BT Infinity & FTTx Discussion
Yeah there is loads of different levels of interleave.
Also different IP's on BT will give lower/higher pings to certain sites. I usually reboot my router a few times till I get nice pings to BBC, Multiplay and Jolt.
Example;
With IP of 86.144.253.174
ping mutliplay.co.uk -t
Pinging mutliplay.co.uk [85.236.96.22] with 32 bytes of data:
Reply from 85.236.96.22: bytes=32 time=13ms TTL=119
Ping statistics for 85.236.96.22:
Packets: Sent = 5, Received = 5, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 13ms, Maximum = 13ms, Average = 13ms
VS
86.180.255.208
Reply from 85.236.96.22: bytes=32 time=18ms TTL=119
Packets: Sent = 6, Received = 6, Lost = 0 (0% loss),
Minimum = 18ms, Maximum = 18ms, Average = 18ms
Some IP's even give as high as 35ms to Multiplay
Since I had the new modem installed this morning I now get 9mbit upload instead of 8
ADSL24 using Netgear WNDR3700.
Search my posts in this thread to see what kind of service you will get.
For anyone interested in getting 9mbit upload instead of 8.3 uncheck the QOS on the modem, you will need to unlock it.
QOS ON:
QOS OFF:
If someone else could test this, would be nice. I've tested after a few reboots and it seems to stick so..
Its cheap and works great!
The only reason to pick another FTTC ISP is if you have more money than sense, or enjoy being told how much you can download.
Yeah, you get the modem + Homehub 3.
I've never had any problems with the HH3 it just lacks features really, others in this thread might tell you different tho :)
