- 8 Oct 2008
The only the the graph shows is that regardless of 1 or 2gb neither can run bf3 ultra settings at a acceptable frame rate. The massive amount of sampling applied worsens the results.
Anything less than 60 FPS for a FPS is just pathetic.
That's (frames per second) for a (first person shooter)
Please re run the test maybe at high settings, or even lower so the average fps does not dip past 60. I'd expect there would be much less difference in performance between the 1gb and 2gb cards. I'd expect it would make no difference at all if you tried to get 120fps. (maybe bf3 cant do this ?)
I agree high res + high settings requires more vram, however it's a moot point when to achieve both at the same time you end up reducing frame rates to a jerky mess. The cards just are not capable of running ultra at such a resolution regardless of ram.
A misleading test. Shame on you Gibbo
