-reach macro keys, including 5 doubly-programmable dedicated M-keys and 3 doubly-programmable Thumbster Keys<br>
- Macro Live! recording button for in-game macro setting; 180+ macros in 5 profiles<br>
- 8 media & hotkeys; 25+ assignable functions<br>
- Medium-height keys; optimum keystroke; advanced anti-ghosting<br>
- ROCCAT. Driver & Macro Manager, incl. macro presets for games, multimedia & office apps<br>
- Integrated Extra-Large Granulated Wrist Rest with optimized surface texture<br>
- Cable channels for better device organization<br>
- Non-slip base with lock-on keyboard feet<br>
- Fast profile switching; 5 Profile-Status LEDs<br>
- ROCCAT. Talk: Set Bonus by combining devices<br>
<br>
<center><iframe width="560" height="345" src="http://www.youtube.com/embed/fFZ3yMnimp0" frameborder="0" allowfullscreen></iframe></center>
Was £76.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Storage Options DIY Home CCTV Kit 500GB DVR 2 Cam @ £168.00 inc VAT
Designed specifically for use and installation by those with no experience or prior knowledge of CCTV systems. DIY Home CCTV Kit with 500GB digital video recorder and 2 outdoor cameras. Includes a clear English manual and all the cabling, power supplies, fixings and everything else needed to secure a property. Capable of recording footage from up to 4 cameras simultaneously. Footage can also be viewed from a Smartphone with apps for Apple and Android available.
Key Features
• View on your Existing TV, Monitor or Smartphone
• Up to 50 Days Continuous Recording
• 2x Fully Weatherproof Cameras with Night Vision
• DIY Kit with All Fixtures, a Detailed Manual & Installation Guide Included
Why Install CCTV?
Installing this DIY Home CCTV Kit could be one of the best steps you ever take to secure your home or business premises. As well as protecting against criminal activity and actively deterring criminals from targeting your property and vehicles, it will bring additional peace of mind for you and your family.
Why Choose a Storage Options DIY Home CCTV Kit?
Designed specifically for use and installation by those with no experience or prior knowledge of CCTV systems, everything you need is contained in the box including a clear instruction manual. If you need additional help, our UK-based support team is available for the price of a local rate phone call.
Your CCTV Questions Answered
What is this kit?
This is a DIY Home CCTV Kit, which will allow you to setup and install a CCTV system in your home or small business.
What's Included in the Box?
• 2x outdoor, weatherproof, night vision cameras
• Digital video recorder (DVR)
• 2x 18.3m (60ft) power/video cables (to connect the cameras to the recorder)
• 1x power adapter
• 1x 5-way power splitter (for the DVR and up to 4 cameras)
• Remote control and a mouse to use with the DVR
• Instruction manual
• Wall fittings (screws and wall plugs)
What Else Will I Need to Use the Kit?
Almost everything you need is included but there are some obvious things to remember: You'll need something to view the footage on, either a TV or a computer monitor. A drill, drill bit and a screwdriver are needed to mount the cameras. Internet access is required to view footage on your smartphone and you will need a network cable to connect the DVR to your router.
Can I Add More Than 2 Cameras to the System?
Yes. The DVR included in this kit can record up to 4 cameras simultaneously. Spare cameras are available from Storage Options.
How Long Will the System Record for?
With 2 cameras attached, this kit will record continuously for 50 days. This time is reduced proportionately if a third (37 days) or fourth camera (25 days) is attached.
Can I View the Live Footage from the Cameras on my Smartphone?
Yes. With free Android and Apple apps available, you can now view CCTV footage directly on your smart phone. So even if you are miles away from your property you can still check all is well at home or work and if necessary, take immediate action. Apple app available from iTunes and Android app available from storageoptions.com.
Can the Cameras "See" in the Dark?
Yes, the cameras included in the kit have infrared night vision with a range of up to 10m (32ft). The system will record all events, even if you can't see them with your own eyes!
What if I Need Some Help Setting up or Using this Kit?
No problem. Our UK-based support team is available for the price of a local-rate phone call. Call us on 0844 248 7191 or email [email protected].
Is there a Warranty on this Kit?
This product is backed by a 12-month warranty in the unlikely event of something going wrong. Simply call our support line if you think there is a problem with your kit. More information is available at storageoptions.com
Was £169.99 Inc. VAT
Only £168.00 inc VAT.
ORDER NOW
Mionix Zibal 60 Mechanical Gaming Keyboard @ £139.98 inc VAT
The Mionix Zibal 60 is a fusion of the best keyboard components together with great gaming features that gives you the edge to your game. Engineered with non-tactile, mechanical, black cherry MX switches that deliver the best feel to every keystroke. Multi-level backlight illumination paired with six key rollover that allows you to perform up to six simultaneous keystrokes with all keys, make the Zibal 60 standout from the crowd. In addition to the performance features, the Zibal 60 offers smart functions that include a two port usb 2.0 hub, audio/mic extensions and media control keys for full integration with your desktop setup.
