Yes mate. Tried multiple GPUs. Reset CMOS. Tried every ram configuration possible. Unfortunately I don't have a multimeter or second power supply though.
I wouldn't have thought a 750w PSU would have any problems, but what if you consider it's 3.5 years old and been used 7 days a week for probably 10 hours a day.
Tried different plugs, without any extensions. Didn't work. No one I know with a PC either
Probably just going to buy this:
http://overclockers.co.uk/showproduct.php?prodid=CA-051-BQ
And then RMA my TX750 and sell one of my PSUs when I get my replacement. Do you guys think that PSU in the link is decent? Good enough to run a GTX 570 and Q6600?
I would go to a local PC shop and buy a PSU, if it doesnt work pack it back up nicely and return it, tbh if you boot with 1 stick of ram on the bench with a new psu and on your 2nd mother board with no gfx card in and it still does it you must be plugging in something wrong on the board or all the ram is bust which is unlikely. Have patience though you will solve it.
