- 20 Oct 2009
- Deepest, darkest Essex
But the microserver states that it is not hot swap capable.
It's not..... but thats not the benefit you would gain by using AHCI
hint - it's the other one
That all looks fine.
Have you tried setting up the drive as GPT natively somewhere first?
just ordered a N40L... but not sure it will come with a november invoice![]()
now reading up after installing i cannot mirror folders onto other drives in the microserver as backup? or am i missing somthing?
The MicroServer support RAID 1, so you could do your mirroring that way. (The two drives will appear as a single drive to Windows.) I haven't done this myself, but I assume it should be straightforward enough.
If you want the mirrored copy to appear in Windows Explorer, etc., you'll have to use something like SyncToy (my favourite) to do the duplication.
When you say Linux From Scratch, have you actually gone for an LFS approach, or is this how you're describing the base Debian install?
Wish I'd seen this a couple of days ago. Will miss the cashback thing I think so no server for me!
True, there's a good possibility of the cashback being extended, but I figured, if it isn't, I'm going to be annoyed.
Or you can set duplication up on the folders.
how do you do that?
Go on the folders tab click properties and at the bottem click the check box for duplication.
