MSI Z68A-GD65-G3 Intel Z68 (Socket 1155) DDR3 Motherboard or Gigabyte GA-Z68XP-UD4 Intel Z68 (Socket
15 Nov 2011
Oxford
hi, not sure which to go for?
which would be the best to overclock 2500k? beening fairly easy to, im new to oc systems. and which is gernarally the better board?
The Gigabyte has 10 levels of Load Line Calibration, the MSI just uses one "Low VDroop" option, plus the Gigabyte has a DVID/Offset mode, although I haven't seen conclusive evidence that it works well.
It's more down to the CPU really, virtually all 2500K's will clock to 4.4/4.5 GHz, the MSI is a good board and will do the job.
Take your pick.
Take your pick.
cheers what would u suggest?
also seen http://www.overclockers.co.uk/showproduct.php?prodid=MB-476-AS&groupid=701&catid=5&subcat=1990 what is that one like?
or Asrock Z68 Extreme4 Gen3?
Those two boards have offset and load line calibration features which are better that the MSI motherboard.
I would also consider the Gigabyte Z68XP-UD3P, it's £10 to £20 cheaper than those boards you mentioned and will do a good job and has all the bios features you need.
Gigabyte's got the best warranty service as well, it's in the UK, the only thing it lacks is the UEFI BIOS, not a big deal though.
Any of those motherboards will do the job, no problem.
And no onboard DVI or VGA outputs ;)
Oh yep so if you run higher than 1920x1200 resolution and don't use a discrete graphics card, it won't be the motherboard for you lol.
Cheers decided on the asrock extreme 4 gen 3, nah i will be using a 6970, and will be xfiring it later on.
just need to sell my current system. before i buy.
