I'm talking about standard 1080p or around that resolution and I've posted two independent reviews/benchmarks which state the same thing: that the extra vram is not worth it.
Well don't post 5760x1600p benchmarks from rubbish sources for all we know they could have been using bhavv's example of using 3Gb 580sli with an Athlon!
So if I was to take your advice, I could be ripping out a PII 955 BE@4GHz, a MB and maybe the ram too or probably double it(giving my self a seriously costly upgrade on top of the price of the gpus), and buy a pair of 1GB cards?
Where as keeping my current system and spending at the most, £50 extra on 2x2GB gpus!
That is absolutely shocking advice bhavv, you should really have a good think about it, seriously!
It's not the point if you shouldn't have, if someone already has this kind of setup and reads your post and takes your advice especially while reading this thread to make their minds up in regards to BF3 which isn't cpu dependant at all.
I'm in no way confused or missing the point!
You have now resorted to deflecting the debate onto performance in other games and other cpu's that has nothing to do with, or discussed in regarding the op!
Of course the Athlon and tri sli combination is a marraige made in hell, but you can't compare a 2GHz Athlon and still ignore the performance of the PII@4GHz, while obviously it's not going to be as good a performer as an i5, it makes no difference in the case of BF3.
You are still ignoring the fact that you advised binning a perfectly good cpu and system for BF3 rather than a simple £25-£50 difference which is frankly shocking advice.
Ever thought about taking up polotics bhavv because you are going way off course rather than admit a 2Gb card makes more sense regarding BF3 mate.
BF3 is only one single game which has no CPU scaling whatsoever, and runs like crap on almost any system with 4x MSAA. I dont get why people use this obviously flawed game as an indicator of system performance.
For being the most highly optimised game to date for the PC that utilises the best gaming hardware on the planet to it's fullest potential, how can you possibly say that BF3 is flawed?
Pre BF3 patches and running on BETA drivers at the time:
I thought I would post a small video of Battlefield 3 multiplayer Caspian Border Gameplay performance of my unlocked 6950 shaders @ 6970 clocks in Crossfire.
Benchmarks are all over the place with many discrepancies imo.
There are a few posts saying that 6970 Crossfire is not enough @1080p with Ultra settings, well you can decide for yourselves now.
Specs are:
Battlefield 3 AMD Crossfire Performance
Full Caspian 64 Player Map
Ultra Settings
In game fps using console command:
'Render.DrawFps 1 Boolean'
Amd 6950>70 Crossfire @ 880MHz/1350Mhz
Catalyst 11.10 preview2 + Cap3 Win7
2500K@ 4.5GHz
MSI Z68A-GD55-G3
16GB Corsair Vengeance Red 1866 Mhz
128GB Crucial M4-Windows
120GB Corsair Force 3-BF3
Windows Pagefile is disabled(I don't know if this helps with the stuttering but I've never had any)
This may help if you are trying to decide whether 6950/70's Crossfire is for you or whether it's worth adding a second card.
Yes the videos not centred, that wasn't the point.
P.s I thought the missus was not bad for her first shot of the tank!![]()
1080p vram usage happy in the knowledge that my cards can utilise the extra vram than not having the option at all:
And since you brought other games into the debate, here are some other DX11 titles @1080p:
If I were to go out and spend a bucket load of cash on a system and slap 1Gb cards into it and couldn't max out BF3 due to taking your advice, instead of just getting 2Gb cards, I would be absolutely
