[TW]Fox;20487466 said:Buying super budget all season tyres strikes me as being rather counter productive.
[TW]Fox;20487534 said:Lol at your posts. Obviously yes I was referring to Goodyear.
[TW]Fox;20487704 said:The first result is a Nankang. I was making the valid point that people should not be tempted to buy super-budget winter/all season tyres because its counter productive.
Obviously I was not referring to Bridgestone and Goodyear as super budget tyres![]()
they do loads of all seasons.
Ah, right, so because nankang was top of the list I was suggesting those...
Yeah you can have those back for your obtuse prior posts, especially as my previous post was CLEARLY a Goodyear...
Hi there
Well all OK now.
Got a pair of Uniroyal MS 55 Winters for the rear with 4mm-5mm - £31
Also a pair of Dunlop Sport 3D Winters for the front with 5mm - £60.
This time I've avoided puncture repaired tyres. So 4 winter tyres all round for sub £100, happy days shall get me through winter and any snow should we have it and then I can either leave on until worn out or buy a set of Summers for summer and just switch between the seasons.![]()
Good going.
Part worn from local tyre fitter or online?
Think I'd have put the Dunlop's on the rear though.
But I did at first think the marginally deeper tread would be better suited on the rear as it is a RWD vehicle.
I would've gone with the better tread on the rear tbh.
For the Jaguar? It should have V speed rating or better, as H is only rated to 130 MPH yet the 3.0 V6 will do 140+!they are the correct rating for my car (95H)
Yep agreed in principle.
But the Uniroyal MS 55 winters have rather soft sidewalls, they are the correct rating for my car (95H) but would make the front end feel like driving on sponges, though great for comfort.
Hence why I am going to see how things go with the Dunlops on front as they are Sport 3D's and definetely have stiffer sidewalls.
Fact is I've gone from:-
1x Illegal Bridgestone on the rear.
1x 4mm never heard off on the rear.
2x Firestone or Firehawk 3mm on the front.
So big improvement all round and should it snow I won't be getting stuck.![]()
