They've upgraded the Libraries PCs to the ones I mentioned earlier (some might be i5 but the one I was on was i7). There's also about 4 times the amount they did have.
You're at Sussex?
Always found it a little odd that businesses, libraries etc always use quite beefy CPUs rather than the budget versions, but I guess it comes down to longevity really.
They always manage to be horrendously slow in any case so it's probably a good thing they don't use cheap CPUs.
You're at Sussex?
When i was at uni in 95 a lot of the computers were pretty high spec for the time. Only one department were stuck with 386's when everywhere else had high end 486's or pentuim 1's. I even remember one lab having Sun computers that must have been mind bendingly expensive at the time
These computers are part of a cluster which is used for big distributed computing projects during University out-of-hours. They're not that wasted.Yep. All the libraries are running Intel i7 2600 CPUs with 8GB of RAM and 23" HP monitors for all the libraries across the various campuses (including hospital libraries in most sites).
Pretty overkill for using Word and web browsing.
Oh yeah, and they're getting like 250MB/s download speed too.![]()
wish my uni had i7 computers, takes 5 minutes just for it to load general applications!!!
Yep, I said this aboveDon't they use them for distributed computing efforts when not in use too?
You must be at Manchester uni.![]()
