** NVIDIA GTX 560Ti "448 Edition" NOW AVAILABLE! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We have two cards based on the new "448 Edition" GTX 560Ti from NVIDIA. These offer the same 320-Bit memory interface and extra memory just like a GTX 570 but at a much reduced price. As both our versions come overclocked out of the box performance is very very close to a GTX 570 but at a considerably saving. We have the MSI in stock right now and the Zotac cards are due to arrive tomorrow:-
MSI GeForce GTX 560Ti OC Power Edition "448 Edition" OC Twin FrozR III 1280MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 "448 Edition" rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2, Battlefield 3, Skyrim with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 "448 Edition" packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560 "448 edition" - arm yourself for battle.
Features:-
- Core Clock: 750MHz
- MSI Twin FrozR III Cooler for maximum cooling potential and low noise
- Memory: 1280MB GDDR5
- Memory Clock: 3900MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 448
- Shader Clock: 1500MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 3 years
Only £239.99 inc VAT.
ORDER NOW
ZOTAC GeForce GTX 560Ti "448 Edition" OC 1280MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
Features:-
- Core Clock: 765MHz
- Zotac innovative low noise cooling solution
- Memory Clock: 3800MHz (Effective)
- Shader Clock: 1530MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 5 years
ORDER NOW
gtx560 £240
gtx570 £240
saving= nothing
any negative comments I make on this thread are not directed at OCUK but Nvidia.
Just can't see the point :confused:
This should be £150 to fly off the shelves in order to dent 7800 sales
plus, 1280MB indeed :rolleyes:
gtx560 £240
gtx570 £240
saving= nothing
That 570 is on special offer and is an extremely good buy, the price goes up £20 tomorrow, so if you want a cheap GTX 570 grab that one quick. ;)
Nvidia are just cashing in on surplus and branding failed GTX570 cores as Limited Edition.
From a business standpoint, it's understandable, as a consumer, it's just plain frustrating. :D
Either way, people should be futureproofing with 2GB+ or more VRAM now or holding out till the new AMD stuff.
I don't think Nvidia will release Keplar till mid 2012.
IF I was in the market for a 570 (and lets be fair, you'd have to have your head examined to be buying a 570 now) I'd rather spend the extra £20 as these new 560ti 448s seems to be just a damaged 570 with £20 knocked off.
Basically Nvidia are charging todays prices for todays performance. We are on the virge of tomorrows performance for todays prices.
The 560ti 448 should be todays performance for tomorrows prices to get the undercut on AMD
I for one will be waiting for the 7870 which will beat these cards on performance and be a lot cheaper, plus will come with 2Gb vram as standard, which will help when it comes to Xfire.
why do you suggest that? 570's are excellent cards
don't get me wrong, they are fantastic cards but aren't you curious as to how good the 7800 series will be next week? I can understand buying a 570, but not when we are this close to the new AMD line up.
They will (most probably, although not confirmed) be:
Faster (8% on a 6970?)
Cheaper :D
Cooler
Quieter
I think that applies not only to the GTX570...in fact, people shouldn't buy ANY card (including 6950/6970) that are still on the dated 40nm process with the next gen cards around the corner. Nobody should be "upgrading" their graphic card right now...the only people should be buying a new graphic card right now are those that need a new rig built asap and absolutely cannot wait for next gen card.
To be honest, if I was someone who got a new PC but no graphic card, I'd just pick up something like a 2nd hand 8800GT/9800GT 512MB for £20~£25, or a 2nd hand 5850 for £80~£90 as a temporary solution until the release of the new cards, rather than spending £200+ on cards that will hit EOL soon.
Do AMD cards still have problems with stuttering in BF3?
personally i am really gagging to buy a card to play skyrim/batman etc at near enough max settings, i dont like lowering stuff down at all it annoys me and i like 60fps min always. i have a 460, so a 560 ti is too small a upgrade to be worth it.
right now i am holding out playing games until i upgrade. What is really annoying is seeing the price of 570's rise slightly, surely as amd are ready to release brand new cards, nvidia would counter this by selling as many as possible now to reduce the number of people lookign to upgrade.
You always have special deals on, wont be long before a different 570 is £230.
Cheaper :D
Cooler
Quieter
You've heard the 7870 will be 8% faster than a 6970? I had assumed the 7870 would be at least as fast as the 6970 just because of the similarity in terms of specifications, but I know that the specs don't tell the full story, so I could definitely see an 8% increase. Couple that with a massive price drop and much less power draw/heat and it's a no-brainer.
I am so disappointed with the prices of these. Wish I had bought the MSI 2GB 560Ti for £200 now.
I was all ready to order one of the 448 cards for £200, maybe £220, but just not worth £240. I think some work needs to be done with prices.
I'll take an MSI one for £220. Go on, you know you can do it :p
