I'm building my first PC and will probably initially just use the integrated graphics with the 2500K and Z68. I don't really play games so I don't need the greatest GPU, and even if I started up I wouldn't be worried about playing everything on the highest settings at all.
But what is a decent bang-for-buck second-hand GPU for around the £100 or less? I don't really know much about GPUs. Would a 460 be okay? I'd like to stick with Nvidia as they work better with Photoshop and Linux, both of which I use (not at the same time).
Thanks.
Thanks.
, and you have to be a member for at least 3 months as well iirc.
