It's an OCZ PSU, mine died in almost exactly the same way but while I was asleep and I woke up to the smell of burning components!
It killed the mobo (A UD3-P so not exactly the easiest of boards to kill!!) and I presume my Q9550 too which cost me an arm and a leg died too.
Buy a new PSU, one from corsair perhaps, avoid OCZ. Yes there are good ones but no point chancing it again with such high spec hardware. When a PSU goes it should take only itself, not other components.
Unfortunately for me, OCZ would not cover the cost of anything else, their policy only covers the PSU which I thought was rubbish, they would only replace the PSU so I had to fork out and ended up upgrading mobo, CPU and RAM and bought a new PSU.
Edit*
I had the same PSU as you BTW.
Off topic, but it doesn't matter if their policy covers it or not - you need to take the retailer to small claims court (as it's them your contract is with) if they won't play ball.
If their product directly caused your part to fail through malfunction, they're liable.
A friend had exactly the same issues, turned out one of his sticks of RAM died and didn't even allow the board to POST.
New one on me, but anything goes with computers..!
Try booting with one stick at a time
Can't you run the system on the cheap 400w psu just remove the 560 and use the onboard gfx
For the sake of £300 odd I did not think it was worth the long drawn out process of going through small claims. They will also spend as long as they can "Investigating" the problem.
£750...![]()
hope you get it fixed soon neil - had the pleasure of murdering you repeatedly on BC2 many a time and have yet to had the pleasure on BF3 !
£34 for a power supply?
You should spend decent money on a high quality PSU at all times!
Easiest thing to do is just unplug the atx cable from your mobo, jump start your PSU with a paperclip and see if it'll power a fan off a molex connector. If not, bad PSU.
POWER SUPPLY!!
Plugged cable GREEN / BLACK on main connection as per instructions
Plugged in a Fan into molex connection
Flicked the switch, The psu fan moved and the fan moved slightly then straight away instant off. The fans probably moved about a cm
What bugs me is people always say " NEVER BUY UNBRANDED " Always make sure you buy such and such. Well i had a case psu that lasted 4 years and a qtech that lasted 5, both branded psu's that i've ever purchased have died shortly after![]()
