HD2000/3000
11 Apr 2008
Guy's,
Whats the difference between an HD2000 & HD3000 chip in terms of speed ( or whatever the difference is), and is the HD3000 worth the extra money you reckon?
thanks
3000
2000
double the power and depends on what you intend on doing?
If you're serious about gaming then it doesn't really matter tbh, neither are really that good compared to the add-in GFX cards you can buy.
Very true if you want to game then dont use the HD3000 not good enough not even great for every day tasks for me the picture on my monitor always looks washed out.
To be fair, compared to the integrated graphics we've put up with for the past decade, the HD2000 and 3000 are actually quite decent, and okay-ish for low detail gaming at lower resolutions.
They basically make the low-end HTPC cards redundant.
But something like a GTX550/HD6750 would utterly walk all over them, and then some.
I second this, the HD3000 graphics in my ULV i3 still amazes me.. maybe my standards are low but it copes really well with almost everything I've thrown at it (albeit not CoD MW3 quite..) for what it's designed for I sing it's praises but yes it's not dedicated GPU.. don't expect the same performance!!!
