Hi, im thinking of buying this CPU (and a motherboard to go with it), I currently have a 4ghz i3 550 that I purchased from OCUK last year as an over-clocked bundle. From the reviews I have seen of the 4100 it appears its unlocked multiplier allows you to simple crank it up to 23x and run the CPU at 4.6ghz right out of the box on the stock cooler (I wouldn't be using the stock cooler).
What will the performance difference be between a 4ghz duel core i3 and a 4.6ghz quad core bulldozer? any ideas?
Thanks.
Thanks.
