Howdy peeps,
Recently bought a 3gb 580GTX from OcUK and have been noticing it hitting the highs of 84C when playing rather demanding games. I bought 3x140mm case fans to try and remedy this problem yet they haven't made the difference I have hoped for, although I haven't tried different "push/pull" configs yet, which is where I need help with!
Case is the coolermaster CM690 II advanced, so has tonnes of places for fans.
Fan config is at the moment the following:
2x 140mm fans on the top blowing OUT of the case
2x 140mm fans on the side (left) blowing OUT of the case
1x120mm fan on the H60 cpu cooler also blowing out of the case
1x 140mm fan on the front blowing INTO the case
140mm fan on the PSU blowing INTO the case (from the bottom)
So currently have 5 fans extracting air, yet 2 putting air into the case.
Contemplating having the 2 new 140mm fans (akasa quiet) to intake instead, blowing cool air onto the gcard and CPU and see if the 3 other fans can extract the warm air well enough.
Is this a good idea or will I be just wasting my time and need to look at 3rd party cooling options for the 580GTX instead, which I don't really wanna do due to warranty issues with removing heatsinks...
Card is a palit 3gb 580GTX for reference.