- Black Cherry MX Mechanical key switches
Mechanical non-tactile Cherry MX black switches with 18K Gold plated switch connectors ensures durability and longer life time.
- Comfortable design
Designed with a detachable wrist rest to be comfortable throughout long gaming sessions.
- Backlit key illumination
Every switch is fitted with a single green LED and you can choose from the three different lighting modes.
- Three lighting modes On, Off and WASD
Select between the three lighting modes On, Off and WASD.
- Multi-level brightness control
Three level adjustable brightness control.
- Mionix Action key
The Mionix Action key provides instant access to all the media and illumination functions.
- Six Key Rollover
Register up to six keystrokes simultaneously.
- Rage proof durability
Fends off rage blasts thanks to the 1.6 mm thick steel frame and heavy duty braided cable.
- Built to last
Lifespan of 50 million keystrokes and wear resistant laser printed keycaps
- Connect-through port for audio
Superior audio quality thanks to the insulated shielded cables
- Full speed USB 2.0 hub
Inbuilt with a two port USB 2.0 hub powered by its own USB cable.
- Plug n Play
Complete Plug n Play, all functions can be performed without any software or drivers.
Was £149.99 Inc. VAT
Only £139.98 inc VAT.
ORDER NOW
Swissgear Synergy 15.6" Backpack @ £53.58 inc VAT
nonl2br
<img src="http://www.ccidistribution.co.uk/images/manufacturers/wenger.jpg">
- Made by Wenger, makers of the genuine Swiss Army knife<br>
- CaseBase Stabilizing Platform<br>
- Air-Flow Back padding keeps your back cool even with a full pack<br>
- Essentials Orangiser<br><br>
Material: Poly, Nylon, PVC<br>
Size (DxWxH): 10” x 13” x 18” / 25.4 x 33 x 46 cm<br><br>
<b>Features :</b><br>
- Fits Most 15”/15.6” Notebooks<br>
- Made by WENGER, maker of the genuine Swiss Army Knife.<br>
- COMP-U-FLEX Computer Pocket<br>
- Lifetime Warranty<br>
- Shock Absorbing Shoulder Straps<br>
- iPod/Music Player Pocket<br>
- Air Flow Back Padding<br>
- Quick Pocket<br>
- Essentials Organizer<br>
- Complies with most airline restrictions for hand luggage*<br>
Was £55.98 Inc. VAT
Only £53.58 inc VAT.
ORDER NOW
Saitek X52 Flight Controller And Throttle Joystick - PC (PS28) @ £84.98 inc VAT
The most fully integrated PC Flight Control System Precision engineering, ergonomic design and a detailed fusion of features deliver maximum aeronautical authenticity.
- Advanced programming provided by Saitek Smart Technology (SST) software
- Enhanced gameplay through intuitive Multi-Function display (MFD)
- Illuminated buttons and MFD - ideal for low light environments
- Rubber grips and ergonomic design for increased comfort and fatigue-free gaming
- Part metal construction for increased durability and authenticity
- Includes Roger Wilco Chat software - the ideal accompaniment for on-line multiplayer gaming
Was £86.99 Inc. VAT
Only £84.98 inc VAT.
ORDER NOW
Saitek Pro Flight Rudder Pedals - PC (PZ35) @ £81.98 inc VAT
The Pro Flight Rudder Pedals are solidly constructed and feature three axis pedals which maximize flight simulator realism by enabling foot control of the rudder function. Paired with a Saitek X52 Flight Stick and Throttle, the Pro Flight Rudder Pedals provide the additional sensitivity and control accuracy for an almost real flight sim experience.
- Self-centering pedals with adjustable damping
- Adjustable foot rests to fit all sizes, with non-slip materials
- Fully adjustable rudder control to suit the gamer’s preferences
- Tension adjustment to vary resistance to suit flying style
- Advanced SST Programming
- Toe brakes
Was £83.99 Inc. VAT
Only £81.98 inc VAT.
ORDER NOW
Saitek Pro Flight Yoke System - PC (PZ44) @ £104.99 inc VAT
Precision. Realism. Control. The Saitek Pro Flight Yoke System is highly engineered to meet the exacting needs of the true flight simulation enthusiast. Stainless steel shaft, ergonomic controls, integrated chronograph and separate throttle quadrant ensure a smooth, accurate and totally realistic flying experience.
- Durable Stainless Steel shaft with precision bearings gives smooth and predictable elevator and aileron control
- Used with the supplied SST Programming software, integrated mode switch trebles the number of controls you have at your fingertips
- Accurately time each leg of your flight plan with the integrated chronograph
- Separate throttle quadrant with additional switches to configure any combination of throttle, flaps, mixture or prop pitch. Mount on top, in front of your desk, pilot or co-pilot side so that the controls are exactly where you want them
- Unique, 2-position desk clamp keeps your yoke and quadrant securely fixed no matter how extreme the flying conditions
- Saitek’s powerful Saitek Smart Technology (SST) programming software allows gamers to configure their controls to suit their preferred gaming style, and to save the configurations aspersonal profiles
Only £104.99 inc VAT.
ORDER NOW
