Hey, I have a few questions regarding overclocking my i5-2500K to 5GHz,
Is a coolermaster hyper 212+ sufficient for 5GHz everyday use? i have 6 case fans (3x120mm, 1x140mm, 2x200mm), and an NZXT Phantom case if that makes any difference
And what settings would you suggest for going to 5GHz? Currently it is running stable at 4.8GHz, (26 Hours test on Prime95 blend), with multiplier on 48x, and CPU Voltage 1.375v, it definitely can be stable at 5GHz, as my friend tried it in his computer and managed it for 24hours on Prime95 blend,
Also, i cannot find anywhere in the ASUS Bios for my mobo (ASUS P8P67 Pro Revision 3.0) an option to enable 'Internal PLL overvolt'
I am very new to overclocking, so layman's terms if possible, any help is much appreciated
