Few games Im gonna buy, pc or ps3?
All these games will play well on a pc, plus you'll get better graphics too. Only thing to consider for maybe Modern Warfare, is what your mates will be playing it on.
well pc i get higher resolution and details.
I also can use pad and on big tv same as ps3.
Only benefit ps3 has is if I want to play freinds online, that would only be MW3 though?
BUt MW3 fps games are better with keys and mouse right?
Im not into using controller online its to inaccurate.
everything's pointing towards getting them on pc. As you say you'll get:
1) better graphics
2) you can still play on a big tv with controller if you want.
3) FPS games are definitely better with a a mouse and keys.
Go for it mate, I see no reason why to get them on ps3. I also own a ps3 but generally only use it for watching blu ray movies now.
PC + pad + 1080 TV = win for all those games but MW3 which calls for M+K and you should get friends with PCs or persuade your friends to buy better PCs (I am slowly doing this by introducing them to older gamer their PCs can play (CS, Quake, UT) showing how much better M+K is and then gradually easing them into building PCs :D)
As you can link your PC up to the TV and have a controller you have the best of both worlds and should get them on PC for better graphics and performance.
The only one with any questions around it is MW3. Mouse and keyboard is better but if you have real life freinds that all play on PS3 you may want to opt for the PS3 version. Also the elite service for MW3 is not available on PC (a slimed down version is apparently in the works) if this interests you then you might again consider ps3.
what do you mean?
Im guessing you mean the comment about steam and 'Skyrim 4Gb'?
The game has to be installed through steam, for some reason. a lot of people, including me have experienced games completely crashing, while starting the game from the steam interface. Some people say it's because steam, have somehow, limited the game to only use 2Gb of RAM. As the game needed more to run stable it crashes (normally every 2 hours).
Skyrim4GB is a launcher which activates and changes a few setting allowing Skyrim to ultilise 4Gb of RAM, therefore preventing crashes.
It looks beautiful on PC compared to my friends Xbox 360 version.
It only uses 2GB of RAM max but I don't think that is Steam's fault is it? Still 2GB is better than 512MB eh ;):p
ps3 only has 512mb?
Anyway I only have 3gb so not much more.
But if I play 1080p med-high details on PC it will be much nicer than ps3 and ps3 prob capped at 30fps.
Plus moddable on PC.
So I should really get for PC?
ps3 only has 512mb?
Yes thats right your PC has 6 times more RAM than your PS3. Consoles are old...really really old.
Can the PS3 even play all those games at 1080?
Yes get it on PC.
