***** The Official Fifa 12 Thread *****
This weeks TOTW sucks, guess that's a good thing as it stops me from throwing more money into the game.
Anyone else find David Silva a bit rubbish at CAM in 41212? He seems too weak and slow to drive into the area, his dribbling isn't as good as his stats suggests. Modric any better? If not may go with Nasri.
Yeah I agree.
I'd go Nasri.
I've got him at CAM at the moment and think he's brilliant! I tend to fare better with small playmakers with good close control, dribbling and passing and he seems to fit the bill :D
For all the bragging about past victories and tournament wins etc, Fifa 12 is a bit different to Fifa 11, people will tell you I was very good at 11 but as everyone knows Im rubbish at 12.
Just play the game and get it over with.
No bragging, I was called out and asked to provide evidence, which I did :)
If you can defend in FIFA12 it's really not that different, the same players are dominating the competitive scene!
Tim's the opposite! ;) Fifa 12 has done wonders for his reputation
He's been practicing lots (Well, until SR3 came out :rolleyes:....:p), not sure if the "training" I gave helped or hindered him but he's definitely better than he gives himself credit for!
It has helped no end I think, although when you suddenly go all out, like our last match, I proceeded to retire to the corner of the office and whimper like a ginger step-child :(
Yeah I agree.
I'd go Nasri.
Any weakness in Nasri's game that I should know about?
I also like my CAM to have good close control and dribbling but can't seem to get Silva to play an effective way. Think I need some pace at CAM too as my ST are Suarez and RVP which both aren't blessed with lightning speed.
You're really going to try & drop 1.8mil on IF Aguero? There will be a SIF at some point for sure, probably retailing about 800K max, and you'll have dropped 1.8-2mil on a same stat/lesser stat card?
I jus don't get it :( But good luck!
Ive said it before that i believe NIF Aguero is the best player you can pick from the premier league. i can only imagine that an IF Aguero would be beastly. i cant mention how many times he has come off the bench and saved the day for me.
my understanding is IF Aguero is expensive as he is a rare one? i see your logic behind the SIF but i will still work at the coins and weight up my options when i have the funds available.
I'm thinking of selling my copy, does anyone know that if I sell it and then rebuy, will the new online code still work with my account?
I assume if I sell it with the code, I keep that code anyway so can reuse that later on?
Also leaves me open to a counter attack though, which you've exploited a few times! ;p
Copies are not worth much with a used code.
I'd just keep it unless you're desperate for £15?!
You will lose money re-buying in the future that's for sure.
