I've already initiated it - and have got to the part where I need to go to the shrine, but just can't find the path up there...
Daedric are the strongest weapons and enchanted
So, is there a 4gb fix that still works then? Want to play but keep crashing again.
Tried the clairvoyance spell with the quest set to your active one?
Did you try following the guy from the quest? He makes a beeline straight for the place.
Never used it (does it do more than the marker does?) - tend to sell all spell's found as playing a sneaky archer character.
